mqtt_simple connect to AWS
I have an AWS account and I am comfortable with the AWS IOT operation in general. I have used it in the past. I am trying to get the sample mqtt_simple to connect to AWS IOT and be able to send packets and receive packets to the nRF9160dk board.
 I am not sure how to set up mqtt_simple parameters? I have created a thing and certificates. I have named the thing "nrf-IMEI" as recommended so it has the board ID in it. All I want to do is to be able to publish a packet to a topic on my AWS account and receive a packet from a topic in my AWS account. I have done this several times in the past with other systems so I am comfortable with AWS IOT operations and formats. I just do not understand how to get mqtt_simple to publish from my board to AWS and subscribe to messages from AWS.
Is this the correct program to use. It seems like all the pieces are there I just do not know how to use them.
I appreciate any help you can give, This is an essential requirement of our production system. right now we are using the pre-production system with a modified version of asset_tracker to send sensor data to the nRF Connect site. We need to be able to send sensor data to our AWS site.
  • Jan
    thanks you very much. I added the POLL loop like was in the V1.2.0 asset_tracker from the cloud_client example.
    I can now connect to mqtt but I see two problems as shown below. first is I get AWS shadow topics subscribe error. I am not sure what topics I am supposed to configure to subscribe to. I just selected the first few. the second is that the program crashes when it gets fota messages. I think I ma very close now. it is connecting and subscribing but some scribe errors and a crash with fota message.
    any ideas on what is going on now?
    [00:00:08.087,371] <inf> asset_tracker: Cloud connection request sent.
    [00:00:08.094,360] <inf> asset_tracker: Connection response timeout is set to 30 seconds.
    [00:00:08.103,027] <dbg> watchdog.secondary_feed_worker: Feeding watchdog
    [00:00:13.110,382] <dbg> watchdog.secondary_feed_worker: Feeding watchdog
    mqtt_evt_handler called 0
    [00:00:15.937,072] <inf> aws_jobs: Subscribe: $aws/things/nrf-352656100378150/jobs/notify-next
    +CSCON: 0
    [00:00:15.947,387] <dbg> lte_lc.at_handler: +CSCON notification
    [00:00:15.954,071] <inf> aws_jobs: Subscribe: $aws/things/nrf-352656100378150/jobs/$next/get/#
    [00:00:15.964,172] <dbg> aws_iot.mqtt_evt_handler: MQTT client connected!
    [00:00:15.971,496] <dbg> aws_iot.topic_subscribe: Subscribing to AWS shadow topic: $aws/things/nrf-352656100378150/shadow/get/accepted
    [00:00:15.984,039] <dbg> aws_iot.topic_subscribe: Subscribing to AWS shadow topic: $aws/things/nrf-352656100378150/shadow/get/rejected
    [00:00:15.996,643] <dbg> aws_iot.topic_subscribe: Subscribing to AWS shadow topic: $aws/things/nrf-352656100378150/shadow/update/accepted
    [00:00:16.009,429] <dbg> aws_iot.topic_subscribe: Subscribing to AWS shadow topic: $aws/things/nrf-352656100378150/shadow/update/rejected
    [00:00:16.022,216] <dbg> aws_iot.topic_subscribe: Subscribing to AWS shadow topic: $aws/things/nrf-352656100378150/shadow/update/delta
    [00:00:16.034,820] <err> aws_iot: AWS shadow topics subscribe, error: -12
    [00:00:16.042,358] <inf> asset_tracker: CLOUD_EVT_CONNECTED
    [00:00:16.048,400] <inf> asset_tracker: Persistent Sessions = 0
    [00:00:16.054,779] <inf> asset_tracker: CLOUD_EVT_READY
    +CSCON: 1
    [00:00:16.061,950] <dbg> lte_lc.at_handler: +CSCON notification
    [00:00:16.068,725] <dbg> nrf9160_gps.init: GPS socket created, fd: 1232491587
    [00:00[00:00:16.070,251] <dbg> aws_iot.aws_iot_send: Publishing to topic: $aws/things/nrf-352656100378150/shadow/update
    :16.077,178] <inf> gps_control: GPS initialized
    mqtt_evt_handler called 7
    [00:00:16.586,517] <inf> aws_fota: subscribed to notify-next topic
    [00:00:16.593,231] <inf> aws_jobs: Publish topic: $aws/things/nrf-352656100378150/jobs/$next/get
    [00:00:16.602,478] <inf> aws_jobs: Publish payload {"clientToken": ""}
    [00:00:16.750,946] <dbg> aws_iot.mqtt_evt_handler: MQTT_EVT_SUBACK: id = 2114 result = 0
    mqtt_evt_handler called 3
    [00:00:16.967,163] <dbg> aws_iot.mqtt_evt_handler: MQTT_EVT_PUBACK: id = 19972 result = 0
    mqtt_evt_handler called 2
    [00:00:17.012,084] <dbg> aws_fota.on_publish_evt: Received topic: $aws/things/nrf-352656100378150/jobs/$next/get/accepted
    [00:00:17.023,498] <inf> aws_fota: Checking for an available job
    [00:00:17.030,059] <dbg> aws_fota.get_job_execution: Job doc: {"clientToken":"","timestamp":1593124752}
    [00:00:17.040,191] <dbg> aws_fota.get_job_execution: Got only one field
    [00:00:17.047,271] <inf> aws_fota: No queued jobs for this device
    *** Booting Zephyr OS build v2.3.0-rc1-ncs1 ***
  • Jan
    I got rid of the subscribe error by only subscribing to the first 4 AWS topics as shown below.
