I get long range demo code for 52840 on the web:
and modify the code to test the 52833 long range feature;
52833 long range peripheral demo.zip
MAINLY code:
static void advertising_init(void) { uint32_t err_code; ble_advertising_init_t init; memset(&init, 0, sizeof(init)); init.advdata.name_type = BLE_ADVDATA_FULL_NAME; init.advdata.include_appearance = false; + init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;//BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE init.srdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]); init.srdata.uuids_complete.p_uuids = m_adv_uuids; init.config.ble_adv_fast_enabled = true; init.config.ble_adv_fast_interval = APP_ADV_INTERVAL; init.config.ble_adv_fast_timeout = APP_ADV_DURATION; + init.config.ble_adv_primary_phy = BLE_GAP_PHY_CODED; + init.config.ble_adv_secondary_phy = BLE_GAP_PHY_CODED; + init.config.ble_adv_extended_enabled = true; init.evt_handler = on_adv_evt; err_code = ble_advertising_init(&m_advertising, &init); APP_ERROR_CHECK(err_code); ble_advertising_conn_cfg_tag_set(&m_advertising, APP_BLE_CONN_CFG_TAG); } ******************* // Copy advertising data. if (!p_advertising->initialized) { p_advertising->adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET; } p_advertising->adv_data.adv_data.p_data = p_advertising->enc_advdata[0]; p_advertising->adv_data.adv_data.len = adv_set_data_size_max_get(p_advertising); ret = ble_advdata_encode(&p_init->advdata, p_advertising->enc_advdata[0], &p_advertising->adv_data.adv_data.len); VERIFY_SUCCESS(ret); + p_advertising->adv_data.scan_rsp_data.p_data = NULL; + p_advertising->adv_data.scan_rsp_data.len = 0; -// p_advertising->adv_data.scan_rsp_data.p_data = p_advertising->enc_scan_rsp_data[0]; -// p_advertising->adv_data.scan_rsp_data.len = adv_set_data_size_max_get(p_advertising); -// ret = ble_advdata_encode(&p_init->srdata, -// p_advertising->adv_data.scan_rsp_data.p_data, -// &p_advertising->adv_data.scan_rsp_data.len); -// VERIFY_SUCCESS(ret); *************** static void advertising_start(void) { uint32_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST); APP_ERROR_CHECK(err_code); //Optional: Change output power + err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, m_advertising.adv_handle, 8); + APP_ERROR_CHECK(err_code); } *************
My question is: WHY IT cannot be connected to the long-range-DK 52840? (THE led1 is always flicking!!)
WHAT IS THE PROBLEM FOR THE LONG RANGE TEST ON 52833 DK????
