NERF52832 having both beacon transmitter and receiver in a single chip
I want to have a single device that can both transmit and receive beacon packets using nrf52832.
Project Idea
Need to identify RSSI level of beacons around a device while also advertising itself as-well
Help required
1) Is it possible to realise the above in a single nrf52832, if not which ic would be better?
2) Any example code/documentation which explains the same
  • It would have been a very comprehensive SDK if it should include example code for every customer's use-case.
    To save you some work, I have created an example combining the scanning from ble_app_beacon_c and advertising from ble_app_beacon example. It will report any advertising packet received, not just iBeacons. You must do the work to parse the advertising data to get the relevant packets for your use-case.
    ble_app_beacon_scanner_advertiser_SDK16.0.0.zip
    Jørgen
    I know this topic is old, and doesn't use the same SDK I'm using (17.0.2) but I'm very interested in the posted code. When compiling I am getting the following error:
    Output/Release/Obj/ble_app_blinky_c_pca10056_s140/ses_startup_nrf_common.o: in function `InitializeUserMemorySections'
    How could I solve this? I intend to read the advertising from nearby devices, and retransmit these advertising with a higher power on the tx.
    Furthermore, I noticed that the code scans, but does not print or store these advertising, what could I change in the code to accomplish what I intend? Thank you very much!
  • Output / Release / Obj / ble_app_blinky_c_pca10056_s140 / ses_startup_nrf_common.o: na função `InitializeUserMemorySections '
    I've already solved this error and I'm running the application. But I still haven't been able to print the received advertising in the log, I just print the advertising address as the original code. How could I do this? I would like to print the advertising received and also retransmit it, could you help me?
  • What code have you added to log the advertising packet? And to retransmit it? It should just be a matter of extracting the data from the received package, and apply it to the current advertising.
    You may get faster and better help if you post a new ticket with your questions, instead of posting in an old, slightly related ticket.
