Queries on FDS records
I am using nRF52840, SDK_16.0.0, SoftDevice S140 V7.0.1 and Segger for flashing the image. I am using ‘ble_app_blinky’.
1) Do we need to call fds_record_close(). As per below statement in below link. I am bit confused with the statement and fds example code. In example  fds_record_update() is called after fds_record_close(). Once closed, even to update do we need to open.
                “So if you need to access the data after closing the record, you must open it again.”
                https://infocenter.nordicsemi.com/index.jsp?topic=%2Fsdk_nrf5_v16.0.0%2Flib_fds_usage.html&anchor=lib_fds_usage_retrieve
2) As per below statement do I need to call fds_init() after ble_stack_init() as we have SoftDevice. But I am able to call fds_init() before SoftDevice Initilization.
           “Before initializing FDS, you must initialize the SoftDevice and register a callback handler to handle FDS events.”
 https://infocenter.nordicsemi.com/index.jsp?topic=%2Fsdk_nrf5_v16.0.0%2Flib_fds_format.html
3) Once I receive FDS_ERR_NO_SPACE_IN_FLASH, whether can I call fds_gc() directly.
a) (Or) Before calling garbage collection, do I need to close the record.
b) Also do I need to delete record fds_record_delete() before initiating garbage collection.
4) Assume I have 4 records and I am updating one record very frequently and received  FDS_ERR_NO_SPACE_IN_FLASH. Now if I do garbage collection, will it erase other 3 records.
a) Assume I keep updating the record. Once there is no space and if I want to call garbage collection, what will happen to last updated record value. After reset, I need to get latest value for all record. Whether it be taken backup before erasing the record.
Thanks & Regards
Vishnu Beema
