Dear All,
I am using the ble_app_template as my baseline.
I have created a custom service with various characteristics and I am able to broadcast my service, connect and exchange data with it.
My next goal is to be able to break the connection from the host device and shutdown the BLE advertisement.
I understand that the client (my device) is not allowed to break a connection on its own, but I want to be able to do so, in case the battery voltage, for example, drops bellow a certain value.
What would be the beset way to go about it?
I know that there is the APP_ADV_DURATION that I can configure, but I want to make sure that the device will shutdown the BLE radio safely whenever the code needs it. I also need to be able to restart the beaconing and my service as soon as the device's battery recovers.
In order to emulate the 2 events I am using 2 buttons on the nrf52840DK attaching interrupts on them:
My interrupt routine is the following:
/**@brief Function for handling pin interrupts * * @param[in] pin The number of the GPIO pin this interrupt is attached to * @param[in] action Pin action detected on the pin */ void in_pin_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action) { ret_code_t err_code; if (pin == PIN_IN_1) { NRF_LOG_INFO("Button 1 pressed"); if (m_conn_handle != BLE_CONN_HANDLE_INVALID) { err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION); APP_ERROR_CHECK(err_code); } err_code = sd_ble_gap_adv_stop(m_advertising.adv_handle); APP_ERROR_CHECK(err_code); } else if (pin == PIN_IN_2) { NRF_LOG_INFO("Button 2 pressed"); conn_params_init(); advertising_init(); advertising_start(erase_bonds); } }
When I press the first button the device should break the connection (here I am cheating as I am indicating that the HOST broke the connection) and stop beaconing.
When I press button 2 the device will start beaconing again expecting new connections.
What I see is the following:
If I run the code and do not connect with a host device, the bluetooth beaconing starts and stops pressing the 2 buttons as expected.
If I connect and then press button 1 the application returns this error: NRF_ERROR_INVALID_STATE when it calls sd_ble_gap_adv_stop.
So I wonder if there is a better way to achieve the functionality I described, or how can I fix my current implementation so that it does not crush anymore at sd_ble_gap_adv_stop
