Is this a bug in the nrf_ble_gatt in SDK 16 ?
I found some thing not seems to be right in SDK 16.  I wonder if this is intentional or a bug.  Bluetooth 5 max MTU can be up to 512 bytes.  I found the definitions in the structures bellow that MTU size is uint16_t but data length is uint8_t.  This seems not rights also nrf_ble_gatt sets a hardcoded max data length to 251.  Which is Bluetooth 4.2 max data length.  That too is bad.  So how did the Bluetooth 5 throughput test demo able to set data length to 512 bytes when it is hard coded in nrf_ble_gatt to 251 ?
Data length defined as uint8_t in nrf_ble_gatt.h which is max at 255.  So cannot use 512 bytes of Bluetooth 5.
/**@brief   GATT information for each connection. */
typedef struct
    uint16_t att_mtu_desired;               //!< Requested ATT_MTU size (in bytes).
    uint16_t att_mtu_effective;             //!< Effective ATT_MTU size (in bytes).
    bool     att_mtu_exchange_pending;      //!< Indicates that an ATT_MTU exchange request is pending (the call to @ref sd_ble_gattc_exchange_mtu_request returned @ref NRF_ERROR_BUSY).
    bool     att_mtu_exchange_requested;    //!< Indicates that an ATT_MTU exchange request was made.
#if !defined (S112) && !defined(S312)
    uint8_t  data_length_desired;           //!< Desired data length (in bytes).
    uint8_t  data_length_effective;         //!< Requested data length (in bytes).
#endif // !defined (S112) && !defined(S312)
} nrf_ble_gatt_link_t;
/**@brief   GATT structure that contains status information for the GATT module. */
struct nrf_ble_gatt_s
    uint16_t                   att_mtu_desired_periph;          //!< Requested ATT_MTU size for the next peripheral connection that is established.
    uint16_t                   att_mtu_desired_central;         //!< Requested ATT_MTU size for the next central connection that is established.
    uint8_t                    data_length;                     //!< Data length to use for the next connection that is established.
    nrf_ble_gatt_link_t        links[NRF_BLE_GATT_LINK_COUNT];  //!< GATT related information for all active connections.
    nrf_ble_gatt_evt_handler_t evt_handler;                     //!< GATT event handler.
Data length is hardcoded inside nrf_ble_gatt.c
#define BLE_GAP_DATA_LENGTH_DEFAULT     27          //!< The stack's default data length.
#define BLE_GAP_DATA_LENGTH_MAX         251         //!< Maximum data length.
ret_code_t nrf_ble_gatt_data_length_set(nrf_ble_gatt_t * p_gatt,
                                        uint16_t         conn_handle,
                                        uint8_t          data_length)
    if (p_gatt == NULL)
        return NRF_ERROR_NULL;
    // Check early to avoid requesting an invalid data length for upcoming connections.
    if (   (data_length > BLE_GAP_DATA_LENGTH_MAX)
        || (data_length < BLE_GAP_DATA_LENGTH_DEFAULT))
        return NRF_ERROR_INVALID_PARAM;
    if (conn_handle == BLE_CONN_HANDLE_INVALID)
        // Save value and request upon connection.
        p_gatt->data_length = data_length;
        return NRF_SUCCESS;
    if (conn_handle >= NRF_BLE_GATT_LINK_COUNT)
    // Request data length on existing link.
    p_gatt->links[conn_handle].data_length_desired = data_length;
    return data_length_update(conn_handle, data_length);
