how to use rtc in nrf52840 dongle
Timer A with a 10-minute interval, timer B with a 4-hour interval, and timer C with a 10-second interval are required, and A and B should also run out of time in low power mode. Timer C only needs to flow for 10 seconds and remains (while generating a BLE signal) while the CPU is fully awake.
If I use softdevice, it says I can't use RTC0, is this right?
Then can I use timer A as RTC1 and timer B as RTC2?
Can I use two RTCs with different scale values?
I understand that APP_TIMER uses RTC1. Then should I not use APP_TIMER in my case?
Can I use TIMER using HFCLK for Timer C?
