Acceleraton sensor with nrf52DK
Im trying to interface LIS3DH with nRF52DK referring this example https://devzone.nordicsemi.com/f/nordic-q-a/34710/lis2dh12-driver-issue-in-nrf-sdk-v15-0.
Im getting the following result, the control doesnt enter "print_identity " function and the results are as follows,
Can you help me find out how to read the values of acceleration with this code and interpret the value read?
 * Copyright (c) 2015 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup tw_sensor_example main.c
 * @ingroup nrf_twi_example
 * @brief TWI Sensor Example main file.
 * This file contains the source code for a sample application using TWI.
#include <stdio.h>
#include "boards.h"
#include "app_error.h"
#include "nrf_drv_twi.h"
#include "nrf_delay.h"
#include "app_gpiote.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "lis2dh12.h"
#include "nrf_twi_mngr.h"
/* TWI instance ID. */
#define TWI_INSTANCE_ID             0
#define MAX_PENDING_TRANSACTIONS    33
#define LIS2DH12_MIN_QUEUE_SIZE     32
NRF_TWI_MNGR_DEF(m_nrf_twi_mngr, MAX_PENDING_TRANSACTIONS, TWI_INSTANCE_ID);
NRF_TWI_SENSOR_DEF(m_nrf_twi_sensor, &m_nrf_twi_mngr, LIS2DH12_MIN_QUEUE_SIZE);
LIS2DH12_INSTANCE_DEF(m_lis2dh12, &m_nrf_twi_sensor, LIS2DH12_BASE_ADDRESS_LOW);
static uint8_t m_sample = 0;
void print_identity(ret_code_t r, void *p_register_data)
    NRF_LOG_INFO("Identity: %d", *((uint8_t *)p_register_data));
    uint32_t err;
    nrf_drv_twi_config_t const config = {
       .scl                = 27,
       .sda                = 26,
       .frequency          = NRF_DRV_TWI_FREQ_100K,
       .interrupt_priority = APP_IRQ_PRIORITY_LOWEST,
       .clear_bus_init     = false
    NRF_LOG_INFO("TWI sensor example started.");
    NRF_LOG_FLUSH();
    err = nrf_twi_mngr_init(&m_nrf_twi_mngr, &config);
    APP_ERROR_CHECK(err);
    err = nrf_twi_sensor_init(&m_nrf_twi_sensor);
    err = lis2dh12_init(&m_lis2dh12);
    NRF_LOG_FLUSH();
    while (true)
        nrf_delay_ms(500);
         NRF_LOG_INFO("Here3.");
        err = lis2dh12_who_am_i_read(&m_lis2dh12, print_identity, &m_sample);
        NRF_LOG_FLUSH();
 * Copyright (c) 2017 - 2019, Nordic Semiconductor ASA
#define RETURN_IF_ERR(err)  \
    if (err != NRF_SUCCESS) \
        return err;         \
ret_code_t lis2dh12_init(lis2dh12_instance_t * p_inst)
    ASSERT(p_inst != NULL);
    memset(&p_inst->temp_cfg, 0, &p_inst->act_dur - &p_inst->temp_cfg);
    p_inst->ctrl0     = LIS2DH12_CTRL_REG0_VALID_SET;
    p_inst->ctrl1     = 0x07;
    p_inst->ctrl4     = 0x80;
    return lis2dh12_cfg_commit(p_inst);
ret_code_t lis2dh12_cfg_commit(lis2dh12_instance_t * p_inst)
    ret_code_t err;
    p_inst->ctrl0 &= ~LIS2DH12_CTRL_REG0_VALID_MASK;
    p_inst->ctrl0 |= LIS2DH12_CTRL_REG0_VALID_SET;
    uint8_t ctrl_msg[] = {
        LIS2DH12_REG_CTRL_REG0 | LIS2DH12_AUTO_INCR_MASK,
        p_inst->ctrl0,
        p_inst->temp_cfg,
        p_inst->ctrl1,
        p_inst->ctrl2,
        p_inst->ctrl3,
        p_inst->ctrl4,
        p_inst->ctrl5,
        p_inst->ctrl6,
        p_inst->reference
    err = nrf_twi_sensor_write(p_inst->p_sensor_data,
                               p_inst->sensor_addr,
                               ctrl_msg,
                               ARRAY_SIZE(ctrl_msg),
                               true);
    RETURN_IF_ERR(err);
    uint8_t fifo_msg[] = {
        LIS2DH12_REG_FIFO_CTRL | LIS2DH12_AUTO_INCR_MASK,
        p_inst->fifo_ctrl,
        0,
        p_inst->int1_cfg,
        0,
        p_inst->int1_ths,
        p_inst->int1_dur,
        p_inst->int2_cfg,
        0,
        p_inst->int2_ths,
        p_inst->int2_dur,
        p_inst->click_cfg
                               fifo_msg,
                               ARRAY_SIZE(fifo_msg),
                               true);
    RETURN_IF_ERR(err);
    uint8_t time_msg[] = {
        LIS2DH12_REG_CLICK_THS | LIS2DH12_AUTO_INCR_MASK,
        p_inst->click_ths,
        p_inst->time_lim,
        p_inst->latency,
        p_inst->time_win,
        p_inst->act_ths,
        p_inst->act_dur
                               time_msg,
                               ARRAY_SIZE(time_msg),
                               true);
    return err;
ret_code_t lis2dh12_data_read(lis2dh12_instance_t * p_inst,
                              lis2dh12_data_cb_t    user_cb,
                              lis2dh12_data_t *     p_data,
                              uint8_t               samples)
    return nrf_twi_sensor_reg_read(p_inst->p_sensor_data,
                                   LIS2DH12_REG_OUT_X_L | LIS2DH12_AUTO_INCR_MASK,
                                   (nrf_twi_sensor_reg_cb_t) user_cb,
                                   (uint8_t *) p_data,
                                   samples * LIS2DH12_BYTES_PER_SAMPLE);
ret_code_t lis2dh12_temp_enable(lis2dh12_instance_t * p_inst, bool temp_en)
    if (temp_en == true)
        NRF_TWI_SENSOR_REG_SET(p_inst->temp_cfg, LIS2DH12_TEMP_EN_MASK, LIS2DH12_TEMP_EN_POS, 3);
        NRF_TWI_SENSOR_REG_SET(p_inst->temp_cfg, LIS2DH12_TEMP_EN_MASK, LIS2DH12_TEMP_EN_POS, 0);
    uint8_t send_msg[] = {
        LIS2DH12_REG_TEMP_CFG_REG,
        p_inst->temp_cfg
    return nrf_twi_sensor_write(p_inst->p_sensor_data,
                                send_msg,
                                ARRAY_SIZE(send_msg),
                                true);
ret_code_t lis2dh12_temp_read(lis2dh12_instance_t * p_inst,
                              lis2dh12_temp_cb_t    user_cb,
                              int16_t *             p_temp)
                                   LIS2DH12_REG_OUT_TEMP_L | LIS2DH12_AUTO_INCR_MASK,
                                   (uint8_t *) p_temp,
                                   LIS2DH12_BYTES_PER_TEMP);
lis2dh12.h
