Hello
Using PCA10040 dev board,
Building with SDK 16, & S112 - using ses
Running ..\examples\dfu\secure_bootloader\pca10040_uart_debug
Using nrfutil to download my package via serial port - all looks good ( package is just app hex file)
via RTT see following from dev board
<info> app: Inside main
<warning> nrf_dfu_settings: Resetting bootloader settings since neither the settings page nor the backup are valid (CRC error).
<info> nrf_dfu_settings: Backing up settings page to address 0x7E000.
<info> app: No firmware to activate.
<info> app: Boot validation failed. No valid app to boot.
<info> nrf_bootloader_wdt: WDT is not enabled
<info> app: Entering DFU mode.
<info> nrf_dfu_serial_uart: Allocated buffer 200016F0
<info> nrf_dfu_serial_uart: Allocated buffer 20001774
<info> nrf_dfu_validation: Signature required. Checking signature.
<info> nrf_dfu_validation: Calculating hash (len: 65)
<info> nrf_dfu_validation: Verify signature
<info> nrf_dfu_validation: Image verified
<info> nrf_dfu_settings: Backing up settings page to address 0x7E000.<info> app: Inside main
<warning> nrf_dfu_settings: No additional data erased
All was going so well... why do I get No Firmware to activate?
My app is modified version of "..\examples\peripheral\twi_scanner\pca10040"
My app runs ok on its own - via debugger or if flashed to board
What are the tricks to get to run with boot-loader? dfu etc?
Thank you
Used:
nrfutil pkg generate --hw-version 52 --sd-req 0xCD --application-version-string 1.01.01 --application my_scanner_pca10040.hex --key-file private.pem my_scanner_pca10040.zip
nrfutil dfu serial -pkg my_scanner_pca10040.zip -p com13 -t 3
