While trying to utilize the TEMP peripheral today, I found that after the event handler returns a single reading the application does not continue to run. Any actions that should occur after a temperature measurement is taken are not performed however the application error handler is never triggered. I originally thought I might be running into an interrupt priority issue but raising and lower the priority had no effect.
I've created a separate project that only takes a temperature measurement and logs the value and am met with the same behavior, one measurement is taken, printed to the console, and nothing else executes.
I've included the code for reference below.
volatile int32_t nrf_temp {0};
void init_log()
void nrf_temp_data_handler(int32_t raw_temperature)
int32_t core_temp = nrfx_temp_calculate(raw_temperature);
uint32_t temp_diff = std::abs(core_temp - nrf_temp);
if (temp_diff >= 1000)
nrf_temp = core_temp;
NRF_LOG_INFO("%d", core_temp);
nrfx_temp_uninit();
void temp_init()
const nrfx_temp_config_t config { .interrupt_priority = 3 };
nrfx_temp_init(&config, nrf_temp_data_handler);
void get_nrf_temperature()
temp_init();
nrfx_temp_measure();
// Get temperature every 5 minutes.
init_log();
while (1)
get_nrf_temperature();
nrf_delay_ms(5000);
NRF_LOG_FLUSH();
Thanks.
