Earlier with SDK 13 in custom advertisement I was able to send 30 bytes under unknown characteristics tab in Nrf connect APP but in SDK 15 I am not. Because the firmware or app getting stuck if I sen more than bytes.
Where exactly does your example get stuck? Could you try to debug the problem and figure it out? Could you also provide some logs? Also, if you could upload a snippet of the relevant code that would be nice.
Simon
* Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @file
* @defgroup ble_sdk_uart_over_ble_main main.c
* @ingroup ble_sdk_app_nus_eval
* @brief UART over BLE application main file.
* This file contains the source code for a sample application that uses the Nordic UART service.
* This application uses the @ref srvlib_conn_params module.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "nrf_drv_saadc.h"
#include "nrf_drv_rtc.h"
#include "nrf_drv_power.h"
#include "nrf_drv_clock.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "app_timer.h"
#include "ble_nus.h"
#include "app_uart.h"
#include "bsp_btn_ble.h"
#include "nrf_pwr_mgmt.h"
#include "ble_gap.h"
#include "boards.h"
#include "bsp_config.h"
#include "nrf_gpiote.h"
#include "app_scheduler.h"
#include "pca10040.h"
#include "boards.h"
//#include "nrf_soc.h"
//#include "nrf_fstorage.h"
#include "nrf_delay.h"
//#include "nrf_fstorage_sd.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define APP_BLE_CONN_CFG_TAG 0 /**< A tag identifying the SoftDevice BLE configuration. */
#define DEVICE_NAME "Nordic_Uart" /**< Name of device. Will be included in the advertising data. */
//#define NUS_SERVICE_UUID_TYPE BLE_UUID_TYPE_VENDOR_BEGIN /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_ADV_INTERVAL 1600 /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_DURATION 0 /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(20, UNIT_1_25_MS) /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(75, UNIT_1_25_MS) /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY 0 /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(20000, UNIT_10_MS) /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(100) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(500) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT 7 /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 256 /**< UART RX buffer size. */
#define SEC_PARAM_BOND 1 /**< Perform bonding. */
#define SEC_PARAM_MITM 0 /**< Man In The Middle protection not required. */
#define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_NONE /**< Display Only capabilities. */
#define SEC_PARAM_OOB 0 /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE 7 /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE 16 /**< Maximum encryption key size. */
#define U8_CMD_MAX_STRING 10
#define U8_MAX_CMD_ENTRIES 5
#define SUCCESS 1
#define FAIL 0
#define TRUE 1
#define FALSE 0
#define U8_MOTION_THRESHOLD 30
#define U8_NO_MOTION_THRESHOLD 5
#define U8_MOTION_DETECT_WT 5
#define U8_MAX_MOTION_DETECT_CNT 60
#define U8_MOTION_NOT_DETECT_WT 3
#define U8_NO_RPM_DETECTED 10
#define U8_NO_RPM_TRIPEND_CNT 5
#define U8_NO_RPM_DETECT 2
#define U8_VALID_RPM 60
#define U8_RTC_RESOLUTION 30//(1000000/32768)
#define APP_TIMER_DELAY APP_TIMER_TICKS(1000)
#define TX_POWER_LEVEL (-12) /**< (-12) 10 meter - TX Power Level value. This will be set both in the TX Power service, in the advertising data, and also used to set the radio transmit power. */
#define SAADC_CALIBRATION_INTERVAL 5 //Determines how often the SAADC should be calibrated relative to NRF_DRV_SAADC_EVT_DONE event. E.g. value 5 will make the SAADC calibrate every fifth time the NRF_DRV_SAADC_EVT_DONE is received.
#define SAADC_SAMPLES_IN_BUFFER 4 //Number of SAADC samples in RAM before returning a SAADC event. For low power SAADC set this constant to 1. Otherwise the EasyDMA will be enabled for an extended time which consumes high current.
#define SAADC_OVERSAMPLE NRF_SAADC_OVERSAMPLE_4X //Oversampling setting for the SAADC. Setting oversample to 4x This will make the SAADC output a single averaged value when the SAMPLE task is triggered 4 times. Enable BURST mode to make the SAADC sample 4 times when triggering SAMPLE task once.
#define SAADC_BURST_MODE 1 //Set to 1 to enable BURST mode, otherwise set to 0.
