nrf52832 sleep mode else if (DMP_acq == 0) { app_timer_start(m_timer, APP_TIMER_TICKS(1000), NULL); // timer one shoot - events will wake up the sensor // Put the CPU to sleep until an interrupt is detected.
I have develop an application using the nrf52832 combined wit the ICM20948 sensor.
The application use ESB communication between peripheral and central.  I have solder 10 ohm resistor between the nrf52 board  and the nominal 3V , and another one between the ICM20948 board and  the 3 V supply.
When the ICM is not in used,  I want to put the nrf52 in sleep mode for one second.  The nrf52 then wake up and send the battery level to the central to keep communication going and also pickup new instruction from the returning acknowledge.  This is the portion of the code use for the standby :
            // Put the CPU to sleep until an interrupt is detected.   (data or timer)
            // Make sure any pending events are cleared
            __SEV();
            __WFE();
            // Enter System ON sleep mode
            __WFE();
When in standby, I measure about 47 mV across the nrf52 10 ohm resistor. That would give about 4.7 mA. The ICM chip is almost at 0 mA.     Number goes up approx to 7.5mA for the nrf52 board and 5 mA for the ICM board (12.5 mA) when sampling values at 56 Hz.
I suspect that I am doing something wrong. I would expect low uA value when the nrf52 is in standby, no sampling going on, using the above code .
I have seen a post with the following calculation:
System ON, no RAM retention + RTC + LFRC = 1.2uA + 0.1uA + 0.6uA = 1.9uA
I have RTC and LFRC, working for timestamp and +,  nrf_clock for ESB
 What am I doing wrong ?
(Note : Not sure what is no ram retention, should I clear the memory before going to sleep ?)
Thanks you in advance for your help.  It's truly appreciated.
  • Sorry for the title.   I have search how to edit the title and the text but did not find how...
     No worries. I don't think it is possible.
    Where do you set DMP_acq = 1?
    First of all, What do you use to measure the voltage over the serial resistor? If you use a multimeter that may be quite inaccurate, because the current consumption is not constant. BLE will typically cause very short current spikes that are quite tall. Multimeters hande these spikes very differently.
    As you can see in the attached screenshot from the Power Profiler Kit, using nRF Connect for Desktop -> Power Profiler:
    You can see that the spikes are at ~10mA, but the average current consumption for the entire window is 1.073mA.
    I suspect that you are trying to implement your own sleep logic using timers and stuff. I don't know how you did that implementation, but be aware of that both starting and stopping the app_timer will generate events shortly after this call,
    BR,
    Edvin
  • Edvin said:
    Can you please try to toggle a pin before __WFE to make sure it is only called once every second? Or you can print some message. I am still worried about the sleep logic in your application.
    Are you still doing this?
                __SEV();
                __WFE();
                __WFE();
    That will not work.
    Your main() functions while loop should look like this:
            while (true)
                custom_functions(); // If you need any
                __SEV();
                __WFE();
                __WFE();
  • I have tried multiple time using a repeated timer  and values are absolutely the same.
    This is a strip down version of the program for testing purposed, using a 1 sec repeated timer.   Power consumption goes up with the ESB clock start.
        int rc = 0;
        ret_code_t err_code;
        uint16_t battery_value;
        uint8_t i;
        uint8_t whoami = 0xFF;
        uint8_t reg_data;
        uint8_t cr;
        bool start_sensor = false;
         float magbias[3] = {0};
         int mgbias[3] = {0};
        // float gyrobias[3] = {0};
        //int magbias[3] = {0};
        // Initialize.
