UARTE power consumption after shutdown
We've been hunting down an issue there when we call nrf_drv_uart_uninit() we get a high static current which indicates that a clock or peripheral is being left on.
After some work I discovered that:
    nrf_drv_uart_uninit(&m_uart);
      *(volatile uint32_t *)0x40002FFC = 0;
  *(volatile uint32_t *)0x40002FFC;
  *(volatile uint32_t *)0x40002FFC = 1;
Fixes the issue- (I eventually found it from this post:
https://devzone.nordicsemi.com/f/nordic-q-a/53121/uart-low-power-shutdown-issue
However when I check the latest errata (2.0) there is no issue 89. These registers aren't documented anywhere and I would like to know if this bug still exists and also what these registers actually do.
Needless to say the excess current is significant in our application and I would have hoped that the driver did the right thing - clearly it does not. Are you going to fix this in an upcoming SDK?