#define ADC_REF_VOLTAGE_IN_MILLIVOLTS 600 /**< Reference voltage (in milli volts) used by ADC while doing conversion. */
#define ADC_PRE_SCALING_COMPENSATION 6 /**< The ADC is configured to use VDD with 1/3 prescaling as input. And hence the result of conversion is to be multiplied by 3 to get the actual value of the battery voltage.*/
#define DIODE_FWD_VOLT_DROP_MILLIVOLTS 270 /**< Typical forward voltage drop of the diode . */
#define ADC_RES_10BIT 1024 /**< Maximum digital value for 10-bit ADC conversion. */
#define NON_CONNECTABLE_ADV_INTERVAL MSEC_TO_UNITS(100, UNIT_0_625_MS) /**< The advertising interval for non-connectable advertisement (100 ms). This value can vary between 100ms to 10.24s). */
#define APP_BEACON_INFO_LENGTH 0x1A /**< Total length of information advertised by the Beacon. */
#define APP_ADV_DATA_LENGTH 0x1A /**< Length of manufacturer specific data in the advertisement. */
#define APP_DEVICE_TYPE 0x02 /**< 0x02 refers to Beacon. */
#define APP_MEASURED_RSSI 0xC3 /**< The Beacon's measured RSSI at 1 meter distance in dBm. */
#define APP_COMPANY_IDENTIFIER 0x0059 /**< Company identifier for Nordic Semiconductor ASA. as per www.bluetooth.org. */
/**< Proprietary UUID for Beacon. */
#define CONNECTABLE_BEACON 0x1f
#define NON_CONNECTABLE_BEACON 0x00
#define ADC_RESULT_IN_MILLI_VOLTS(ADC_VALUE)\
((((ADC_VALUE) * ADC_REF_VOLTAGE_IN_MILLIVOLTS) / ADC_RES_10BIT) * ADC_PRE_SCALING_COMPENSATION)
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT); /**< BLE NUS service instance. */
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr); /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */
APP_TIMER_DEF(m_timer_id);
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
//static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifier. */
// {BLE_UUID_NUS_SERVICE, NUS_SERVICE_UUID_TYPE}
unsigned int gu32_Cumulativetime = 0;
unsigned int gu32_CurrentAddress = 0;
unsigned int gu32_CurRPMVal = 0;
unsigned int gu32_PrevRPMVal = 0;
uint8_t gu8_ActivateStatus = FALSE;
unsigned int gu32_BattVolt = 0;
uint8_t gu8_VibrationCount = 0;
static uint8_t su8_WakeupTimer = 0;
static uint8_t su8_TripStartFlag = FALSE;
static uint8_t su8_RPMDetectFlag = FALSE;
static uint8_t su8_TripDebounceCnt = 0;
static uint8_t su8_RPMTimerIndex = 0;
static uint32_t su32_RPMTimerValue[5] = {0};
static uint32_t su32_RPMPulseWidth;
//static void on_conn_params_evt(ble_conn_params_evt_t * p_evt);
typedef struct
int8_t ms8_Command[U8_CMD_MAX_STRING];
uint8_t (*function_ptr)(uint8_t *lu8p_RespBuff,uint8_t *lu8p_ResultPtr ,uint8_t *lu8_SavePtr);
}st_btmcfgCommand_t;
//static ble_gap_sec_params_t gst_secparams;
static void apptimer_Init(void);
void rtc2_open(void);
void rtc2_start(void);
void rtc2_stop(void);
uint32_t rtc2_GetRtcCounterValue(void);
void rtc2_close(void);
void rtc2_resetCounter(void);
void gpiote_MagSenseInit(void);
void pwr_VariablesInit(void);
void pwr_MagSensEnable(void);
void pwr_MagSensDisable(void);
void pwr_VibrationDetectEnable(void);
void pwr_VibrationDetectDisable(void);
void gpiote_Vibrationinit(void);
void app_timer_handler(void * p_context);
void gpiote_MagSenseIntEn(void);
void gpiote_MagSenseIntDis(void);
static void power_manage(void);
void GPIOTE_IRQHandler(void);
void apptimer_Start(void);
//static void advertising_start(void);
int16_t saadc_init(void);
int16_t saadc_measure(void);
//void _init(void);
