How does 52832 sdk16 change the button state
Hello Nordic team,
I'm getting started with BLE, using the 52832 SDK16 HID mouse example. In the example, clicking the button only moves 5 pixels. How can I move the cursor continuously. I tried to modify the example descriptor as a gamepad and found that clicking the button will only send data once. The button has been pressed all the time, and the data cannot be updated in real time. How to solve it.
thank you for your support.
    The example generates only one event per time a button is pressed. Which means that you would have to check if the button is still pressed if you want the cursor to keep moving. One way is by calling bsp_button_is_pressed() after a button pressed event is generated. You could then call mouse_movement_send() as long as bsp_button_is_pressed() returns true for that button. Just make sure that you don't do it in interrupt context as it might interfere with Softdevice operations. I suggest that you rather set a flag in interrupt context after the button has been pressed and then check the flag in a loop in main context. Probably not the most elegant solution, but it should work Slight smile
    regards
    Jared
  • Thank you for taking the time to answer. I tried to use app_button, which seems to conflict with the BSP button module. I ca n’t find how to close the BSP button alone. When I commented out buttons_leds_init (& erase_bonds); or err_code = bsp_init (BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler) ; Changed to err_code = bsp_init (BSP_INIT_LEDS, bsp_event_handler); can work very well. And when I disconnect the power of nRF52 DK and connect it again, windows10 can't connect, repeatedly disconnect, the android device can click to connect again.
    Try to modify sdk.config.h / BSP_BTN_BLE_ENABLED to 0, but it doesn't seem to work
    (Sorry, my English is not good, I need an interpreter :D
  • Have you tried using the debugger to see what happens and if the application asserts?
     I'm not sure what you mean by this.
  • Thanks for your suggestions, the problem has been solved.
