NRF52840 Mesh : Device communicates not communicate if they are not in direct range.
Dear,
I am struggle a problem in mesh communication.
Mesh SDK 4.1.0
I used dimmer example.
Two nodes can communicate and work perfectly fine, only if they are in communication range. if they are not in communication range, I put a 3 rd not in between them. but communication doesn't happen. I confirms that all 3 nodes works perfect, only if  in direct communication range.
Changes I done :
I want to use phy coded to get longer range. changed parameter according to this link. replied of Hung Bui.
Please support me in this.
Thank You
Bivay
  • Hi Brevy,
    Could you double check if MESH_FEATURE_RELAY_ENABLED is set to 1 in your code ?
    Could you try to test using the light switch example , I don't think it would be much different to the dimming example but it worth to try.
    What was your "direct communication range" ? When you put the 3rd node in between 2 nodes, they are in directed communication range ?
    To check if the note actually doing relay or not you can do this to enable logging for the NETWORK layer :
    __LOG_INIT(LOG_SRC_APP | LOG_SRC_BEARER|LOG_SRC_NETWORK, LOG_LEVEL_DBG1, LOG_CALLBACK_DEFAULT);
    When checking the log you can find when the node receives a mesh packet (RX) and when it retransmit a packet (TX).
  • Thanks for support. I will try your suggestions.