//static void fs_event_handler(nrf_fstorage_evt_t * evt);
void RetriveCumulativetime(void);
//void storeCumulativetime(void);
//static void tx_power_set(void);
uint8_t btm_ExecuteSetTimeReq(uint8_t *lu8p_RespBuff,uint8_t *lu8p_Result, uint8_t *lu8p_SavePtr);
uint8_t btm_ExecuteSetGearReq(uint8_t *lu8p_RespBuff,uint8_t *lu8p_Result, uint8_t *lu8p_SavePtr);
uint8_t btm_ExecuteSetRateReq(uint8_t *lu8p_RespBuff,uint8_t *lu8p_Result, uint8_t *lu8p_SavePtr);
uint8_t btm_ExecuteGetRPMReq(uint8_t *lu8p_RespBuff,uint8_t *lu8p_Result, uint8_t *lu8p_SavePtr);
uint8_t btm_ExecuteSetActivateReq(uint8_t *lu8p_RespBuff,uint8_t *lu8p_Result, uint8_t *lu8p_SavePtr);
uint8_t btm_CmdProcess(uint8_t *lu8p_CmdBuff,uint8_t *lu8p_ResBuf);
static void advertising_init(uint8_t AdvMode);
uint8_t remote_char_data[30];
uint8_t custom_char_data[26];
void remote_To_custom_char(uint8_t *r_data, int r_size);
static ble_gap_adv_params_t m_adv_params; /**< Parameters to be passed to the stack when starting advertising. */
static uint8_t m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET; /**< Advertising handle used to identify an advertising set. */
static uint8_t m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX]; /**< Buffer for storing an encoded advertising set. */
static ble_gap_adv_data_t m_adv_data =
.adv_data =
.p_data = m_enc_advdata,
.len = BLE_GAP_ADV_SET_DATA_SIZE_MAX
.scan_rsp_data =
.p_data = NULL,
.len = 0
static const st_btmcfgCommand_t cst_btmcfgSetCommand[] = {
{"TIME",btm_ExecuteSetTimeReq},
{"GEAR",btm_ExecuteSetGearReq},
{"RATE",btm_ExecuteSetRateReq},
{"DEACTIVATE",btm_ExecuteSetActivateReq}
static const st_btmcfgCommand_t cst_btmcfgGetCommand[] = {
{"RPM",btm_ExecuteGetRPMReq},
//NRF_FSTORAGE_DEF(nrf_fstorage_t m_fs) =
// .evt_handler = fs_event_handler,
// .start_addr = 0x0007E000,
// .end_addr = 0x0007F000,
* Function Name : apptimer_Init
* Description : initializing app timer for 1 sec
* Arguments : None
* Return values : None
// Create 1sec timer.
//app_timer_create(&m_timer_id,APP_TIMER_MODE_REPEATED,app_timer_handler);
* Function Name : apptimer_Start
* Description : start rtc1 in timer mode repeated every 1 sec
* Arguments : void
* Return Values : void
app_timer_start(m_timer_id,APP_TIMER_DELAY, NULL );
* Function Name : pwr_VariablesInit
* Description : Initialize of variables
* Arguments : None
gu32_CurRPMVal = 0;
gu32_BattVolt = 0;
rtc2_close();
* Function Name : gpiote_MagSenseInit
* Description : Initialise the event on magnetic sensor output pin
on every rising edge
* Arguments : void
NRF_GPIOTE->CONFIG[0] = 0x01 << 0; // MODE: Event
NRF_GPIOTE->CONFIG[0] |= BT_MAG_SENSE_OUTPUT << 8; // Pin number
NRF_GPIOTE->CONFIG[0] |= NRF_GPIOTE_POLARITY_HITOLO << 16; // Event rising edge
* Function Name : gpiote_MagSenseIntEn
* Description : Enable the interrupt on magnetic sensor output pin for rising edge
* Arguments : void
NRF_GPIOTE->INTENSET = 0x01 << 0; // enable interrupt
NVIC_ClearPendingIRQ(GPIOTE_IRQn);
NVIC_SetPriority(GPIOTE_IRQn, APP_IRQ_PRIORITY_LOW);
NVIC_EnableIRQ(GPIOTE_IRQn);
* Function Name : gpiote_MagSenseIntDis
* Description : Disable the interrupt on magnetic sensor output pin
* Arguments : void
NRF_GPIOTE->INTENCLR = 0x01 << 0; //clear interrupt
* Function Name : gpiote_Vibrationinit
* Description : configure event for vibration sensor on raising edge
* Arguments : void
NRF_GPIOTE->CONFIG[1] = 0x01 << 0; // MODE: Event
