Size restriction of composition data status message
the mesh profile spec 4.2.1, for the composition data page 0 states: "The size of the state shall not exceed the maximum useful access payload size". The maximum payload size seems like it is 380 bytes according to section 3.7.3.
When I flash the light lightness example, it uses 9 SIG models for the first element. So I expect that it could use around 7 elements for all other elements (excluding configuration server and health server). That means there is a restriction of around 20 elements with a light lightness server in a node.
Is this a fixed restriction so that I cannot have more elements/models in my node or is it simply the amount that can be reported using the composition data page 0? However, I expect that most clients would have problems dealing with a node that does not report all elements and models using the composition data.
Marius
