1. I am using a boost to power the USBD since I am using coin cell to power the whole system, what minimum and maximum supply current is needed/can be handled?
2. What boost converter would you recommend
Not sure why you want to boost the voltage from a coin cell to power the VBUS pin. This is only needed of you're using the USB interface, and will get power from the USB host anyway
Thats not the case for me, I will only be provided with a D+ and D- signal from an external chip that I need to connect here. Since the host is not providing the voltage, I need to figure that out myself os I am asking how I could use the coin cell. Is the USB draw the 2.4 mA listed on pg 569?
Yes, correct.
Note that the nRF52850 us a USB device only and can not be a host.
Sorry, I did not understand what you mean, I could feed the USB data I get into the 52840 and transmit it, right? SInce the external chip is not providing the voltage for the VNUS, that's all I need to make sure I have with a boost
Yes, the USB interface i bidirectional. But there's a difference between a host and a device. A host is usually a PC and is part of the link that initiates all communication on the bus. A device is the "slave", than can be a mouse, keyboard or whatever. A device can not communicate with another device, only a host. The nRF52840 can only be a device.
But if the chip you have can act as a host, all of good. You only need to boost the battery voltage to supply the VBUS pin.Just about anything goes here, there are tons of boost regulators around.
