Sample LWM2M client using for FOTA
Hi
So I tried to use the lwm2m sample client (nrf\samples\nrf9160\lwm2m_client) for FOTA upgrades. I do get a connection to my plattform. When I start the update I do get the following in a loop.
m[8D[J[1;32muart:~$ [m[8D[J[00:00:50.592,498] [1;31m<err> net_lwm2m_engine: Unknown IP address family:0
[0m[1;32muart:~$ [m[8D[J[00:00:50.592,529] [0m<dbg> net_lwm2m_engine.lwm2m_udp_receive: checking for reply from [unk]
[0m[1;32muart:~$ [m[8D[J[00:00:50.592,590] [0m<dbg> net_lwm2m_engine.handle_request: No accept option given. Assume OMA TLV.
[0m[1;32muart:~$ [m[8D[J[00:00:50.592,681] [0m<dbg> net_lwm2m_engine.engine_add_observer: OBSERVER DUPLICATE 5/0/3(3) []
[0m[1;32muart:~$ [m[8D[J[00:00:50.921,600] [1;31m<err> net_lwm2m_engine: Unknown IP address family:0
[0m[1;32muart:~$ [m[8D[J[00:00:50.921,630] [0m<dbg> net_lwm2m_engine.lwm2m_udp_receive: checking for reply from [unk]
[0m[1;32muart:~$ [m[8D[J[00:00:50.921,661] [0m<dbg> net_lwm2m_engine.handle_request: No accept option given. Assume OMA TLV.
[0m[1;32muart:~$ [m[8D[J[00:00:50.921,752] [0m<dbg> net_lwm2m_obj_firmware.package_uri_write_cb: PACKAGE_URI WRITE:
[0m[1;32muart:~$ [m[8D[J[00:00:50.921,783] [0m<dbg> net_lwm2m_engine.lwm2m_notify_observer: NOTIFY EVENT 5/0/3
[0m[1;32muart:~$ [m[8D[J[00:00:50.921,783] [0m<dbg> net_lwm2m_obj_firmware.lwm2m_firmware_set_update_state: Update state = 0
[0m[1;32muart:~$ [m[8D[J[00:00:50.921,813] [0m<dbg> net_lwm2m_obj_firmware.lwm2m_firmware_set_update_result: Update result = 0
[0m[1;32muart:~$ [m[8D[J[00:00:50.921,875] [0m<dbg> net_lwm2m_engine.lwm2m_notify_observer: NOTIFY EVENT 5/0/3
[0m[1;32muart:~$ [m[8D[J[00:00:50.921,875] [0m<dbg> net_lwm2m_obj_firmware.lwm2m_firmware_set_update_state: Update state = 1
[0m[1;32muart:~$ [m[8D[J[00:00:50.922,027] [0m<dbg> net_lwm2m_engine.lwm2m_parse_peerinfo: Parse url:
[0m[1;32muart:~$ [m[8D[J[00:00:50.922,973] [0m<inf> net_lwm2m_obj_firmware_pull: Connecting to server
[0m[1;32muart:~$ [m[8D[J[1;32muart:~$ [m[8D[J[1;32muart:~$ [m[8D[J[00:00:51.517,486] [1;31m<err> net_lwm2m_engine: Unknown IP address family:0
[0m[1;32muart:~$ [m[8D[J[00:00:51.517,517] [0m<dbg> net_lwm2m_engine.lwm2m_udp_receive: checking for reply from [unk]
[0m[1;32muart:~$ [m[8D[J[00:00:51.517,578] [0m<dbg> net_lwm2m_engine.handle_request: No accept option given. Assume OMA TLV.
[0m[1;32muart:~$ [m[8D[J[00:00:51.570,526] [0m<dbg> net_lwm2m_engine.generate_notify_message: [MANUAL] NOTIFY MSG START: 5/0/3(3) token:'' [] ERR
[0m[1;32muart:~$ [m[8D[J[00:00:51.571,746] [0m<dbg> net_lwm2m_engine.generate_notify_message: NOTIFY MSG: SENT
[0m[1;32muart:~$ [m[8D[J[00:00:51.637,817] [1;31m<err> net_lwm2m_engine: Unknown IP address family:0
[0m[1;32muart:~$ [m[8D[J[00:00:51.637,817] [0m<dbg> net_lwm2m_engine.lwm2m_udp_receive: checking for reply from [unk]
[0m[1;32muart:~$ [m[8D[J[00:00:51.766,448] [1;31m<err> net_lwm2m_engine: Unknown IP address family:0
[0m[1;32muart:~$ [m[8D[J[00:00:51.766,479] [0m<dbg> net_lwm2m_engine.lwm2m_udp_receive: checking for reply from [unk]
[0m[1;32muart:~$ [m[8D[J[00:00:51.766,510] [0m<dbg> net_lwm2m_engine.notify_message_reply_cb: NOTIFY ACK type:2 code:2.4 reply_token:''
[0m[1;32muart:~$ [m[8D[J[00:00:51.766,601] [0m<dbg> net_lwm2m_engine.lwm2m_udp_receive: reply 0x20021b70 handled and removed[0m
Is the sample client made for FOTA? If not what is needed to upgrade the client to get it working? Is there anywhere a tutorial or something that will help me?
