when i use that message to pass some data value to nordic device, in generic onoff server. i face problem that when i try to send the message to nordic device, it sends again again the message. In console log appear as resending the message in access layer. After 3 to 4 try it get canceled with a error message. I use docklight to check receive message in nordic device and it verify that it receive the message. i am using the nrf5 sdk 540 device to test.
message parameter contain [int8] array
import Foundation public struct GenericConfigSet: GenericMessage, TransactionMessage, TransitionMessage { public static let opCode: UInt32 = 0x8206 // public static let responseType: StaticMeshMessage.Type = GenericLevelStatus.self public var tid: UInt8! public var parameters: Data? { let data = Data() + byteArray + tid if let transitionTime = transitionTime, let delay = delay { return data + transitionTime.rawValue + delay } else { return data } } /// The target value of the Generic Level state. public let byteArray: [UInt8] public let transitionTime: TransitionTime? public let delay: UInt8? public init(parameter: [UInt8]) { self.byteArray = parameter self.transitionTime = nil self.delay = nil } /// - parameters: /// - transitionTime: The time that an element will take to transition /// to the target state from the present state. /// - delay: Message execution delay in 5 millisecond steps. public init(parameter: [UInt8], transitionTime: TransitionTime, delay: UInt8) { self.byteArray = parameter self.transitionTime = transitionTime self.delay = delay } public init?(parameters: Data) { print("\n call by system \n") guard parameters.count == 3 || parameters.count == 5 else { return nil } byteArray = [parameters[0]] //check for any error later. tid = parameters[2] if parameters.count == 5 { transitionTime = TransitionTime(rawValue: parameters[3]) delay = parameters[4] } else { transitionTime = nil delay = nil } } }
