Sample LWM2M client using for FOTA
Hi
So I tried to use the lwm2m sample client (nrf\samples\nrf9160\lwm2m_client) for FOTA upgrades. I do get a connection to my plattform. When I start the update I do get the following in a loop.
m[8D[J[1;32muart:~$ [m[8D[J[00:00:50.592,498] [1;31m<err> net_lwm2m_engine: Unknown IP address family:0
[0m[1;32muart:~$ [m[8D[J[00:00:50.592,529] [0m<dbg> net_lwm2m_engine.lwm2m_udp_receive: checking for reply from [unk]
[0m[1;32muart:~$ [m[8D[J[00:00:50.592,590] [0m<dbg> net_lwm2m_engine.handle_request: No accept option given. Assume OMA TLV.
[0m[1;32muart:~$ [m[8D[J[00:00:50.592,681] [0m<dbg> net_lwm2m_engine.engine_add_observer: OBSERVER DUPLICATE 5/0/3(3) []
[0m[1;32muart:~$ [m[8D[J[00:00:50.921,600] [1;31m<err> net_lwm2m_engine: Unknown IP address family:0
[0m[1;32muart:~$ [m[8D[J[00:00:50.921,630] [0m<dbg> net_lwm2m_engine.lwm2m_udp_receive: checking for reply from [unk]
[0m[1;32muart:~$ [m[8D[J[00:00:50.921,661] [0m<dbg> net_lwm2m_engine.handle_request: No accept option given. Assume OMA TLV.
[0m[1;32muart:~$ [m[8D[J[00:00:50.921,752] [0m<dbg> net_lwm2m_obj_firmware.package_uri_write_cb: PACKAGE_URI WRITE:
[0m[1;32muart:~$ [m[8D[J[00:00:50.921,783] [0m<dbg> net_lwm2m_engine.lwm2m_notify_observer: NOTIFY EVENT 5/0/3
[0m[1;32muart:~$ [m[8D[J[00:00:50.921,783] [0m<dbg> net_lwm2m_obj_firmware.lwm2m_firmware_set_update_state: Update state = 0
[0m[1;32muart:~$ [m[8D[J[00:00:50.921,813] [0m<dbg> net_lwm2m_obj_firmware.lwm2m_firmware_set_update_result: Update result = 0
[0m[1;32muart:~$ [m[8D[J[00:00:50.921,875] [0m<dbg> net_lwm2m_engine.lwm2m_notify_observer: NOTIFY EVENT 5/0/3
[0m[1;32muart:~$ [m[8D[J[00:00:50.921,875] [0m<dbg> net_lwm2m_obj_firmware.lwm2m_firmware_set_update_state: Update state = 1
[0m[1;32muart:~$ [m[8D[J[00:00:50.922,027] [0m<dbg> net_lwm2m_engine.lwm2m_parse_peerinfo: Parse url:
[0m[1;32muart:~$ [m[8D[J[00:00:50.922,973] [0m<inf> net_lwm2m_obj_firmware_pull: Connecting to server
[0m[1;32muart:~$ [m[8D[J[1;32muart:~$ [m[8D[J[1;32muart:~$ [m[8D[J[00:00:51.517,486] [1;31m<err> net_lwm2m_engine: Unknown IP address family:0
[0m[1;32muart:~$ [m[8D[J[00:00:51.517,517] [0m<dbg> net_lwm2m_engine.lwm2m_udp_receive: checking for reply from [unk]
[0m[1;32muart:~$ [m[8D[J[00:00:51.517,578] [0m<dbg> net_lwm2m_engine.handle_request: No accept option given. Assume OMA TLV.
[0m[1;32muart:~$ [m[8D[J[00:00:51.570,526] [0m<dbg> net_lwm2m_engine.generate_notify_message: [MANUAL] NOTIFY MSG START: 5/0/3(3) token:'' [] ERR
[0m[1;32muart:~$ [m[8D[J[00:00:51.571,746] [0m<dbg> net_lwm2m_engine.generate_notify_message: NOTIFY MSG: SENT
[0m[1;32muart:~$ [m[8D[J[00:00:51.637,817] [1;31m<err> net_lwm2m_engine: Unknown IP address family:0
[0m[1;32muart:~$ [m[8D[J[00:00:51.637,817] [0m<dbg> net_lwm2m_engine.lwm2m_udp_receive: checking for reply from [unk]
[0m[1;32muart:~$ [m[8D[J[00:00:51.766,448] [1;31m<err> net_lwm2m_engine: Unknown IP address family:0
[0m[1;32muart:~$ [m[8D[J[00:00:51.766,479] [0m<dbg> net_lwm2m_engine.lwm2m_udp_receive: checking for reply from [unk]
[0m[1;32muart:~$ [m[8D[J[00:00:51.766,510] [0m<dbg> net_lwm2m_engine.notify_message_reply_cb: NOTIFY ACK type:2 code:2.4 reply_token:''
[0m[1;32muart:~$ [m[8D[J[00:00:51.766,601] [0m<dbg> net_lwm2m_engine.lwm2m_udp_receive: reply 0x20021b70 handled and removed[0m
Is the sample client made for FOTA? If not what is needed to upgrade the client to get it working? Is there anywhere a tutorial or something that will help me?
Kind regards.
  • Hi. and sorry for the late reply.
    Yes, the lwm2m_client sample should support FOTA.
    From your logs, it looks like the server is checking if the device is available for FOTA, which it is.
