nrfx.h: No such file or directory
I am coming accoss an issue while running the LLPM Sample example from http://developer.nordicsemi.com/nRF_Connect_SDK/doc/1.2.0/nrf/samples/bluetooth/llpm/README.html on nRF52. The issue being "nrfx.h: No such file or directory". Any help would be appreciated. I have attached screenshot below and output transcript.
Output is as follows:
Building ‘zephyr/include/generated/driver-validation.h’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/CMakeFiles/driver_validation_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/driver_validation_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/kobj-types-enum.h’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/otype-to-str.h’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/CMakeFiles/kobj_types_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/kobj_types_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘C:/Users/production/ncs/v1.2.0/zephyr/include/dt-bindings/gpio/gpio.h’ from solution ‘build’ in configuration ‘Common’
Building ‘C:/Users/production/ncs/v1.2.0/zephyr/include/dt-bindings/i2c/i2c.h’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls.json’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/syscall_list.h’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/CMakeFiles/syscall_list_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/syscall_dispatch.c’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/syscall_list_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_offsets’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj’ from solution ‘build’ in configuration ‘Common’
1> Compiling ‘offsets.c’
1> In file included from C:/Users/production/ncs/v1.2.0/zephyr/include/arch/arm/aarch32/cortex_m/cmsis.h:17,
1> from C:/Users/production/ncs/v1.2.0/zephyr/include/arch/arm/aarch32/cortex_m/mpu/arm_mpu_v7m.h:10,
1> from C:/Users/production/ncs/v1.2.0/zephyr/include/arch/arm/aarch32/cortex_m/mpu/arm_mpu.h:13,
1> from C:/Users/production/ncs/v1.2.0/zephyr/include/arch/arm/aarch32/arch.h:248,
1> from C:/Users/production/ncs/v1.2.0/zephyr/include/arch/cpu.h:17,
1> from C:/Users/production/ncs/v1.2.0/zephyr/include/kernel_includes.h:34,
1> from C:/Users/production/ncs/v1.2.0/zephyr/include/kernel.h:17,
1> from C:/Users/production/ncs/v1.2.0/zephyr/arch/arm/core/offsets/offsets.c:25:
1> C:/Users/production/ncs/v1.2.0/zephyr/soc/arm/nordic_nrf/nrf52/soc.h:16:10: fatal error: nrfx.h: No such file or directory
1> compilation terminated.
Build failed
