Coap response error
I have a problem with coap response. I use iot coap library.
Client send nonconfirmable coap message with payload to broadcast addr
Server get payload and send nonconfirmable response without payload to p_message.remote address.
Server use message id and token from request but client dont get response.
I was seen the request and response from server on nrf sniffer but client dont get the response, but cames response error.
Can you help me find problem?
Thank you.
Frantisek
  • Hi, based on the sniffer log you sent I thought you were developing with Thread, since it says 802.15.4, but now I'm not so sure. The functions you are using in your code come from the BLE IoT library. So are you using the BLE based IoT library?
    If so, can you post the output of "ifconfig" and specifically check if the bt0 interface has gotten a global IP? Also, have you installed radvd so the global IP is given to the client?
    Also please describe the whole setup. Which protocol you're developing on, which libraries, what type of hardware, DKs, computers, servers, etc... Thanks a lot!
  • I use library from: nRF5_SDK_for_Thread_and_Zigbee_v4.1.0_32ce5f8\components\iot\coap
    I use Thread but I communicate point to point without border router
    I use nRF52840 specifically Fanstel BT840F
  • I try to send multicast message for link-local scope and I need to know that at least 1 node get the message.
    client                              ->                              server
    multicast NONconfirmable request
    server                             ->                              client
    unicast NONconfirmable response, the same token, different message ID
    is it the coorect design?
    This is pattern for message exchange.
    Message ID is different but token is the same.
    If a request is sent in a Non-confirmable message, then the response is sent using a new Non-confirmable message, although the server may instead send a Confirmable message. This type of exchange is illustrated in Figure 6. Client Server | | | NON [0x7a11] | | GET /temperature | | (Token 0x74) | +----------------->| | | | NON [0x23bc] | | 2.05 Content | | (Token 0x74) | | "22.5 C" | |<-----------------+ | | Figure 6: A Request and a Response Carried in Non-confirmable Messages
    https://tools.ietf.org/html/rfc7252#section-2.2
    Sorry for the delay.
    So you are not using Thread, then? The coap module from components\iot\coap is not part of Thread nor Zigbee (and it is actually removed/deprecated in the latest SDK, SDK17). The 802.15.4 drivers that are used in Thread in the Thread and Zigbee SDK is found in SDK\external\nRF-IEEE-802.15.4-radio-driver, but the coap used in this SDK is part of the openthread library.
    I am struggling to understand your actual issue. Is it that the message ID is different from the request to the response? (the "get temperature" message and reply message with the temperature?)
    If so, I can try to ask our Thread and Zigbee team, but they are typically not that familiar with the "iot" module, as this is old and was never actually finished.
    Edvin
  • I must use IOT module because I use DFU OTA modul and it has problem with default coap library
