BLE nus slow transmitting after being connected for a while
I have implemented BLE nus uart on my device and am getting some weird problems with the transfer speed.
When I connect to the device and transfer data via BLE nus to the mobile phone the data is transferred very quickly, however, if I keep the device connected for a while after connecting and then transferring data then the data is sent extremely slow. The same happens if I send data with BLE nus and then send again afterwards. I currently switch between slow and fast connection interval, could this be a problem? But, the weird thing is that when I connected to the device in the beginning and wait for a while it also happens when still on fast connection interval.
I currently am using sdk 15.0 with SD 6.0
    Changing the connection interval may affect the tranfer rate, but this is a quite complex topic. Check out the ble_app_att_mtu_throughput example to see how the connection parameters is affecting the transfer rate.
    Have you tried sniffing the connection using nRF Sniffer? Are there any connection parameter updates when the transfer rate is going slow? Is there anything changing from your application? Are you starting to send smaller packets? How do you queue the packets? Do you wait for one packet to be completed (TX COMPLETE) before queuing the next, or do you queue them as soon as you can, until it returns NRF_ERROR_RESOURCES?
    BR,
    Edvin
    Thank you for the immediate support!
    No, I haven't tried nRF sniffer as I currently only have one dev board that is in used already. Will check if I might have an extra that I could setup as a sniffer.
    As I do it currently is that whenever I receive an init package from the mobile app, I update the connection interval to fast instead of slow. Afterwards I start packaging data available on the nRF device and send it to the mobile phone. The data could sometime be large chunks but also small. The problem I've observed is that when starting the sending directly after connecting to the device it is much more faster than when sending again or waiting for a few minutes and then sending the data. If I have waited like for more than 4-5 minutes the device even freezes and I'll have to reset the device manually.
     You need to do some debugging to figure out whats going on here. Are you still connected after the freeze? (does the phone say that they are connected?)
    What does the call to ble_nus_data_send() return?
  • Hi Edvin,
    Yes it seem that the app still is waiting for the data to be sent and phone still appear as connected. To get the device out of the freeze i'll have to restart the device. I have checked the return status and it seem that sometimes it give 0x13(timeout?) and then we keep retrying until it gives us 0x0(success). The problem is that when we first send it, the transmission is extremely fast but after a while or during the second send it is very slow and laggy.
    What I have observed before the board freeze is that it successfully sends and then it freezes afterwards. I just want to mention that I have a second processor that is sending some UART data with the nrf ble module. Could is somehow cause any trouble? The second processor is sending data to the nrf module which then transfers it to the mobile.
     I don't know. You need to debug. When you "freeze", is the processor running, or has your application crashed? Have you tried to monitor the log from the nRF? Does it say anything when it freezes?
    Please check the return values for a given softdevice call. For ble_nus_data_send(), that would be sd_ble_gatts_hvx(). In ble_gatts.h you can see the possible return values.
    NRF_ERROR_TIMEOUT is 13 (0x0D), while NRF_ERROR_RESOURCES is 19 (0x13). You see the 19, right? So you get an NRF_ERROR_RESOURCES, meaning that the queue is full (which is a good thing if you try to send as much as possible because you have filled the queue.
    So let's try another approach then. What is the connection interval changed to after a while?
    To sum up.
    1: What happenes at the "freeze"?
    2: What is your connection interval "after a while"?
    And what are the actual rates that you are seeing? What determines how fast you are trying to send? The incoming UART? And how fast is that?