    I also am receiving only the flip data on my AWS account as shown below.
      "appId": "FLIP",
      "data": "NORMAL",
      "messageType": "DATA"
    I am not receiving the device info or sensor information packets. I am sure that
    is because it crashed before or during the transmission of those JSON packets.
    it crashes at the same place each time.
    [00:00:16.418,701] <dbg> aws_fota.get_job_execution: Job doc: {"clientToken":"","timestamp":1593126964}
    [00:00:16.428,833] <dbg> aws_fota.get_job_execution: Got only one field
    [00:00:16.435,913] <inf> aws_fota: No queued jobs for this device
    any ideas where I can look to fix this. maybe this is all I need and I will be
    working again with V1.3.0. I am sure I am very close. I would be still banging my
    head without your help. I had no idea the POLL loop was needed.
    [00:00:14.879,913] <inf> aws_jobs: Subscribe: $aws/things/nrf-352656100378150/jobs/notify-next
    +CSCON: 0
    [00:00:14.890,228] <dbg> lte_lc.at_handler: +CSCON notification
    [00:00:14.896,881] <inf> aws_jobs: Subscribe: $aws/things/nrf-352656100378150/jobs/$next/get/#
    [00:00:14.906,768] <dbg> aws_iot.mqtt_evt_handler: MQTT client connected!
    [00:00:14.914,062] <dbg> aws_iot.topic_subscribe: Subscribing to AWS shadow topic: $aws/things/nrf-352656100378150/shadow/get/accepted
    [00:00:14.926,605] <dbg> aws_iot.topic_subscribe: Subscribing to AWS shadow topic: $aws/things/nrf-352656100378150/shadow/get/rejected
    [00:00:14.939,147] <dbg> aws_iot.topic_subscribe: Subscribing to AWS shadow topic: $aws/things/nrf-352656100378150/shadow/update/accepted
    [00:00:14.951,995] <dbg> aws_iot.topic_subscribe: Subscribing to AWS shadow topic: $aws/things/nrf-352656100378150/shadow/update/rejected
    +CSCON: 1
    [00:00:14.966,094] <dbg> lte_lc.at_handler: +CSCON notification
    [00:00:14.972,656] <inf> asset_tracker: CLOUD_EVT_CONNECTED
    [00:00:14.978,698] <inf> asset_tracker: Persistent Sessions = 0
    [00:00:14.985,107] <inf> asset_tracker: CLOUD_EVT_READY
    [00:00:14.991,668] <dbg> nrf9160_gps.init: GPS socket created, fd: 1232491587
    [00:00:15.000,152] <inf> gps_control: GPS initialized
    [00:00:14.993,713] <dbg> aws_iot.aws_iot_send: Publishing to topic: $aws/things/nrf-352656100378150/shadow/update
    [00:00:15.698,669] <inf> aws_fota: subscribed to notify-next topic
    [00:00:15.705,413] <inf> aws_jobs: Publish topic: $aws/things/nrf-352656100378150/jobs/$next/get
    [00:00:15.714,660] <inf> aws_jobs: Publish payload {"clientToken": ""}
    [00:00:16.025,726] <dbg> aws_iot.mqtt_evt_handler: MQTT_EVT_SUBACK: id = 2114 result = 0
    [00:00:16.072,052] <dbg> aws_iot.mqtt_evt_handler: MQTT_EVT_SUBACK: id = 29952 result = 0
    [00:00:16.389,495] <dbg> aws_iot.mqtt_evt_handler: MQTT_EVT_PUBACK: id = 56415 result = 0
    [00:00:16.400,756] <dbg> aws_fota.on_publish_evt: Received topic: $aws/things/nrf-352656100378150/jobs/$next/get/accepted
    [00:00:16.412,170] <inf> aws_fota: Checking for an available job
  • Hi Jan
    Let me confirm. In ncs v1.3.0 you are supposed to use asset_tracker connecting nRF cloud and AWS IoT is not supported yet right?
  • Jan
    any update on this? is it supported and if so do you understand why I am crashing? If not can you tell me when it is supported and I will continue to work with V1.2.0 until it is supported.
    Yusuke, only nRF Cloud backend is officially supported and tested in NCS releases. I'm not aware of timeline for official AWS IoT support. I would expect it to work, however.
    Timothy, it looks like the client token object in received jobs message is empty. You could use debugger to check if that's the reason for crash.
    I'm out of office the next few weeks, so I will unfortunately not be able to follow up much at this time. Hopefully Martin can pick it up or forward it to someone who can. If not, I will pick it up when I'm back.
    Jan Tore
