AGPS and PSM
Hi
Looking at the AGPS sample code, it seems GPS/LTE is turned on and off using AT commands (AT+CFUN=x, x in {20, 21, 31}).
Do you recommend NOT using PSM when using AGPS?
Tron
  • Hi.
    The gps sample was originally created with only GPS in mind. It was later expanded when we added A-GPS support.
    That is why the sample only uses GPS, and not LTE (more than necessary for A-GPS). Another consideration to factor in is that the sample is not guaranteed to be granted PSM, and can therefore not rely on PSM to get enough run-time for the GPS.
    That is no longer necessary, with the improvements to the modem, but the sample is still meant to be as basic as possible.
    I would probably enable PSM after downloading the A-GPS data, but there should not be a problem using PSM with A-GPS.
    However, we have found that the SUPL library is more stable if the GPS is turned off before the SUPL session is started.
    This would make the following order of events: Start GPS -> Get A-GPS data request -> Stop GPS (using socket interface) -> Start SUPL session -> SUPL session ends -> Enable PSM -> Start GPS
    But, things could be done in other orders as well.
    Didrik
