how to config the parameter of GZP_TX_RX_TRANS_DELAY?
i am useing nRF51822 pairing with nRF24lu1 over GZLL protocol now, is there someone have the experience on how to config the parameter of GZP_TX_RX_TRANS_DELAY in function gzp_tick_sleep_rx_periods(GZP_TX_RX_TRANS_DELAY);
For Example why is the GZP_TX_RX_TRANS_DELAY parameter set to 10 – this line of code causes a 20msec delay
below is the nRF51822 side code:
static gzp_tx_rx_trans_result_t gzp_tx_rx_transaction(const uint8_t *tx_packet, uint8_t tx_length, uint8_t *rx_dst, uint32_t *rx_length, uint8_t pipe) { ... nrf_gzp_flush_rx_fifo(pipe);
retval = GZP_TX_RX_FAILED_TO_SEND;
(void)nrf_gzll_disable();
while(nrf_gzll_is_enabled())
temp_lifetime = nrf_gzll_get_sync_lifetime();
(void)nrf_gzll_set_sync_lifetime(GZP_TX_RX_TRANS_DELAY * 3); // 3 = RXPERIOD * 2 + margin
(void)nrf_gzll_enable();
tx_packet_success = gzp_tx_packet(tx_packet, tx_length, pipe);
if(tx_packet_success)
    retval = GZP_TX_RX_NO_RESPONSE;
    fetch_packet[0] = (uint8_t)GZP_CMD_FETCH_RESP;
    ***gzp_tick_sleep_rx_periods(GZP_TX_RX_TRANS_DELAY);***
    tx_packet_success = gzp_tx_packet(fetch_packet,GZP_CMD_FETCH_RESP_PAYLOAD_LENGTH, pipe);
        if(nrf_gzll_get_rx_fifo_packet_count(pipe))
(void)nrf_gzll_set_sync_lifetime(temp_lifetime);
return retval;
