To be able to have USB communication/interface, do I need to apply 5V to VBUS? Or will 3V on Vdd be enough. I am planning to use coin cell that is max rated for 4.2V so it won't be able to provide 5V.
But the USB itself will provide 5V - surely?
Have you read the USB section in the Product Specification?
https://infocenter.nordicsemi.com/topic/ps_nrf52840/usbd.html?cp=4_0_0_5_34
eg,
"The signal pins and the pull-up will operate only while VBUS is in its valid voltage range"
"The physical layer interface (PHY)/USB transceiver is powered separately from the rest of the device (VBUS pin)"
"Enable USBD after VBUS has been detected only"
etc, ...
Yes I have read the USV section, just wanted to make sure, thanks . The nRF will be used in portable device so won't have a USB cable connected so will need to have the coin cell supply.
1. Any documentation/resources you have for using a boost converter with the nRF?
2. How much power does the 5V take?
Thanks
If it doesn't have a USB cable connected, there's no point in enabling the USB - is there?!
And when there is a USB cable connected - it gives you the 5V !
For our application there is a point since one of our signals outputs using USB interface/protocol for communication which will feed into the BLE and then transmit
But if you have a USB connection, that must provide the 5V - that is part of the definition of USB!