NRF_GPIOTE->CONFIG[1] |= BT_SW_OUTPUT << 8; // Pin number
NRF_GPIOTE->CONFIG[1] |= NRF_GPIOTE_POLARITY_LOTOHI << 16; // Event rising edge
* Function Name : pwr_MagSensEnable
* Description : Enable the magnetic sensor
* Arguments : None
nrf_gpio_pin_set(BT_MAG_SENSE_VSS);
* Function Name : pwr_MagSensDisable
* Description : Disable the magnetic sensor
* Arguments : None
nrf_gpio_pin_clear(BT_MAG_SENSE_VSS);
* Function Name : pwr_VibrationDetectEnable
* Description : Enable the Vibration detection
* Arguments : None
nrf_gpio_pin_set(BT_SW_VSS);
gpiote_Vibrationinit();
* Function Name : pwr_VibrationDetectDisable
* Description : Disable the vibration detection
* Arguments : None
nrf_gpio_pin_clear(BT_SW_VSS);
* Function Name : btm_CmdProcess(s8 *ls8p_CmdBuff,uint8_t *lu8p_ResBuf)
* Description : Process the command recieved from app
* Arguments : ls8p_CmdBuff,lu8p_ResBuf
* Return values : SUCCESS/FAIL
uint8_t lu8_Status = FAIL;
uint8_t lu8_size = 0;
uint8_t *lu8p_word = NULL;
uint8_t *lu8p_SavePtr = NULL;
uint8_t lu8_FirstCmdBuf[10];
uint8_t lu8_SecCmdBuf[10];
uint8_t lu8_Index = 0;
uint8_t *lu8p_buf = NULL;
//check for "#" in command buffer if found
lu8p_buf =(uint8_t *) strstr((char *)lu8p_CmdBuff,"#");
if(lu8p_buf == NULL)
return FAIL;
//check for max size
lu8_size = strlen((char *)lu8p_CmdBuff);
if(lu8_size > 30)
return FAIL;
//skip # from the command
lu8p_CmdBuff += 1;
//process the command
lu8p_word = (uint8_t *)strtok_r((char *)lu8p_CmdBuff,(const char *)",",(char **)&lu8p_SavePtr);
if(NULL == lu8p_word)
strcpy((char *)lu8p_ResBuf,"Unknown Request");
lu8_Status = FAIL;
strcpy((char *) lu8_FirstCmdBuf,(const char *)lu8p_word);
lu8p_word = (uint8_t *)strtok_r((char *)NULL,(const char *)",\r\n",(char **)&lu8p_SavePtr);
lu8_Status = FAIL;
strcpy((char *) lu8_SecCmdBuf,(const char *)lu8p_word);
//uartd_write(lu8_SecCmdBuf,strlen(lu8_SecCmdBuf));
if(0 == strcmp((char*)lu8_FirstCmdBuf,"SET"))
for(lu8_Index = 0;lu8_Index < U8_MAX_CMD_ENTRIES; lu8_Index++)
if(0 == (strcmp( (const char*)lu8_SecCmdBuf,(const char *)cst_btmcfgSetCommand[lu8_Index].ms8_Command)))
lu8_Status = cst_btmcfgSetCommand[lu8_Index].function_ptr(lu8p_ResBuf,lu8p_word,lu8p_SavePtr);
if(0 == strcmp((char*)lu8_FirstCmdBuf,"GET"))
if(0 == (strcmp( (const char*)lu8_SecCmdBuf,(const char *)cst_btmcfgGetCommand[lu8_Index].ms8_Command)))
lu8_Status = cst_btmcfgGetCommand[lu8_Index].function_ptr(lu8p_ResBuf,lu8p_word,lu8p_SavePtr);
return lu8_Status;
* Function Name : btm_ExecuteSetTimeReq(uint8_t *lu8p_RespBuff,uint8_t *lu8p_Result, uint8_t *lu8p_SavePtr)
* Description : Execute the received command
* Arguments : lu8p_RespBuff,lu8p_Result,lu8p_SavePtr
lu8p_Result = (uint8_t *) strtok_r(NULL,(const char *)"\n",(char **)&lu8p_SavePtr);
if(NULL == lu8p_Result)
strcpy((char *)lu8p_RespBuff,"#SET,TIME,FAIL");
return SUCCESS;
//TODO: need to set Time
strcpy((char *)lu8p_RespBuff,"#SET,TIME,SUCCESS");
return SUCCESS;
* Function Name : btm_ExecuteSetGearReq(uint8_t *lu8p_RespBuff,uint8_t *lu8p_Result, uint8_t *lu8p_SavePtr)
lu8p_Result = (uint8_t *) strtok_r(NULL,(const char *)"$",(char **)&lu8p_SavePtr);
strcpy((char *)lu8p_RespBuff,"#SET,GEAR,FAIL");
return SUCCESS;
//TODO: need to set Gear
strcpy((char *)lu8p_RespBuff,"#SET,GEAR,SUCCESS");
return SUCCESS;
* Function Name : btm_ExecuteSetRateReq(uint8_t *lu8p_RespBuff,uint8_t *lu8p_Result, uint8_t *lu8p_SavePtr)
