TWI does not work on custom board with BMD-330 (nRF52810 chipset) even though it works fine on development kits
Dear All,
We have designed our custom board based on BMD-330 (nRF52810 chipset). It uses i2c (TWI) to communicate with Azoteq IQS620A sensor.
TWI code runs fine on nRF52-DK (based on nRF52832) and BMD-330-EVAL (based on nRF52810), but when I run the same code on the custom board, the nrf_drv_twi_rx function returns error code 0x17 (busy).
By the way, I have already removed the DEVELOP_IN_NRF52832 and NRFX_COREDEP_DELAY_US_LOOP_CYCLES=3 flags.
main.c
 * Copyright (c) 2015 - 2019, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup tw_sensor_example main.c
 * @ingroup nrf_twi_example
 * @brief TWI Sensor Example main file.
 * This file contains the source code for a sample application using TWI.
#include <stdio.h>
#include "boards.h"
#include "app_error.h"
#include "nrf_drv_twi.h"
#include "nrf_delay.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
/* TWI instance ID. */
#define TWI_INSTANCE_ID     0
/* Common addresses definition for temperature sensor. */
#define IQS620A_ADDR       0x44
/* Indicates if operation on TWI has ended. */
static volatile bool m_xfer_done = false;
/* TWI instance. */
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
/* Buffer for samples read from sensor. */
static uint8_t m_sample;
 * @brief TWI events handler.
void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
    switch (p_event->type)
        case NRF_DRV_TWI_EVT_DONE:
            m_xfer_done = true;
 * @brief UART initialization.
void twi_init (void)
    ret_code_t err_code;
    const nrf_drv_twi_config_t iqs620a_config = {
       .scl                = 7,
       .sda                = 6,
       .frequency          = NRF_DRV_TWI_FREQ_400K,
       .interrupt_priority = APP_IRQ_PRIORITY_HIGH,
       .clear_bus_init     = false
    err_code = nrf_drv_twi_init(&m_twi, &iqs620a_config, twi_handler, NULL);
    nrf_drv_twi_enable(&m_twi);
 * @brief Function for reading data from temperature sensor.
static void read_sensor_data()
    uint32_t err_code = NRF_SUCCESS;
    /* Read 1 byte from the specified address - skip 3 bits dedicated for fractional part of temperature. */
    err_code = nrf_drv_twi_rx(&m_twi, IQS620A_ADDR, &m_sample, sizeof(m_sample));
    if (err_code != NRF_SUCCESS) return;
    while(m_xfer_done == false);
    NRF_LOG_INFO("\r\nTWI sensor example started.");
    NRF_LOG_FLUSH();
    twi_init();
    while (true)
        nrf_delay_ms(500);
        read_sensor_data();
        NRF_LOG_FLUSH();
Any help to why this issue is occuring on the custom board would be highly appreciated.
Ahmad Shakir
Vulpés Electronics GmbH
