I am trying to implement energy efficient(batt powered) application for nrf9160, using UDP/DTLS/LWM2M as comm stack. Got "hello world" working, but now I am really confused about many details. Hope you can help me.
Question 1: Operator NAT/firewall rules and NRF9160 DTLS implementation
It looks like operator networks loose UDP port rules about after 1 minute of silence. This essentially means that UDP port number changes between consecutive packets sent from device to server if communications happens for example in every 10 minutes. This again means that DTLS connection would need to be resumed for it to work. It looks like resumption does not work in NRF or is not implemented at all? Effect is dramatic, you have to either ping server in <60s intervals or go through connection failure+re-register cycle every time you send anything.
Am I missing something here or how do people in general make things work? This ruins the whole idea of power save modes and LWM2M benefits. Is the only workaround to use MBED TLS stack instead?
Question 2: It looks like DTLS connection(to LWM2M bootstrap server) always ends to TLS ALERT sent by nrf91. Any idea why? Is this a feature? Other clients do not do that.
Question 3: Zephyr does not support QUEUE mode. If I understood the LWM2M spec correctly, QUEUE mode is exactly what low power NB-IoT application needs, but zephyr LWM2M stack does not support it. Do you have any idea how Nordic users tend to solve this? Implement queues as server side application on top of LWM2M? Use different LWM2M client?
Probably not the easiest questions and not all directly in Nordics domain, but I hope that you have some ideas how to make actual production quality app using NRF91. Thanks.
