Bootloader update problem
I'm having an issue programming the bootloader using .hex file. I have "Erase all" by nrf52832 and was trying to debug my bootloader the code didn't stop at the beginning of the main. By breaking the code I was it was running in the Softdevice. Finally I figure out that the UICR[0] register wasn't written to the address of the bootloader. I manually write the address with nrfjprog.exe using the following command line and it start running properly:
nrfjprog.exe --family NRF52 --memwr 0x10001014 --val 0x00078000
Then I try to update the softdevice and applicative firmware and everything work fine.
I then try to update the bootloader version but it doesn't work. I'm trying to figure out what is not working properly but having some problem to run the bootloader in debug. Anyway I figure out that if I write the UICR[1] register to the __mbr_params_page_start__ (0x0007E000).
I was trying to see in the code where the UICR[1] register is use that could cause my problem. There is the following definition that I found but it doesn't seems to be used:
#define MBR_PARAMS_PAGE_ADDRESS (NRF_UICR->NRFFW[1])
Any idea why I can't update my bootloader if NRF_UICR->NRFFW[1] != 0x0007E000?
Also is there a way to have the NRF_UICR->NRFFW[0] and NRF_UICR->NRFFW[1] values included in the .hex file without modifying it manually?
Thank!
  • Bootloader and MBR param page adresses have changed in recent SDKs - which version do you use?
    Newer SDK use a location within the MBR space and use UICR as backup. Older SDKs use UICR locations exclusively.
    And yes, the bootloader cannot be updated via DFU without a MBR param page specified.
    Yes and no. SDK 15.3 no longer uses the UICR but use the end of the MBR page (page 0) to store the bootloader settings and MBR params addresses. This is included when you build the bootloader project, so if you inspect the bootloader hex file (for instance by just opening it in nRF Connect Programmer, you will see that it includes two words at the end of page 0. Because of this, you must take care when programming the bootloader and SoftDevice initially, so that you don't accidentally erase either the MBR when writing the bootloader, or the other way around (erasing BL settings/MBR params address), which you will do if you erase all pages that you are writing to. This is a common problem with SDK 15.3.
  • I'm comparing the .hex generated by the open_bootloader_usb_mbr_pca10056 example and my project and in the example .hex file I see the following 2 lines but not in mine:
    :040FF80000000E00E7
    :040FFC0000E00F0002
    I understand that I won't have the same exact lines but lines that will begin with :040FF8 and :040FFC.
    I have the definition of m_uicr_bootloader_start_address in my code as follow:
    volatile uint32_t m_uicr_bootloader_start_address __attribute__ ((section(".uicr_bootloader_start_address")))
    = BOOTLOADER_START_ADDR;
    #define BOOTLOADER_START_ADDR (CODE_START)
    #define CODE_START ((uint32_t)&_vectors)
    In the linker script (bootloader.ld) the uicr_bootloader_start_address section is define in the MEMORY definition but not placed.
    MEMORY
            UNPLACED_SECTIONS (wx) : ORIGIN = 0x100000000, LENGTH = 0
            uicr_mbr_params_page (wx) : ORIGIN = 0x00000ffc, LENGTH = 0x00000004
            uicr_bootloader_start_address (wx) : ORIGIN = 0x00000ff8, LENGTH = 0x00000004
            bootloader_settings_page (wx) : ORIGIN = 0x0007f000, LENGTH = 0x00001000
            mbr_params_page (wx) : ORIGIN = 0x0007e000, LENGTH = 0x00001000
            RAM (wx) : ORIGIN = 0x20000000, LENGTH = 0x00010000
            FLASH (wx) : ORIGIN = 0x00000000, LENGTH = 0x00080000
    It's the same for the uicr_mbr_params_page section.
    Any idea why the definition is remove? Optimization Level at None doesn't work.
  • Check your hex file generation command. It may not include the extra uicr_mbr_params_page section.
