mqtt_simple connect to AWS
I have an AWS account and I am comfortable with the AWS IOT operation in general. I have used it in the past. I am trying to get the sample mqtt_simple to connect to AWS IOT and be able to send packets and receive packets to the nRF9160dk board.
 I am not sure how to set up mqtt_simple parameters? I have created a thing and certificates. I have named the thing "nrf-IMEI" as recommended so it has the board ID in it. All I want to do is to be able to publish a packet to a topic on my AWS account and receive a packet from a topic in my AWS account. I have done this several times in the past with other systems so I am comfortable with AWS IOT operations and formats. I just do not understand how to get mqtt_simple to publish from my board to AWS and subscribe to messages from AWS.
Is this the correct program to use. It seems like all the pieces are there I just do not know how to use them.
I appreciate any help you can give, This is an essential requirement of our production system. right now we are using the pre-production system with a modified version of asset_tracker to send sensor data to the nRF Connect site. We need to be able to send sensor data to our AWS site.
  • Martin
    yes it is the same board with the same certificates. it connects and runs fine with V1.2.0 but does not with V1.3.0. I think I made all of the settings in kconfig and prj.conf that I did in V1.2.0 to get ti to connect.
    I am very confused. I must be missing something simple.
  • Please first try to enable more logging from the application:
    Add in prj.conf:
    ASSET_TRACKER_LOG_LEVEL_DBG=y
    What we could do is to make this case private so I could look more into your configurations in your application.
  • Martin
    I added the line but not much more was shown. we can make private or do whatever else is needed.
    I could send you the directory zipped up but you would need the  certificates to connect to my board. I am willing to try whatever you suggest
    [00:00:00.238,250] <inf> asset_tracker: Connecting to LTE network.
    [00:00:00.244,903] <inf> asset_tracker: This may take several minutes.
    [00:00:00.251,953] <dbg> lte_lc.lte_lc_system_mode_set: Sending AT command to set system mode: AT%XSYSTEMMODE=1,0,1,0
    [00:00:00.271,453] <dbg> lte_lc.lte_lc_system_mode_set: Sending AT command to set system mode: AT%XSYSTEMMODE=1,0,1,0
    +CEREG: 2,"9E03","026B8102",7,0,0,"11100000","11100000"
    [00:00:02.561,798] <dbg> lte_lc.at_handler: +CEREG notification: +CEREG: 2,"9E03","026B8102",7,0,0,"11100000","11100000"
    [00:00:02.573,577] <dbg> lte_lc.parse_psm_cfg: TAU: -1 sec, active time: -1 sec
    +CSCON: 1
    [00:00:02.611,602] <dbg> lte_lc.at_handler: +CSCON notification
    +CEREG: 5,"9E03","026B8102",7,,,"11100000","11100000"
    [00:00:04.247,039] <dbg> lte_lc.at_handler: +CEREG notification: +CEREG: 5,"9E03","026B8102",7,,,"11100000","11100000"
    [00:00:04.258,636] <dbg> lte_lc.parse_psm_cfg: TAU: -1 sec, active time: -1 sec
    [00:00:04.266,601] <inf> asset_tracker: Connected to LTE network.
    [00:00:04.273,193] <inf> asset_tracker: Connecting to cloud, attempt 1 of 8
    client_id_buf nrf-352656100378150
    CONFIG_AWS_IOT_BROKER_HOST_NAME a2uy3w9dvx40gv-ats.iot.us-east-1.amazonaws.com
    client_broker_init passed
    [00:00:09.697,937] <inf> asset_tracker: Cloud connection request sent.
    [00:00:09.704,925] <inf> asset_tracker: Connection response timeout is set to 30 seconds.
    [00:00:09.713,592] <dbg> watchdog.secondary_feed_worker: Feeding watchdog
    [00:00:14.720,916] <dbg> watchdog.secondary_feed_worker: Feeding watchdog
    +CSCON: 0
    [00:00:17.323,913] <dbg> lte_lc.at_handler: +CSCON notification
    [00:00:19.728,271] <dbg> watchdog.secondary_feed_worker: Feeding watchdog
    [00:00:24.735,656] <dbg> watchdog.secondary_feed_worker: Feeding watchdog
    [00:00:29.743,072] <dbg> watchdog.secondary_feed_worker: Feeding watchdog
    [00:00:34.750,457] <dbg> watchdog.secondary_feed_worker: Feeding watchdog
    [00:00:39.713,623] <err> asset_tracker: LTE link disconnect
    +CSCON: 1
    [00:00:39.833,801] <dbg> lte_lc.at_handler: +CSCON notification
    +CEREG: 0,"9E03","026B8102",7,0,0,"11100000","11100000"
    [00:00:39.845,367] <dbg> lte_lc.at_handler: +CEREG notification: +CEREG: 0,"9E03","026B8102",7,0,0,"11100000","11100000"
    [00:00:39.857,147] <dbg> lte_lc.parse_psm_cfg: TAU: -1 sec, active time: -1 sec
  • Martin
    I added some print statements to help see what is going on. see below that everything is passing (client_broker_init -> mqtt_connect -> aws_iot -> cloud_connect).  the client structure returned from client_broker_init is identical to the one returned in mqtt_simple I am pretty sure. I printed out some of the same information in both. it looks like mqtt is never connecting and calling the call back handler. it is the same board with the same credentials and security tag.
    could it be some other configuration is different that needs to be set or changed? the mqtt_simple has a very simple client_init interface while the asset_tracker now has several layers and uses aws_iot.c functions. I am at a loss and can not see what I am missing. any ideas or suggestions would be helpful.
    if you have a working example of asset_tracker for V1.3.0 connecting to aws that would help also. I am sure it is something very simple I am missing.
    [00:00:03.533,050] <inf> asset_tracker: Connecting to cloud, attempt 1 of 8
    [00:00:03.742,462] <dbg> aws_iot.broker_init: IPv4 Address found 3.221.33.115
    mqtt_connect passed
    aws_iot_connect 0
    cloud_connect 0
    [00:00:08.274,841] <inf> asset_tracker: Cloud connection request sent.
    [00:00:08.281,829] <inf> asset_tracker: Connection response timeout is set to 30 seconds.
  • Hi Timothy,
    I think the issue is that there's nothing actually reading incoming data to the cloud socket. For the asset tracker, the assumption is that it's done by the cloud backend. That is the case for nRF Cloud backend, but not for AWS IoT backend. Support for polling the AWS IoT socket in the backend is coming in this PR: https://github.com/nrfconnect/sdk-nrf/pull/2351/commits
    For now you can cherry-pick the commit introducing this addition from that PR and enable it with Kconfig.
    Another option is to solve this in the asset tracker like it's done in the cloud client sample: https://github.com/nrfconnect/sdk-nrf/blob/3710213bc65cb64fbb59fb07ae84285ab1c2755b/samples/nrf9160/cloud_client/src/main.c#L221
    Jan Tore