strcpy((char *)lu8p_RespBuff,"#SET,RATE,FAIL");
return SUCCESS;
//TODO: need to set rate
strcpy((char *)lu8p_RespBuff,"#SET,RATE,SUCCESS");
return SUCCESS;
* Function Name : btm_ExecuteSetActivateReq(uint8_t *lu8p_RespBuff,uint8_t *lu8p_Result, uint8_t *lu8p_SavePtr)
strcpy((char *)lu8p_RespBuff,"#SET,DEACTIVATE,FAIL");
return SUCCESS;
gu8_ActivateStatus = (*lu8p_Result - '0');
strcpy((char *)lu8p_RespBuff,"#SET,DEACTIVATE,SUCCESS");
if(TRUE == gu8_ActivateStatus)
app_timer_stop(m_timer_id);
rtc2_close();
pwr_MagSensDisable();
pwr_VibrationDetectDisable();
gpiote_MagSenseIntDis();
return SUCCESS;
* Function Name : btm_ExecuteGetRPMReq(uint8_t *lu8p_RespBuff,uint8_t *lu8p_Result, uint8_t *lu8p_SavePtr)
sprintf((char *)lu8p_RespBuff,"#GET,RPM,%u,%u,%u,%u",gu32_CurRPMVal,gu32_Cumulativetime,gu32_BattVolt,gu8_ActivateStatus);
return SUCCESS;
* Function Name : rtc2_open
* Description :
* Arguments :
* Return values :
NRF_RTC2->PRESCALER = 0;
NVIC_SetPriority(RTC2_IRQn, APP_IRQ_PRIORITY_LOW);
NVIC_ClearPendingIRQ(RTC2_IRQn);
NVIC_EnableIRQ(RTC2_IRQn);
NRF_RTC2->TASKS_CLEAR = 1;
NRF_RTC2->TASKS_START = 1;
* Function Name : rtc2_start
* Description :
* Arguments :
* Return values :
* Function Name : rtc2_stop
* Description :
* Arguments :
* Return values :
NRF_RTC2->TASKS_STOP = 1;
* Function Name : rtc2_GetRtcCounterValue
* Description : This Function returns real time counter value in milli
* seconds
* Arguments : None
* Return values :
return(NRF_RTC2->COUNTER);
* Function Name : rtc2_close
* Description : This Function for de-initializing the RTC2 driver. This
* function disables the RTC event interrupt and disables
* compare events and stops RTC2 events
* Arguments : None
volatile uint32_t lu32_Counter = 10000;
uint32_t mask = ( RTC_INTENCLR_TICK_Pos |
RTC_INTENCLR_OVRFLW_Pos |
RTC_INTENCLR_COMPARE0_Msk |
RTC_INTENCLR_COMPARE1_Msk |
RTC_INTENCLR_COMPARE2_Msk |
RTC_INTENCLR_COMPARE3_Msk
NVIC_DisableIRQ(RTC2_IRQn);
NRF_RTC2->EVTENCLR = mask;
NRF_RTC2->INTENCLR = mask;
/* Once RTC is stopped 15 to 46 micro seconds delay is
* required before we start new selection for the RTC*/
while (lu32_Counter)
lu32_Counter --;
* Function Name : rtcd_resetCounter
* Description : Reset the RTC counter value
* Arguments :
* Return values :
* Function Name : GPIOTE_IRQHandler
* Description : Interrupt every rising edge of Sensor. Timer resolution of 30u Seconds
* Arguments :
* Return Values :
uint32_t lu32_PulseWidth[3];
su32_RPMTimerValue[su8_RPMTimerIndex] = rtc2_GetRtcCounterValue();
if( 3 == su8_RPMTimerIndex)
lu32_PulseWidth[0] = (su32_RPMTimerValue[2] - su32_RPMTimerValue[1]);
lu32_PulseWidth[1] = (su32_RPMTimerValue[3] - su32_RPMTimerValue[2]);
if(abs(lu32_PulseWidth[1] - lu32_PulseWidth[0]) < 400)
su32_RPMPulseWidth = (lu32_PulseWidth[1] + lu32_PulseWidth[0])/2;
su8_RPMDetectFlag = TRUE;
rtc2_stop();
su8_RPMTimerIndex++;
//clear GPIOTE events
NRF_GPIOTE->EVENTS_IN[0] = 0;
* Function Name : app_timer_handler
* Description : Event every 1 second. Channel 1 is for Vibration Sensor
* Arguments :
* Return Values :
uint32_t lu32_RpmValue = 0;
//detect vibration
if(NRF_GPIOTE->EVENTS_IN[1] == 1)
{ // Vibration detected this second
NRF_GPIOTE->EVENTS_IN[1] = 0;
gu8_VibrationCount += U8_MOTION_DETECT_WT;
if(U8_MAX_MOTION_DETECT_CNT <= gu8_VibrationCount)
gu8_VibrationCount = U8_MAX_MOTION_DETECT_CNT; // Saturate at a maximum value
