We're bringing up custom hardware using SiT1532 MEMS 32kHz oscillator. This part outputs a low swing single ended clock source (300mV +/-55mV p-p). I'm struggling to find the appropriate way to configure this when using softdevice.
sdk_config.h lists external low swing external source options for the clock driver, but NRF_SDH_CLOCK_LF_SRC has no such option. When trying to use the 131073 value listed for NRFX_CLOCK_CONFIG_LF_SRC, the compiler throws an error, apparently softdevice can only accept an 8 bit value, even though the LFCLKSRC register documents setting bit 17 for external sources instead of Xtals.
If I use the clock driver, I'm able to successfully start the clock and measure a good waveform. But when setting NRF_SDH_CLOCK_LF_SRC to Xtal, my call to nrf_sdh_enable_request() fails with NRF_ERROR_INVALID_PARAM, and it looks like it's propagating up from sd_softdevice_enable().
What's the right way to use an external source with softdevice? We're on version 16 of the SDK with S140, nRF52840.
Steve
