How to set SDA= p0.25;and SCL=P0.26 default pin configration.
You don't use UICR for that.
You use either sdk_config.h or the custom board header file for your board (when using NRF SDK).
Thank you for reply.
how can i go through sdk_config.h file.please explain me
If you are using the TWI driver in the SDK (nrf_drv_twi), the GPIO pin numbers are set in the config struct passed to nrf_drv_twi_init(). For instance, in the twi_sensor example, the ARDUINO_SCL/SDA pins are used:
void twi_init (void) { ret_code_t err_code; const nrf_drv_twi_config_t twi_lm75b_config = { .scl = ARDUINO_SCL_PIN, .sda = ARDUINO_SDA_PIN, .frequency = NRF_DRV_TWI_FREQ_100K, .interrupt_priority = APP_IRQ_PRIORITY_HIGH, .clear_bus_init = false }; err_code = nrf_drv_twi_init(&m_twi, &twi_lm75b_config, twi_handler, NULL); APP_ERROR_CHECK(err_code); nrf_drv_twi_enable(&m_twi); }
These pins are defined in the pca10040.h board header file:
#define ARDUINO_SCL_PIN 27 // SCL signal pin #define ARDUINO_SDA_PIN 26 // SDA signal pin
You can define your own pins in the application:
#define TWI_SCL_PIN 26 // SCL signal pin #define TWI_SDA_PIN 25 // SDA signal pin
And then set these in the config struct.
thank you, but i want default pin configuration. after reset and erase their is no changes to defined pin.
i think above are user defined pin configration .
I'm not sure what you mean by "default pin configuration". There is no default pin config for the peripheral. Any GPIO can be configured to be used with any serial peripheral. You need to define the pin usage in the application. The pin configuration can be changed in run-time. If you erase the chip, it will not have any TWI peripheral configured so the pin config will be irrelevant. The pin config will always be set on boot by your application.
