Earlier with SDK 13 in custom advertisement I was able to send 30 bytes under unknown characteristics tab in Nrf connect APP but in SDK 15 I am not. Because the firmware or app getting stuck if I sen more than bytes.
You can comment that. ,Or you take Ble App Uart example sdk15, make all uuids zero, remove flags and then try.
I tested your sample and saw the same behavior as you. If I send more than 20 bytes (21) from the nRF Connect App, it is not received by the application.
However, I tested the ble_app_uart example, and it was possible to send more than 20 bytes.
I am not sure what the issue is with your application, but I will investigate further.
However, before I investigate any more, could you do the following:
I am quite busy at the moment, but I will try to get to the bottom of it as soon as possible.
Simon
Are you able to receive those more than 20 bytes in the device?
No, with your code, I am not able to receive more than 20 bytes. The nus_data_handler() doesn't run if 21 bytes I sent from the nRF Connect App. I will investigate further and try to provide you with an answer on Monday (6/8/2020).
Simon
I figured out what was causing the issue.
In main.c ble_evt_handler()→BLE_GAP_EVT_SEC_PARAMS_REQUEST, you have commented out sd_ble_gap_sec_params_reply(). Try changing it to:
printf("BLE_GAP_EVT_SEC_PARAMS_REQUEST");
// Pairing not supported
I did this and was able to send 21 bytes from the nRF Connect App.
Simon
