Button handling not working using bsp
Hi. I have a problem with my NRF52840 Dongle. When using BSP driven button. I've tried to use some SDK precompiled examples - it doesn't work. Neither with ble_peripheral, nor ZigBee or Thread examples. Then I tried this code:
#include "boards.h"
int main(){
    bsp_board_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS);
    while (true)
        if (bsp_board_button_state_get(BSP_BUTTON_0)){
            bsp_board_led_invert(BSP_BOARD_LED_2);
 and it worked as expected.
But the following code, which is intended to perform the same action:
#include "boards.h"
#include "app_timer.h"
#include "app_button.h"
static void buttons_handler(uint8_t pin, uint8_t action)
    if (pin == BSP_BOARD_BUTTON_0){
        if (action == APP_BUTTON_PUSH){
            bsp_board_led_invert(BSP_BOARD_LED_0);
    app_timer_init();
    static app_button_cfg_t buttons [] = {
        {BSP_BOARD_BUTTON_0, false, BUTTON_PULL, buttons_handler}
    app_button_init(buttons, ARRAY_SIZE(buttons), APP_TIMER_TICKS(50));
    app_button_enable();
 doesn't work.
This code works well:
#include <stdbool.h>
#include <stdint.h>
#include "boards.h"
#include "bsp.h"
#include "nordic_common.h"
void bsp_evt_handler(bsp_event_t evt)
    switch (evt)
        case BSP_EVENT_KEY_0:
            return;
int main(void){
    NRF_CLOCK->LFCLKSRC            = (CLOCK_LFCLKSRC_SRC_Xtal << CLOCK_LFCLKSRC_SRC_Pos);
    NRF_CLOCK->TASKS_LFCLKSTART    = 1;
    app_timer_init();
    bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_evt_handler);
    while (true)
But the same construction in examples doesn't work (Ble blinky, for example).
I need some help because I don't know, where to look for some kind of solution.
    Which board file examples did you try to flash the dongle with, PCA10059?
     doesn't work.
    Exactly what do you mean by this? Is the event handler called? What is returned by app_button_init()?
    regards
    Jared
  • Thanks for your reply!
    Yes, I tried PCA10059. I mean button events are not handled. When I press a button on my dongle nothing happens, but the program seems running - it can connect to other devices automatically for example, or just blink.
    I can't tell you what app_button_init() returns because I don't have a debugger.
    You cannot use the BSP_BOARD_BUTTON_x defines with app_button. App_button expects the GPIO pin number as input, while the BSP_BOARD_BUTTON_x defines are defined from 0-7:
    #define BSP_BOARD_BUTTON_0 0
    #define BSP_BOARD_BUTTON_1 1
    #define BSP_BOARD_BUTTON_2 2
    #define BSP_BOARD_BUTTON_3 3
    #define BSP_BOARD_BUTTON_4 4
    #define BSP_BOARD_BUTTON_5 5
    #define BSP_BOARD_BUTTON_6 6
    #define BSP_BOARD_BUTTON_7 7
    You can use the BUTTON_x or the BSP_BUTTON_x defines from the board header file (these are taken from pca10056.h):
    #define BUTTON_1       11
    #define BUTTON_2       12
    #define BUTTON_3       24
    #define BUTTON_4       25
    #define BSP_BUTTON_0   BUTTON_1
    #define BSP_BUTTON_1   BUTTON_2
    #define BSP_BUTTON_2   BUTTON_3
    #define BSP_BUTTON_3   BUTTON_4
    Jørgen
  • Hi! Thanks. That helped to fix the issue with small parts of code above. But, unfortunately, I still don't know what should I do with Zigbee example. Here are some parts of init code from my modified light_switch. But the same situation is with other examples.
    #include "zboss_api.h"
    #include "zb_mem_config_custom.h"
    #include "zb_error_handler.h"
    #include "zigbee_helpers.h"
    #include "bsp.h"
    #include "boards.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    static void buttons_handler(bsp_event_t evt)
        zb_ret_t zb_err_code;
        zb_uint32_t button;
        bsp_board_led_invert(BSP_BOARD_LED_1);
        if (m_device_ctx.bulb_params.short_addr == 0xFFFF)
            /* No bulb found yet. */
            bsp_board_led_off(BULB_FOUND_LED);
            return;
        switch(evt)
                zb_err_code = zb_buf_get_out_delayed_ext(light_switch_send_on_off, ZB_FALSE, 0);
                button = BSP_BUTTON_0;
                NRF_LOG_INFO("Unhandled BSP Event received: %d", evt);
                return;
    /**@brief Function for initializing LEDs and buttons.
    static zb_void_t leds_buttons_init(void)
        ret_code_t error_code;
        /* Initialize LEDs and buttons - use BSP to control them. */
        error_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, buttons_handler);
        APP_ERROR_CHECK(error_code);
        /* By default the bsp_init attaches BSP_KEY_EVENTS_{0-4} to the PUSH events of the corresponding buttons. */
        bsp_board_leds_off();
        zb_ieee_addr_t ieee_addr;
        /* Initialize timers, loging system and GPIOs. */
        timers_init();
        log_init();
        leds_buttons_init();
        /* Set Zigbee stack logging level and traffic dump subsystem. */
        ZB_SET_TRACE_LEVEL(ZIGBEE_TRACE_LEVEL);
        ZB_SET_TRACE_MASK(ZIGBEE_TRACE_MASK);
        ZB_SET_TRAF_DUMP_OFF();
        /* Initialize Zigbee stack. */
        ZB_INIT("light_switch");
        /* Set device address to the value read from FICR registers. */
        zb_osif_get_ieee_eui64(ieee_addr);
        zb_set_long_address(ieee_addr);
        zb_set_network_ed_role(IEEE_CHANNEL_MASK);
        zigbee_erase_persistent_storage(ERASE_PERSISTENT_CONFIG);
        zb_set_ed_timeout(ED_AGING_TIMEOUT_64MIN);
        zb_set_keepalive_timeout(ZB_MILLISECONDS_TO_BEACON_INTERVAL(3000));
        // sleepy_device_setup();
        /* Initialize application context structure. */
        UNUSED_RETURN_VALUE(ZB_MEMSET(&m_device_ctx, 0, sizeof(light_switch_ctx_t)));
        /* Set default bulb short_addr. */
        m_device_ctx.bulb_params.short_addr = 0xFFFF;
        /* Register dimmer switch device context (endpoints). */
        ZB_AF_REGISTER_DEVICE_CTX(&dimmer_switch_ctx);
        /** Start Zigbee Stack. */
        zb_err_code = zboss_start_no_autostart();
        ZB_ERROR_CHECK(zb_err_code);
        // bsp_board_led_on(BSP_BOARD_LED_3);
        while(1)
            zboss_main_loop_iteration();
            UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
    It's supposed that at least led would invert on button press, but nothing happens at all.
  • I modified the Zigbee light_switch example with your buttons_handler code, and LED2 (BSP_BOARD_LED_1) is toggling on every button press in my test. LED3 (BSP_BOARD_LED_2) does not toggle, as the application enters and returns from the button_handler in this section:
        return;
    If I remove this or comment out the return, LED3 also toggles.