    The server then instructs the device to start the FOTA process, but it does not provide a URL to download the DFU image from.
    Didrik
  • Hi
    Thanks for your answer! I do now get the URI on my client. But I do get the following:
    [00:00:44.699,951] <inf> net_lwm2m_obj_firmware_pull: Connecting to server coap://.........
    [00:00:44.942,108] <err> net_lwm2m_obj_firmware_pull: Unexpected response from server: 4.0
    For info I did not paste the full URI but it is there. Do you know this error?
    Kind regards.
  • So ok now I am able to download the file. Now I get the following:
    [00:22:07.848,144] <dbg> net_lwm2m_obj_firmware.lwm2m_firmware_set_update_state: Update state = 3
    [00:22:07.848,175] <dbg> app_lwm2m_firmware.firmware_update_cb: Executing firmware update
    [00:22:07.848,175] <inf> app_lwm2m_firmware: Update Counter: current 0, update 1
    [00:22:07.848,724] <inf> app_lwm2m_firmware: Rebooting device
    *** Booting Zephyr OS build v2.1.99-ncs1-1145-g13dc96f83bab  ***
    [00:00:00.006,958] <inf> mcuboot: Starting bootloader
    [00:00:00.015,502] <inf> mcuboot: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x1
    [00:00:00.028,961] <inf> mcuboot: Boot source: none
    [00:00:00.036,285] <inf> mcuboot: Swap type: test
    [00:00:10.380,615] <err> mcuboot: Image in the secondary slot is not valid!
    [00:00:10.734,100] <inf> mcuboot: Bootloader chainload address offset: 0x10000
    [00:00:10.741,729] <inf> mcuboot: Jumping to the first image slot
    After reboot it states that the firmware update is failed. What can I do to get my app_update.bin valid?
  • It might be that the new version uses a different flash partitioning than the bootloader.
    Is the <build folder>/pm.config files the same in both the application that is flashed on the device and the application/version you try to upgrade to?
  • Sorry for my late answer.
    So I guess I am doing something wrong. I found the pm.config file in my build folder. But I have no pm.config file of my application. I take the app_update.bin file from the same build folder upload it on the lwm2m server and start the update. Do I have to do anything else?
    Edit: I do also not find any signal of version in my pm.config file.
    PM_MCUBOOT_ADDRESS=0x0
    PM_MCUBOOT_SIZE=0xc000
    PM_MCUBOOT_NAME=mcuboot
    PM_MCUBOOT_ID=0
    PM_0_LABEL=MCUBOOT
    PM_EMPTY_0_ADDRESS=0xc000
    PM_EMPTY_0_SIZE=0x4000
    PM_EMPTY_0_NAME=EMPTY_0
    PM_MCUBOOT_PAD_ADDRESS=0x10000
    PM_MCUBOOT_PAD_SIZE=0x200
    PM_MCUBOOT_PAD_NAME=mcuboot_pad
    PM_MCUBOOT_PAD_ID=1
    PM_1_LABEL=MCUBOOT_PAD
    PM_MCUBOOT_PRIMARY_ADDRESS=0x10000
    PM_MCUBOOT_PRIMARY_SIZE=0x77000
    PM_MCUBOOT_PRIMARY_NAME=mcuboot_primary
    PM_MCUBOOT_PRIMARY_ID=2
    PM_2_LABEL=MCUBOOT_PRIMARY
    PM_MCUBOOT_PRIMARY_SPAN="spm app mcuboot_pad"
    PM_MCUBOOT_PRIMARY_APP_ADDRESS=0x10200
    PM_MCUBOOT_PRIMARY_APP_SIZE=0x76e00
    PM_MCUBOOT_PRIMARY_APP_NAME=mcuboot_primary_app
    PM_MCUBOOT_PRIMARY_APP_ID=3
    PM_3_LABEL=MCUBOOT_PRIMARY_APP
    PM_MCUBOOT_PRIMARY_APP_SPAN="app spm"
    PM_SPM_ADDRESS=0x10200
    PM_SPM_SIZE=0xc000
    PM_SPM_NAME=spm
    PM_SPM_ID=4
    PM_4_LABEL=SPM
    PM_APP_ADDRESS=0x1c200
    PM_APP_SIZE=0x6ae00
    PM_APP_NAME=app
    PM_APP_ID=5
    PM_5_LABEL=APP
    PM_MCUBOOT_SECONDARY_ADDRESS=0x87000
    PM_MCUBOOT_SECONDARY_SIZE=0x77000
    PM_MCUBOOT_SECONDARY_NAME=mcuboot_secondary
    PM_MCUBOOT_SECONDARY_ID=6
    PM_6_LABEL=MCUBOOT_SECONDARY
    PM_SETTINGS_STORAGE_ADDRESS=0xfe000
    PM_SETTINGS_STORAGE_SIZE=0x2000
    PM_SETTINGS_STORAGE_NAME=settings_storage
    PM_SETTINGS_STORAGE_ID=7
    PM_7_LABEL=SETTINGS_STORAGE
    PM_OTP_ADDRESS=0xff8108
    PM_OTP_SIZE=0x2f4
    PM_OTP_NAME=otp
    PM_NUM=8
    PM_ALL_BY_SIZE="mcuboot_pad otp settings_storage EMPTY_0 mcuboot spm app mcuboot_primary_app mcuboot_secondary mcuboot_primary"
