NRF9160 - multiple SPI slave
I cant find an example / documentation for controlling multiple SPI slaves (by using different CS pins).
can someone please direct me?
    It doesn't look like it should be a problem to control multiple CS pins with the Zephyr SPI API. You can create more instances of the spi_cs_control structure, one for each slave, then make sure to pass the correct CS structure when you call the spi_read/write/transceive functions.
  • I have tried both spi3 and spi2 in separate examples which work OK.  However, when I put both of them in the same example I get a run-time error "SPI device SPI_2 not found"
    I'm using nrf9160-DK with this overlay file and building with west:
    &spi2 {
    mosi-pin = <31>;
    led_strip: ws2812@0 {
    compatible = "worldsemi,ws2812-spi";
    label = "WS2812";
    /* SPI */
    reg = <0>; /* necessary for SPI bindings */
    spi-max-frequency = <4000000>;
    /* WS2812 */
    chain-length = <1>; /* arbitrary; change at will */
    spi-one-frame = <0x70>;
    spi-zero-frame = <0x40>;
    &uart2 {
    status = "disabled";
    aliases {
    led-strip = &led_strip;
    &spi3 {
    status = "okay";
    sck-pin = <11>;
    mosi-pin = <10>;
    miso-pin = <12>;
    cs-gpios = <&gpio0 13 GPIO_ACTIVE_LOW>;
    bme280@13 {
    compatible = "bosch,bme280";
    reg = <0x00>;
    label = "BME280";
    &uart3 {
    In my prj.conf I have:
    ## sensors
    CONFIG_SENSOR=y
    CONFIG_SPI=y
    CONFIG_I2C=n
    CONFIG_BME280=y
    ##LEDs
    CONFIG_LED_STRIP=y
    CONFIG_WS2812_STRIP=y
    I went back to the single SPI examples and found that I can't use either SPI1 or 2 - same error.
    Any suggestions please?