// Vibration not detected this second
if(gu8_VibrationCount > U8_MOTION_NOT_DETECT_WT)
gu8_VibrationCount -= U8_MOTION_NOT_DETECT_WT;
gu8_VibrationCount = 30; //Vibration disabled
if((U8_MOTION_THRESHOLD <= gu8_VibrationCount) || (TRUE == su8_TripStartFlag))
if(0 == su8_WakeupTimer) // Time ut ealpsed- If nor rpm detected in previous attempts wait for U8_NO_RPM_DETECTED number of seconds
//Pulses detected
if(TRUE == su8_RPMDetectFlag)
lu32_RpmValue = ((su32_RPMPulseWidth * U8_RTC_RESOLUTION));
lu32_RpmValue = ((100000000 / lu32_RpmValue) * 60);
lu32_RpmValue /= 400;
//validate the RPM
if(U8_VALID_RPM < lu32_RpmValue)
if(0 == gu32_PrevRPMVal)
gu32_PrevRPMVal = lu32_RpmValue;
gu32_CurRPMVal = (((gu32_PrevRPMVal * 7) + lu32_RpmValue) / 8);
gu32_PrevRPMVal = gu32_CurRPMVal;
//valid RPM detected
if(FALSE == su8_TripStartFlag)
su8_TripStartFlag = TRUE;
su8_TripDebounceCnt ++;
if(TRUE == su8_TripStartFlag)
if(U8_NO_RPM_TRIPEND_CNT <= su8_TripDebounceCnt)
//Trip end
gu32_CurRPMVal = 0;
//Store cumulative time to Flash
// storeCumulativetime();
su8_WakeupTimer = U8_NO_RPM_DETECTED;
rtc2_stop();
return;
//Trip not detected
if(U8_NO_RPM_DETECT <= su8_TripDebounceCnt)
rtc2_stop();
return;
// Enable sensor RTC and interrupt
su32_RPMPulseWidth = 0;
rtc2_resetCounter();
rtc2_start();
pwr_MagSensEnable();
gpiote_MagSenseIntEn();
// Wait time not elapsed
if(su8_WakeupTimer)
su8_WakeupTimer--;
rtc2_stop();
// No Vibration detected
rtc2_stop();
gu32_Cumulativetime++;
* Function Name : saadc_event_handler
* Description : Do nothing, as we use blocking mode
* Arguments :
* Return Values : Void
void saadc_event_handler(nrf_drv_saadc_evt_t const * p_event)
// Do nothing, as we use blocking mode
* Function Name : saadc_init
* Description : Initialising SAADC for measuring Vdd
* Arguments : Void
* Return Values : Ret
int ret = nrf_drv_saadc_init(NULL, saadc_event_handler);
if (ret) return ret;
nrf_saadc_channel_config_t config =
NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(SAADC_CH_PSELP_PSELP_VDD);
ret = nrf_drv_saadc_channel_init(0, &config);
return ret;
* Function Name : saadc_measure
* Description : Measuring battery voltage
* Arguments : Void
* Return Values : Batt voltage
nrf_saadc_value_t value;
nrf_drv_saadc_sample_convert(0, &value);
return ADC_RESULT_IN_MILLI_VOLTS(value);
* Function Name : nrf_fstorage_init
* Description : Initialization for FLASH to store cummulative time
* Arguments : void
//void fstorage_init(void)
// uint32_t err_code;
// err_code = nrf_fstorage_init(&m_fs, &nrf_fstorage_sd, NULL);
// APP_ERROR_CHECK(err_code);
* Function Name : fs_event_handler
* Description :
* Arguments : void
//static void fs_event_handler(nrf_fstorage_evt_t * evt){
// if (evt->result != NRF_SUCCESS){
// NRF_LOG_ERROR("Flash error");
// } else {
// NRF_LOG_INFO("Flash event success");
* Function Name : storeCumulativetime
* Description : store Cumulative time
* Arguments : void
// ret_code_t rc;
// if(gu32_CurrentAddress == m_fs.end_addr)
// rc = nrf_fstorage_erase( &m_fs,m_fs.start_addr,1,NULL);
// if (rc == NRF_SUCCESS)
// gu32_CurrentAddress = m_fs.start_addr;
// nrf_delay_ms(1);
// rc = nrf_fstorage_write(&m_fs, gu32_CurrentAddress, &gu32_Cumulativetime, 4, NULL);
// gu32_CurrentAddress += 4;
//* Function Name : RetriveCumulativetime
//* Description : Retrive Cumulative time
//* Arguments : void
//* Return Values : void
// uint32_t lu32_currentAddress = 0;