Kind regards.
  • To clarify what I meant in my previous post:
    When building your project, a script is run, which places all the images into the flash at fitting places. The bootloader is then given this map of the flash and uses that map to know where to jump to.
    Likewise, the application uses the partition map to know where to store update images, and where to write to the bootloader that the image is ok.
    Therefore, it is important that the image you update has the same partition map as the image you upgrade from and the bootloader. However, as the partition map is generated for each build, there might be changes between two versions. It is therefore important to extract the partition map from the build that is flashed on the device so that the same map can be used in later builds.
    That can be done by copying the partitions.yml (I wrote the wrong filename last time, my apologies) into the project folder, and renaming it to pm_static.yml.
    Remo94 said:
    I take the app_update.bin file from the same build folder upload it on the lwm2m server and start the update.
     If I understand you correctly, you build the sample once, then flash it to the device, and start a FOTA update to the same image?
    Then all I mentioned above does not matter. Sorry for the confusion.
    To check if the problem is with the image or the FOTA process, could you do the following test:
    1. Flash the program as normal.
    2. In a command line, navigate to the build folder, then run the following commands:
    cd zephyr
    nrfjprog --program app_moved_test_update.hex
    That will write the update image to the secondary_image slot in flash.
    3. Reset the device.
    You should then see MCUBoot trying to update the firmware, similar to how it looked when you did it over LwM2M.
  •  If I understand you correctly, you build the sample once, then flash it to the device, and start a FOTA update to the same image?
    Exactly.
    I did these steps. And here is the result. No error but I also do not see any success. So did this work?
    *** Booting Zephyr OS build v2.1.99-ncs1-1145-g13dc96f83bab  ***
    [00:00:00.007,049] <inf> mcuboot: Starting bootloader
    [00:00:00.015,594] <inf> mcuboot: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x1
    [00:00:00.029,052] <inf> mcuboot: Boot source: none
    [00:00:00.036,346] <inf> mcuboot: Swap type: test
    [00:00:26.349,334] <inf> mcuboot: Bootloader chainload address offset: 0x10000
    [00:00:26.356,964] <inf> mcuboot: Jumping to the first image slot
     Yes, it does indeed look like it worked. As you are "upgrading" to the same application, we do not expect any change in behavior. But the fact that the bootloader spent some time (presumably swapping the images), followed by a successful boot of the application tells us that the upgrade was successful.
    That means that the image itself is OK and that MCUBoot is able to perform an upgrade if there is a valid image in the secondary slot.
    The question then becomes: Why are you not able to upgrade to the image when you download it?
    Could you send me your app_update.bin?
    In addition, I would like you to read out the flash of your device after the image has been downloaded (but preferably before mcuboot tries to boot it). You can read out the flash using nrfjprog:
    nrfjprog --readcode readout.hex
    Finally, I would also like to see the partitions.yml file from the build you used when you read out the flash.
  • app_update.bin
    app_update.bin
    partitions.yml:
    EMPTY_0:
      address: 0xc000
      placement:
        before:
        - mcuboot_pad
    app:
      address: 0x1c200
      region: flash_primary
    mcuboot:
      address: 0x0
      placement:
        before:
        - mcuboot_primary
    mcuboot_pad:
      address: 0x10000
      placement:
        align:
          start: 0x8000
        before:
        - mcuboot_primary_app
    mcuboot_primary:
      address: 0x10000
      orig_span: &id001
      - spm
      - mcuboot_pad
      - app
      sharers: 0x1
      span: *id001
    mcuboot_primary_app:
      address: 0x10200
      orig_span: &id002
      - app
      - spm
      span: *id002
    mcuboot_secondary:
      address: 0x87000
      placement:
        after:
        - mcuboot_primary
        align:
          start: 0x1000
      share_size:
      - mcuboot_primary
    otp:
      address: 0xff8108
      region: otp
    settings_storage:
      address: 0xfe000
      placement:
        after:
        - app
    spm:
      address: 0x10200
      inside:
      placement:
        before:
        - app
    readout.hex:
    readout.hex
    I hope this I did not forgot anything. Thank you!
  • Had the FOTA image been downloaded to the device when you read out the flash?
    If so, I am not able to find the magic which indicates the start of the header of the image.
