Whenever I am importing the sample project I am getting a source directory that does not exist error, adding error report below.
Loading solution asset_tracker.emProject
Executing load commands
cmake -GNinja -DBOARD=nrf52840_pca10056 -DBOARD_DIR=C:/Windows/System32/ncs/zephyr/boards/arm/nrf52840_pca10056 -DZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb -DGNUARMEMB_TOOLCHAIN_PATH=C:/Users/Bhumit/ncs/v1.2.0/toolchain/opt -BC:/Windows/System32/ncs/nrf/applications/asset_tracker/build_nrf52840_pca10056 -HC:/Windows/System32/ncs/nrf/applications/asset_tracker -DEXTRA_KCONFIG_TARGETS=menuconfig_ses -DEXTRA_KCONFIG_TARGET_COMMAND_FOR_menuconfig_ses=C:/Users/Bhumit/ncs/v1.2.0/toolchain/segger_embedded_studio/html/configure_nordic_project_menuconfig.py
CMake Error: The source directory "C:/Windows/System32/ncs/nrf/applications/asset_tracker" does not exist.
Specify --help for usage, or press the help button on the CMake GUI.
Project load failed
Reported error: solution load command failed (1)
  • I have added CMake path to segger studio now I am getting this error.
    C:/Program Files/CMake/bin/cmake.exe -GNinja -DBOARD=nrf52840_pca10056 -DBOARD_DIR=C:/Windows/System32/ncs/zephyr/boards/arm/nrf52840_pca10056 -DZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb -DGNUARMEMB_TOOLCHAIN_PATH=C:/Users/Bhumit/ncs/v1.2.0/toolchain/opt -BC:/Windows/System32/ncs/nrf/applications/asset_tracker/build_nrf52840_pca10056 -HC:/Windows/System32/ncs/nrf/applications/asset_tracker -DEXTRA_KCONFIG_TARGETS=menuconfig_ses -DEXTRA_KCONFIG_TARGET_COMMAND_FOR_menuconfig_ses=C:/Users/Bhumit/ncs/v1.2.0/toolchain/segger_embedded_studio/html/configure_nordic_project_menuconfig.py
    -- Zephyr version: 2.1.99
    -- Selected BOARD nrf52840_pca10056
    -- Found west: C:/Python37/Scripts/west.exe (found suitable version "0.7.2", minimum required is "0.6.0")
    CMake Error at C:/Users/Bhumit/ncs/v1.2.0/zephyr/cmake/host-tools.cmake:67 (string):
    string sub-command REGEX, mode MATCH needs at least 5 arguments total to
    command.
    C:/Users/Bhumit/ncs/v1.2.0/zephyr/cmake/app/boilerplate.cmake:443 (include)
    CMakeLists.txt:11 (include)
    CMake Error at C:/Users/Bhumit/ncs/v1.2.0/zephyr/cmake/host-tools.cmake:68 (if):
    if given arguments:
    "VERSION_LESS" "1.4.6"
    Unknown arguments specified
    Project load failed
    Are you following a specific guide or tutorial? - are you developing using Segger Embedded studio?
    Which CMake and nRF Connect SDK versions are you using?
    I have heard from customers that faced this same error that updating their CMake solved the issue.
    Please see this section for our recommended way of installing the toolchain and Connect SDK.
    Could you also provide the full command you ran when this error occurred?
    command.
    if given arguments:
    Judging by the error message you provided, it seems that not enough arguments was provided to the CMake command.
    As mentioned above, this might be dependent on what CMake version you are using.
    Karl
  • Yes, i am using segger embedded studio (nordic edition), I have updated CMake from 3.14 to 3.17.2 even though I am getting the same error. I have installed nrf connect sdk using the toolchain manager.
  • Which Segger Embedded Studio version are you using? Could you also tell me if you are following a tutorial or guide?
  • Segger (nordic edition) v4.52, nrf connect desktop tool is available in which application is there called as toolchain manager where the option is available to install sdk I have just clicked that button and it has installed all the necessary things for sdk including segger studio.
