I am running nRF Connect on an Android smartphone (Pixel 3 XL running Android 10 (Q)) and see it detect nearby BLE beacons successfully. The application also shows the RSSI chart changing over time when I select it. I want to record that chart data using nRF Logger which I also installed on the Smartphone. However, nRF logger does not detect nRF Connect. If I select the hamburger menu, only the nRF Logger Welcome option is available. Both Connect and Logger were downloaded from the Google Play Store.
nRF Connect = version 4.24.1
nRF Logger = version 1.8.1
Is there a problem running on Android 10? Are the versions above compatible with each other?
Please suggestion options to enable these two applications to work together.
