Different capabilities on BLE peripheral device with multi-link, multi-peripheral and multi-role features
I am using nRF52840, SDK_16.0.0, SoftDevice S140 V7.0.1 and Segger for flashing the image. I am using ‘ble_app_blinky’.
Initially I was in assumption that once BLE peripheral connected to a master, will stop advertisement and cannot connect to another masters. After going through BLE Core_4.2 standards I read below statements and gone through couple of Nordic examples like Multi-link, Multi-Peripheral and Multi-Role examples.
“Within a physical channel, a physical link is formed between a master and each slave. Direct physical links between slaves in a piconet are not supported.
Slaves are permitted to have physical links to more than one master at a time. A device is permitted to be master and slave at the same time. Role changes between a master and slave device are not supported at this time.”
My further queries are with respect to Core_4.2 (Page : 173). I need inputs from the BLE experts like you rather than googling and getting different answers and having wrong interpretations.
1) “Direct physical links between slaves in a piconet are not supported.”
       This means two Slaves cannot connect and communicate directly. But whether two slaves can connect to same master and exchange data. Similar to ZigBee with Star topology. Where once slave can communicate to other slave within network via Master or Router.
2) “Slaves are permitted to have physical links to more than one master at a time.”
    This means same slave can connect to different Masters. Even after connection, still slave can do Advertisement (Ex: ble_app_multiperipheral). In case of nRF52832/40, how may max masters can be connected by single slave.
3) “A device is permitted to be master and slave at the same time.”
      As a Master whether it can connect to multiple slave devices and the same device as slave whether it can connect to multiple masters.
4) “Role changes between a master and slave device are not supported at this time.”
     Bit confused about this statement and above statement. If same device can act as Master and Slave at same time, then what does Role change is not supported.
5) In below link I am seeing the statement “least 1 Peripheral + 8 Central + Broadcaster roles in parallel”
    https://devzone.nordicsemi.com/f/nordic-q-a/24140/can-i-use-ble-connection-and-advertising-at-the-same-time
    Whether same device will act as 8 Centrals. To my understanding there will be only one Central in same network. Please correct if I am wrong.
Please let me know your inputs for each point separately, so that it will be clear.
Thanks & Regards
Vishnu Beema
