Extending application of SDK 12.3 for legacy buttonless DFU
I need to develop an application for nRF51822 that uses SoftDevice 110 v8.0.0 using SDK 12.3 and extend it to use buttonless DFU for the legacy DFU bootloader of SDK 10/11. I've successfully added S110 v8.0.0 to SDK 12.3 and have its ble_app_uart example building and working well using Segger Embedded Studio 4.18 on macOS (on nRF51 DK).
The DFU bootloader of 12.3 is the newer secure bootloader, so instructions/examples for extending an application for buttonless DFU are for this newer secure bootloader. A couple tickets (here and here) state that it is possible to port the legacy DFU service and related libraries from SDK 10/11 to SDK 12.3.
The guide for extending an app for buttonless DFU in SDK 11 state that the application must use Device Manager. I understand that Device Manager was removed in SDK 12.x and replaced with Peer Manager. I'm a bit lost on how to go about this. Adding buttonless legacy DFU support to an application in SDK 10/11 relies on:
bootloader_util_arm.c in nRF51SDK1000dc26b5e/examples/dfu/experimental_ant_bootloader/
dfu_app_handler.c in nRF51SDK1000dc26b5e/components/libraries/bootloader_dfu
ble_dfu.c in nRF51SDK1000dc26b5e/components/ble/ble_services/ble_dfu
Adding buttonless DFU (secure) support to an application in SDK 12.3 relies on:
ble_dfu.c in
nrf_dfu_settings.c
I've tried approaching this a number of different ways, all unsuccessful so far. Before providing details, thought I would ask for some initial guidance. General steps for extending the ble_app_uart application of SDK 12.3 with S110 v8.0.0 for buttonless legacy DFU.
Many thanks,
Tim
  • Hi Tim,
    as far as I remember, the Device Manager is only used to fetch the Peer Data. So I think that you only have to modify the dfu_app_peer_data_set() function
    /**@brief Function for providing peer information to DFU for re-establishing a bonded connection in
     *        DFU mode.
     * @param[in] conn_handle   Connection handle for the connection requesting DFU mode.
    static void dfu_app_peer_data_set(uint16_t conn_handle)
        uint32_t                 err_code;
        dm_sec_keyset_t          key_set;
        uint32_t                 app_context_data = 0;
        dm_application_context_t app_context;
    /** [DFU bond sharing] */
        err_code = dm_handle_get(conn_handle, &m_dm_handle);
        if (err_code == NRF_SUCCESS)
            err_code = dm_distributed_keys_get(&m_dm_handle, &key_set);
                m_peer_data.addr              = key_set.keys_central.p_id_key->id_addr_info;
                m_peer_data.irk               = key_set.keys_central.p_id_key->id_info;
                m_peer_data.enc_key.enc_info  = key_set.keys_periph.enc_key.p_enc_key->enc_info;
                m_peer_data.enc_key.master_id = key_set.keys_periph.enc_key.p_enc_key->master_id;
                err_code = dfu_ble_svc_peer_data_set(&m_peer_data);
                app_context_data   = (DFU_APP_ATT_TABLE_CHANGED << DFU_APP_ATT_TABLE_POS);
                app_context.len    = sizeof(app_context_data);
                app_context.p_data = (uint8_t *)&app_context_data;
                app_context.flags  = 0;
                err_code = dm_application_context_set(&m_dm_handle, &app_context);
                // Keys were not available, thus we have a non-encrypted connection.
                err_code = dm_peer_addr_get(&m_dm_handle, &m_peer_data.addr);
    Now to replace the DM code with the equivalent Peer Manager APIs I suggest that you take a look at the retrieve_peer_data() function in ble_dfu_bonded.c in SDK v14.1.0. SDK v12.x and v13.x  did not have any bond sharing feature implementend, hence its better to look at v14.x.
