how can nrf51822 make 2.4G communication and BLE communication arbitrary switch?
Sligthly old blog post, but in principle should still be valid:
https://devzone.nordicsemi.com/nordic/nordic-blog/b/blog/posts/running-micro-esb-concurrently-with-ble
I got idea for switching between BLE and 2.4GHZ.But when i was disabled to softdevice using "sd_softdevice_disable()",the program come in "while (loop);". If i want to close the softdevice, what am i going to do? My idea is this code for switching between BLE and 2.4GHz. nrf_gpio_cfg_output(LED_BLE); //ble±êÖ¾
nrf_gpio_pin_write(LED_BLE, 0); //³õʼ״̬µçƽÀµÍʹ֮²»ÁÁ
nrf_gpio_cfg_output(LED_TXS); //2.4G±êÖ¾
nrf_gpio_pin_write(LED_TXS, 0); //³õʼ״̬µçƽÀµÍʹ֮²»ÁÁ
nrf_gpio_cfg_input(switch_24toble,NRF_GPIO_PIN_NOPULL);
ble_stack_init();
ble_app_cfg_start();
// Enter main loop.
for (;;)
pinvalue = nrf_gpio_pin_read(switch_24toble);
if (pinvalue == 1)
running_mode = BLE;
running_mode = GHZ;
power_manage();
if (running_mode != previous_mode)
previous_mode = running_mode;
if (running_mode == BLE)
AppTx_stop(); //Í£Ö¹·¢ËÍ£¬¿ªÊ¼ble
ble_stack_init();
else if (running_mode == GHZ)
//ble_app_cfg_stop();
ble_stack_stop(); //Í£Ö¹ble£¬×¢Òâֹͣ˳Ðò£»¿ªÊ¼2.4GHZ
esb_tx_init(); //³õʼ»¯·¢ËÍÅäÖÃ
ret = AppTx_Send((uint8_t *)buf,5); //·¢ËÍÒ»Ö¡¹Ì¶¨Ö¡£¬²âÊÔÓÃ
if (ret < 0)
ret = 0;
void ble_stack_stop(void)
uint32_t err_code;
err_code = softdevice_handler_sd_disable();
uint32_t softdevice_handler_sd_disable(void)
uint32_t err_code = sd_softdevice_disable();
#if 1
if (err_code == NRF_SUCCESS)
m_softdevice_enabled = false;
nrf_drv_clock_on_sd_disable();
#else
m_softdevice_enabled = !(err_code == NRF_SUCCESS);
return err_code;
ble_stack_init();
// Enter main loop.
for (;;)
if (pinvalue == 1)
running_mode = BLE;
running_mode = GHZ;
power_manage();
ble_stack_init();
if (ret < 0)
ret = 0;
uint32_t err_code;
#if 1
#else
return err_code;
}"2.4GHz" is just a frequency
BLE operates at 2.4GHz
So "switching between BLE and 2.4GHZ" means nothing.
You mean, "switching between BLE and a proprietary protocol"
Check out \examples\multiprotocol\ble_app_gzll