       // APP_ERROR_CHECK(NRF_LOG_INIT(NULL));
      //  NRF_LOG_DEFAULT_BACKENDS_INIT();
        clocks_start();    /// from ESB
        APP_ERROR_CHECK(esb_init());
        NRF_LOG_RAW_INFO("\n**********  ICM20948 start  **********\n\r");
        lfclk_init();  // for timestamp
                               // rtc_config(); // sl not used
        gpiote_init();   // init interrupt
        Adc12bitPolledInitialise();     ///  battery_helper.c
      timers_init();    //  ========================  init timer
      while(1)                 //      ****************  main loop *****************
             if  (timer_event)
                tx_payload.noack = false;
                NRF_LOG_INFO("timer event");
                timer_event = false;
                //  battery_timer = true;
             //if (battery_timer)
               {  battery_value = GetBatteryVoltage();
                  sprintf(ESBstring, "Bat: %d",battery_value);
                  NRF_LOG_DEBUG("%s ",ESBstring)
                  ESBsend();
                  battery_timer = false;
                 // next_battery_read_ms = mytimestamp + BATTERY_READ_MS;
            }// if timer event
                 nrfx_gpiote_in_event_disable(MPU_INT_PIN); // helping  7 mv instead of 2 if disable
                 //  twi_disable(); // 1.9 mv  not helping
                 //  nrf_esb_disable();  // 1.9 mv  not helping
                 // NRF_ESB_SYS_TIMER->TASKS_SHUTDOWN = 1;  //  1.9 mv  not helping
             //    NRF_CLOCK->TASKS_HFCLKSTOP = 1;
                //    nrf_drv_clock_hfclk_release();  // 78 mv  - worst
                 //  nrf_drv_clock_lfclk_release();  // 78 mv  - worst
                 //nrf_saadc_disable();  // already disable   wont compile
               //    app_timer_start(m_timer, APP_TIMER_TICKS(1000), NULL);  //  timer one shoot  - events will wake up the sensor
                 //  NRF_LOG_INFO("sleep start \n");
                     // Use directly __WFE and __SEV macros since the SoftDevice is not available.
                     // Wait for event.
                      __WFE();
                      // Clear Event Register.
                      __SEV();
                      __WFE();
               //NRF_LOG_INFO("sleep stop ");
               // NRF_LOG_FLUSH();
              nrfx_gpiote_in_event_enable(MPU_INT_PIN, true);
           // nrfx_gpiote_in_event_disable();
               //nrfx_gpiote_init();
              // nrf_esb_start_rx();
        } // while(1)
    } // main
     But you said that "NRF_CLOCK->TASKS_HFCLKSTOP = 1; // drop the power to few µA"?
    So the issue is that nrf_drv_clock_release does not do the same, right?
    I don't know if you have looked at the implementation ofnrf_drv_clock_hfclk_release(), but depending on what SDK version you are using, it should look something like this:
    void nrf_drv_clock_hfclk_release(void)
        ASSERT(m_clock_cb.module_initialized);
        ASSERT(m_clock_cb.hfclk_requests > 0);
        CRITICAL_REGION_ENTER();
        --(m_clock_cb.hfclk_requests);
        if (m_clock_cb.hfclk_requests == 0)
            hfclk_stop();
        CRITICAL_REGION_EXIT();
    So if you have requested the clock more times than you have released it, then it will not stop the clock. Does any other part of your project request the hfclk?
    BR,
    Edvin
  • I am using SDK16.
    Yes nrf_drv_clock_release don't do the same as NRF_CLOCK->TASKS_HFCLKSTOP = 1;
    The hfclk is only used by ESB...
    The clock is start this way, as in the ESB exemple: esb_low_power_prx
    void clocks_start( void )
        while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0);
    Could you please check the power consumption of the exemple  esb_low_power_prx and tell me what value you get?
  • Try to debug when you call nrf_drv_clock_hfclk_release(), and check the value of m_clock_cb.hfclk_requests after it is decremented, and whether hfclk_stop() is called or not.
    If it is not, then there is either something else in your project that has requested the clock, or the issue may be that noone has requested the clock. Calling clocks_start() doesn't request the clock. Perhaps one of the asserts are triggered, and the application resets starting the clock again?