    static uint32_t retrieve_peer_data(void)
        ret_code_t              ret_code;
        pm_peer_data_bonding_t  bonding_data;
        pm_peer_id_t            peer_id;
        ret_code = pm_peer_id_get(mp_dfu->conn_handle, &peer_id);
        VERIFY_SUCCESS(ret_code);
        if (peer_id == PM_PEER_ID_INVALID)
            return NRF_ERROR_FORBIDDEN;
        ret_code = pm_peer_data_bonding_load(peer_id, &bonding_data);
        memcpy(&m_peer_data.ble_id, &bonding_data.peer_ble_id, sizeof(ble_gap_id_key_t));
        memcpy(&m_peer_data.enc_key, &bonding_data.own_ltk, sizeof(ble_gap_enc_key_t));
        uint16_t len = SYSTEM_SERVICE_ATT_SIZE;
        ret_code = sd_ble_gatts_sys_attr_get(mp_dfu->conn_handle,
                                             m_peer_data.sys_serv_attr,
                                             &len,
                                             BLE_GATTS_SYS_ATTR_FLAG_SYS_SRVCS);
        NRF_LOG_INFO("---------------system attribute table: %d--------------", len);
        return NRF_SUCCESS;
    So dm_handle_get() and dm_distributed_keys_get() can be replaced with pm_peer_id_get() and pm_peer_data_bonding_load(). Once you have the bonding data ( pm_peer_data_bonding_t) you just need to copy the correct content into a dfu_ble_peer_data_t struct and then pass that to dfu_ble_svc_peer_data_set.
    typedef struct
        uint8_t           own_role;    /**< @brief The BLE role of the local device during bonding. See @ref BLE_GAP_ROLES. */
        ble_gap_id_key_t  peer_ble_id; /**< @brief The peer's Bluetooth address and identity resolution key (IRK). */
        ble_gap_enc_key_t peer_ltk;    /**< @brief The peer's long-term encryption key (LTK) and master ID. */
        ble_gap_enc_key_t own_ltk;     /**< @brief Locally generated long-term encryption key (LTK) and master ID, distributed to the peer. */
    } pm_peer_data_bonding_t;
    typedef struct
        ble_gap_addr_t      addr;                                   /**< BLE GAP address of the device that initiated the DFU process. */
        ble_gap_irk_t       irk;                                    /**< IRK of the device that initiated the DFU process if this device uses Private Resolvable Addresses. */
        ble_gap_enc_key_t   enc_key;                                /**< Encryption key structure containing encrypted diversifier and LTK for re-establishing the bond. */
        uint8_t             sys_serv_attr[SYSTEM_SERVICE_ATT_SIZE]; /**< System service attributes for restoring of Service Changed Indication setting in DFU mode. */
    } dfu_ble_peer_data_t;
    On the bootloader side you should not have to do any changes.
    Best regards
    Bjørn
  • Hi Bjørn, and thanks.
    I'm now unclear about whether or not Peer Manager is required for our application. Our application is based on the ble_app_uart example of SDK 12.3, to be extended for legacy buttonless DFU. I've manually added S110 to SDK 12.3 and have ble_app_uart working with it.
    An encrypted link (bonding) with the central is not necessary, either for our application's normal use or for DFU over BLE.
    If bonding is not necessary for legacy buttonless DFU, can I avoid the use of Peer Manager altogether? Is the work of adding legacy buttonless DFU to SDK 12.3 app thereby simplified? Could I simply reduce dfu_app_peer_data_set() in dfu_app_handler.c (SDK 11.0) to this code, with dm calls/types replaced with non-dm, non-pm equivalents?:
        uint32_t                 err_code;
    If our application must use Peer Manager in order to support legacy buttonless DFU, do I need to follow the instructions of your Migrating to Peer Manager guide in addition to the code changes you note?
    I'm finding compile errors because of incompatibilities between SDK 12.3 Peer Manager and S110, which I manually added to SDK 12.3.
    In a way I feel very close to a solution, but my inexperience with low level BLE and Nordic SDK is making it challenging.
    Thank you for your assistance.
    Tim
  • Hi Tim,
    If you don't plan to forward any peer data to the bootloader, it will be quite simple to do buttonless DFU.
    The main function of buttonless DFU is to switch to the bootloader and tell the bootloader to enter DFU mode instead of booting up the application.
    You can do this by, in your application, simply write to NRF_POWER->GPREGRET value 0xB1 (BOOTLOADER_DFU_START) and then jump to the bootloader. I belive you just need to call this function, the similar to what  in the ble_app_hrs buttonless in SDK v11:
        err_code = sd_power_gpregret_set(BOOTLOADER_DFU_START);
        err_code = sd_softdevice_disable();
        err_code = sd_softdevice_vector_table_base_set(NRF_UICR->NRFFW[0]);
        NVIC_ClearPendingIRQ(SWI2_IRQn);
        interrupts_disable();
        bootloader_util_app_start(NRF_UICR->NRFFW[0]);
    Just simply ignore the peer data stuff, it will be ignored by the bootloader if you don't write anything to it. But note that the bootloader will do advertises with the origin address +1. This is to avoid the original address is bonded to the phone, the bootloader will advertise as a new device.