// uint32_t lu32_currentData = 0;
// uint32_t lu32_previousData = 0;
// ret_code_t rc;
// uint8_t Flag = FALSE;
// for(lu32_currentAddress = m_fs.start_addr;lu32_currentAddress < m_fs.end_addr; lu32_currentAddress += 4)
// rc = nrf_fstorage_read(&m_fs, lu32_currentAddress, &lu32_currentData, 4);
// if(lu32_currentData == 0xFFFFFFFF)
// gu32_CurrentAddress = lu32_currentAddress;
// break;
// else
// lu32_previousData = lu32_currentData;
// gu32_Cumulativetime = lu32_previousData;
// if( lu32_currentAddress > m_fs.end_addr )
// Flag = TRUE;
// if ( TRUE == Flag)
/**@brief Function for assert macro callback.
* @warning This handler is an example only and does not fit a final product. You need to analyse
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] p_file_name File name of the failing ASSERT call.
* the device. It also sets the permissions and appearance.
uint32_t err_code;
ble_gap_conn_params_t gap_conn_params;
strlen(DEVICE_NAME));
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
// Update security parameters for connection reply
// gst_secparams.bond = SEC_PARAM_BOND;
// gst_secparams.mitm = SEC_PARAM_MITM;
// gst_secparams.io_caps = SEC_PARAM_IO_CAPABILITIES;
// gst_secparams.oob = SEC_PARAM_OOB;
// gst_secparams.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
// gst_secparams.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
* application about an error.
* @param[in] nrf_error Error code containing information about what went wrong.
APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the data from the Nordic UART Service.
* @details This function will process the data received from the Nordic UART BLE Service and send
* it to the UART module.
* @param[in] p_evt Nordic UART Service event.
/**@snippet [Handling the data received over BLE] */
// if (p_evt->type == BLE_NUS_EVT_RX_DATA)
memcpy(remote_char_data, p_evt->params.rx_data.p_data, p_evt->params.rx_data.length);
remote_To_custom_char(remote_char_data, sizeof(remote_char_data));
memcpy(custom_char_data+1, r_data+1, r_size-14);
custom_char_data[(r_size-14)+1]= 0x64;
memcpy(custom_char_data+18, r_data+17, r_size-14);
uint32_t err_code;
ble_nus_init_t nus_init;
// Initialize NUS.
/**@brief Function for handling an event from the Connection Parameters Module.
* @details This function will be called for all events in the Connection Parameters Module
* which are passed to the application.
* @note All this function does is to disconnect. This could have been done by simply setting
* the disconnect_on_fail config parameter, but instead we use the event handler
* mechanism to demonstrate its use.
* @param[in] p_evt Event received from the Connection Parameters Module.
/**@brief Function for handling errors from the Connection Parameters module.
uint32_t err_code;
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = false;
// cp_init.evt_handler = on_conn_params_evt;
cp_init.error_handler = conn_params_error_handler;
// cp_init.p_conn_params->min_conn_interval = MIN_CONN_INTERVAL;
// cp_init.p_conn_params->max_conn_interval = MAX_CONN_INTERVAL;
// cp_init.p_conn_params->slave_latency = SLAVE_LATENCY;
// cp_init.p_conn_params->conn_sup_timeout = CONN_SUP_TIMEOUT;
// if (p_evt->evt_type == BLE_CONN_PARAMS_EVT_FAILED)
// err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_CONN_INTERVAL_UNACCEPTABLE);
* @param[in] ble_adv_evt Advertising event.
