How to get nodes' address in Mesh ?
Hi community !
Imagine this configuration :
A -> B -> C
So A can't directly communicate with C. I send a message from A to C (And only C), so this one with be relayed by B. On the status event (in A software) if i put :
p_meta->p_core_metadata->params.scanner.adv_addr.addr[0],
p_meta->p_core_metadata->params.scanner.adv_addr.addr[1],
p_meta->p_core_metadata->params.scanner.adv_addr.addr[2],
p_meta->p_core_metadata->params.scanner.adv_addr.addr[3],
p_meta->p_core_metadata->params.scanner.adv_addr.addr[4],
p_meta->p_core_metadata->params.scanner.adv_addr.addr[5]);
i will get the address of C. Is there a way to get all address of nodes which has relayed this message ? In my example, i will get B and C's address
Thanks
  • Hi Paul,
    It's not possible to get the address of all the nodes that have relayed the message to. This information is not included in mesh packet.
    In addition , this address you found is the BLE advertiser address, not the mesh address. It should comes from the neighbor node that relay the message. I 'm not sure why you receive the address of C, most likely you have direct range between A and C.