  • Hello ...
    I've been testing DFU on Simblee and have discovered some odd behaviour, similar to this thread (see last reply, no resolution provided). Simblee is proprietary and normally programmed using Arduino IDE and the Simblee library. It is readback protected so I cannot read its flash contents. I do know it uses S110 v8.0.0 and I do have its dual bank bootloader hex file. I also know that Simblee apps are placed at 0x1F000 in flash instead of 0x18000, the standard location for S110 v8.0.0 applications.
    I built a simple Simblee application that advertises "simblee" and programmed a Simblee using the Arduino IDE. I also built the Nordic ble_app_hrs example of SDK 10.0 for s110_and_dfu (pca10028) using GCC. I modified the linker script to place the application at 0x1F000.
    I used nrfutil version 0.52 to generate zip image files of simpleSimblee.ino.hex and ble_app_hrs_s110.hex with a command like:
    nrfutil dfu genpkg ble_app_hrs_s110.zip --application ble_app_hrs_s110.hex --application-version 0xffff --dev-revision 0xffff --dev-type 0xffff -sd-req 0x64
    I transferred the zip files to iPad with nRF Connect installed then I connect to the Simblee and perform DFU using the simpleSimblee.ino.zip and ble_app_hrs_s110.zip images.
    If the application on the Simblee is a legacy buttonless DFU enabled application built using the Arduino IDE and Simblee library (simpleSimblee), DFU is successful. Here's the DFU log from nRF Connect for DFU of ble_app_hrs_s110.zip:
    File Name: ble_app_hrs_s110.zip
    Parts: 1
    Soft Device Size: Zero KB
    Bootloader Size: Zero KB
    [Callback] Central Manager did update state to: Powered ON
    Connecting to simblee...
    centralManager.connect(peripheral, options: nil)
    [Callback] Central Manager did connect peripheral
    Connected to simblee
    Discovering services...
    peripheral.discoverServices(nil)
    Services discovered
    Starting Legacy DFU...
    Services discovered
    Legacy DFU Service found
    Discovering characteristics in DFU Service...
    peripheral.discoverCharacteristics(nil, for: 00001530-1212-EFDE-1523-785FEABCD123)
    DFU characteristics discovered
    Reading DFU Version number...
    peripheral.readValue(00001534-1212-EFDE-1523-785FEABCD123)
    Read Response received from 00001534-1212-EFDE-1523-785FEABCD123, value (0x): 0100
    Version number read: 0.1
    Enabling notifications for 00001531-1212-EFDE-1523-785FEABCD123...
    peripheral.setNotifyValue(true, for: 00001531-1212-EFDE-1523-785FEABCD123)
    Notifications enabled for 00001531-1212-EFDE-1523-785FEABCD123
    DFU Control Point notifications enabled
    Application with buttonless update found
    Writing to characteristic 00001531-1212-EFDE-1523-785FEABCD123...
    peripheral.writeValue(0x0104, for: 00001531-1212-EFDE-1523-785FEABCD123, type: .withResponse)
    Data written to 00001531-1212-EFDE-1523-785FEABCD123
    Jump to bootloader (Op Code = 1, Upload Mode = 4) request sent
    [Callback] Central Manager did disconnect peripheral
    Disconnected by the remote device
    peripheral.discoverServices([00001530-1212-EFDE-1523-785FEABCD123])
    Services discovered
    Read Response received from 00001534-1212-EFDE-1523-785FEABCD123, value (0x): 0600
    Version number read: 0.6
    Writing image sizes (0b, 0b, 30892b) to characteristic 00001532-1212-EFDE-1523-785FEABCD123...
    peripheral.writeValue(0x0000000000000000ac780000, for: 00001532-1212-EFDE-1523-785FEABCD123, type: .withoutResponse)
    Start DFU (Op Code = 1, Upload Mode = 4) request sent
    Notification received from 00001531-1212-EFDE-1523-785FEABCD123, value (0x): 100101
    Response (Op Code = 1, Status = 1) received
    Writing Initialize DFU Parameters...
    peripheral.writeValue(0x0200, for: 00001531-1212-EFDE-1523-785FEABCD123, type: .withResponse)
    Writing to characteristic 00001532-1212-EFDE-1523-785FEABCD123...