//static void on_adv_evt(ble_adv_evt_t ble_adv_evt)
// switch (ble_adv_evt)
// case BLE_ADV_EVT_FAST:
// break;
// case BLE_ADV_EVT_IDLE:
// //advertising_start(); // advertising forever
// break;
// default:
// break;
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
uint32_t err_code;
case BLE_GAP_EVT_CONNECTED:
//m_conn_handle = BLE_CONN_HANDLE_INVALID;
sd_ble_gap_adv_stop(m_adv_handle);
advertising_init(BLE_GAP_ADV_TYPE_NONCONNECTABLE_SCANNABLE_UNDIRECTED);
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
// Pairing not supported
// err_code = sd_ble_gap_sec_params_reply(m_conn_handle, BLE_GAP_SEC_STATUS_SUCCESS, &gst_secparams, NULL);
case BLE_GATTC_EVT_TIMEOUT:
// err_code = sd_ble_gap_disconnect(p_ble_evt->evt.gattc_evt.conn_handle,
// BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
case BLE_GATTS_EVT_TIMEOUT:
// No implementation needed.
/**@brief Function for the SoftDevice initialization.
* @details This function initializes the SoftDevice and the BLE event interrupt.
ret_code_t err_code;
uint32_t ram_start =0;
// Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
p_gatt->att_mtu_desired_central,
p_gatt->att_mtu_desired_periph);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
* @param[in] event Event generated by button press.
uint32_t err_code;
switch (event)
case BSP_EVENT_SLEEP:
case BSP_EVENT_DISCONNECT:
// advertising_start(); // advertising forever
case BSP_EVENT_WHITELIST_OFF:
uint32_t err_code;
ble_advdata_t advdata;
//uint8_t flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
ble_advdata_manuf_data_t manuf_specific_data;
manuf_specific_data.company_identifier = APP_COMPANY_IDENTIFIER;
if(AdvMode ==BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED)
custom_char_data[0]=CONNECTABLE_BEACON;
custom_char_data[0]=NON_CONNECTABLE_BEACON;
manuf_specific_data.data.p_data = (uint8_t *) custom_char_data;
manuf_specific_data.data.size = APP_BEACON_INFO_LENGTH;
// Build and set advertising data.
memset(&advdata, 0, sizeof(advdata));
advdata.name_type = BLE_ADVDATA_NO_NAME;
//advdata.flags = flags;
advdata.p_manuf_specific_data = &manuf_specific_data;
// Initialize advertising parameters (used when starting advertising).
memset(&m_adv_params, 0, sizeof(m_adv_params));
m_adv_params.properties.type = AdvMode;
m_adv_params.p_peer_addr = NULL; // Undirected advertisement.
m_adv_params.filter_policy = BLE_GAP_ADV_FP_ANY;
m_adv_params.interval = NON_CONNECTABLE_ADV_INTERVAL;
m_adv_params.duration = 0; // Never time out.
err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &m_adv_params);
/**@brief Function for waiting for event
sd_app_evt_wait();
err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
* Function Name : tx_power_set
* Description : Setting TX power level
* Arguments : void
// uint32_t err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, m_advertising.adv_handle, TX_POWER_LEVEL);
// uart_init();
// Initialize pins.
// io_pinhandler();
//app timer initialization for 1 sec
apptimer_Init();
rtc2_open();
saadc_init();
ble_stack_init();
//sd_power_dcdc_mode_set(NRF_POWER_DCDC_ENABLE);
gap_params_init();
gatt_init();
services_init();
memset(custom_char_data,0,sizeof(custom_char_data));
advertising_init(BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED);
conn_params_init();
//printf("\r\nadvertising_start() is ok.\r\n");
//tx_power_set();
pwr_VariablesInit();
// RetriveCumulativetime();
// printf(" Beaconm Low power started");
// Enter main loop.
for (;;)
app_sched_execute();
power_manage();
Where does your program get stuck? Could you try to figure it out by doing some debugging? Some logs would be nice as well. When you figure out where your program gets stuck, check if that is due to some function failing, and check what the returned error value is equal to.
It is not even coming to the nus handler.
Okay, the issue might be on the app side. However, it would be nice to see if the data is actually sent. Could you capture a sniffer trace to see what's happening in the air?
You could use the nRF Sniffer for Bluetooth LE to acquire this. You need an additional nRF5x device to use the nRF Sniffer.
Simon