    peripheral.writeValue(0xffffffffffff00000100640013d8, for: 00001532-1212-EFDE-1523-785FEABCD123, type: .withoutResponse)
    peripheral.writeValue(0x0201, for: 00001531-1212-EFDE-1523-785FEABCD123, type: .withResponse)
    Notification received from 00001531-1212-EFDE-1523-785FEABCD123, value (0x): 100201
    Response (Op Code = 2, Status = 1) received
    Initialize DFU Parameters completed
    peripheral.writeValue(0x080c00, for: 00001531-1212-EFDE-1523-785FEABCD123, type: .withResponse)
    Packet Receipt Notif Req (Op Code = 8, Value = 12) request sent
    peripheral.writeValue(0x03, for: 00001531-1212-EFDE-1523-785FEABCD123, type: .withResponse)
    Uploading firmware...
    Sending firmware to DFU Packet characteristic...
    Notification received from 00001531-1212-EFDE-1523-785FEABCD123, value (0x): 100301
    Response (Op Code = 3, Status = 1) received
    Upload completed in 14.52 seconds
    peripheral.writeValue(0x04, for: 00001531-1212-EFDE-1523-785FEABCD123, type: .withResponse)
    Validate Firmware (Op Code = 4) request sent
    Notification received from 00001531-1212-EFDE-1523-785FEABCD123, value (0x): 100401
    Response (Op Code = 4, Status = 1) received
    peripheral.writeValue(0x05, for: 00001531-1212-EFDE-1523-785FEABCD123, type: .withResponse)
    Activate and Reset (Op Code = 5) request sent
    After successful DFU, Simblee advertises Nordic_HRM, I can connect, etc.
    If the application on the Simblee is the ble_app_hrs_s110 application, it seems there is an issue connecting to the device after jumping to the bootloader because there's a pause (timeout?) after "centralManager.connect(peripheral, options: nil)" and then later, the DFU version number read is again 0.1 which I understand means it's the application with buttonless DFU running, not the bootloader. So the DFU controller (nRF Connect) tries to again jump to the bootloader and this repeats without end.
    File Name: simpleSimblee.ino.zip
    Parts: 1
    Connecting to Nordic_HRM...
    Connected to Nordic_HRM
    Services discovered
    Services discovered
    Services discovered
    Services discovered
    Services discovered
    There is something different about legacy buttonless DFU between a Simblee-built application and a Nordic SDK application. I need to resolve this before I continue working on adding legacy buttonless DFU to the ble_app_uart_s110 application I'm using to develop our Simblee/nRF51 application.
    Oddly, when I repeat these tests using an nRF51 DK, all images DFU successfully, even it the application on the DK is a Nordic SDK application with legacy buttonless DFU support.
    I'm puzzled and appreciate any help.
    Many thanks,
    Tim
  • Hello ...
    Unfortunately I'm still stuck here. As per my previous post, for some reason when Simblee has an app that was built using Nordic SDK 10.0 with legacy buttonless DFU support, DFU of a new application fails because it appears that when attempting to jump to bootloader, the device resets and runs the application again rather than entering DFU mode. When Simblee has an app that was built using the Simblee library, DFU of new application succeeds.
    I'm trying to figure out what may be different legacy buttonless DFU support in a Simblee library-built app and a Nordic SDK-built app.
    Are there other ways to force DFU mode from the application? I'm testing with the ble_app_hrs example for s110_and_dfu. My application will be based on ble_app_uart of SDK 12.3, re-worked to work with S110 v8.0.0 and legacy buttonless DFU of SDK 10.0.
    I've seen some tickets where the power management module is used:
    nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_DFU)
    Possible that this would work? Could my app write something to flash to basically make the bootloader see that there's no application and, therefore, enter DFU?
    I find it odd that applications built with Simblee library are placed at 0x1F000 in flash instead of 0x18000, the standard location for s110 v8.0.0 applications.
    I tried in bootloader_start() of dfu_app_handler.c:
    NRF_POWER->GPREGRET = BOOTLOADER_DFU_START;
    NVIC_SystemReset();
    Didn't work. I read that when doing this, you have to remove the init_softdevice check in ble_stack_init() in the bootloader and unfortunately I don't have access to the source of or control over the Simblee bootloader.
    How about using DFU to first update the bootloader to the bootloader of SDK 10.0? Then perhaps DFU of new application, initiated from application build with Nordic SDK 12.3, would work?
    Thank you for any suggested next steps to resolve.
    Tim
