Coap response error
I have a problem with coap response. I use iot coap library.
Client send nonconfirmable coap message with payload to broadcast addr
Server get payload and send nonconfirmable response without payload to p_message.remote address.
Server use message id and token from request but client dont get response.
I was seen the request and response from server on nrf sniffer but client dont get the response, but cames response error.
Can you help me find problem?
Thank you.
Frantisek
  • void coap_pir_send_request(uint8_t state)
        coap_message_t       * p_request;
        coap_message_conf_t   message_conf;
        coap_remote_t         remote_device;
        uint32_t              err_code;
        memset(&message_conf, 0, sizeof(message_conf));
        message_conf.type             = COAP_TYPE_NON;
        message_conf.code             = COAP_CODE_GET;
        message_conf.port.port_number = COAP_PORT;
        message_conf.id               = coap_header_message_id++;
        (void)uint16_encode(HTONS(coap_header_token), message_conf.token);
        coap_header_token++;
        message_conf.token_len = sizeof(coap_header_token);
        message_conf.response_callback = coap_pir_response_callback;
        err_code = coap_message_new(&p_request, &message_conf);
        //TODO leader address
        //fde5:8dba:82e1:1::ff:fe00:fc00
        err_code = otIp6AddressFromString((char *)"ff03::1", (otIp6Address *)&remote_device.addr[0]);
        ASSERT(err_code == OT_ERROR_NONE);
        remote_device.port_number = COAP_PORT;
        err_code = coap_message_remote_addr_set(p_request, &remote_device);
        err_code = coap_message_opt_str_add(p_request, COAP_OPT_URI_PATH, (uint8_t *)"pir", 3);
        err_code = coap_message_payload_set(p_request, &state, sizeof(state));
        uint32_t handle;
        NRF_LOG_INFO("send coap message pir state");
        err_code = coap_message_send(&handle, p_request);
        if (err_code != NRF_SUCCESS)
            NRF_LOG_ERROR("CoAP Message skipped, error code = 0x%08lX.", err_code);
        err_code = coap_message_delete(p_request);
        //TODO led
        //nrf_gpio_pin_toggle(12);
    void coap_pir_response_callback(uint32_t status, void * p_arg, coap_message_t * p_message)
        NRF_LOG_INFO("coap pi response callback ---------------");
        if(status == NRF_SUCCESS)
            NRF_LOG_INFO("pir response");
            coap_pir_msg_resend = 0;
            NRF_LOG_INFO("response error");
            if(coap_pir_msg_resend++ < COAP_PIR_MSG_MAX_RESEND)
                coap_pir_send_request(coap_pir_last_state);
                NRF_LOG_INFO("error: no response from lamp");
    client code
    void coap_pir_request_callback(coap_resource_t * p_resource, coap_message_t * p_request)
        coap_message_conf_t pir_response_config;
        NRF_LOG_INFO("coap pir rq callback");
        //evaluate pir request
        if(use_pir_messages)
            if(p_request->p_payload[0] == 1)
                //movement stop
                pir_set_lc_pin(1);
                //movement start
                pir_set_lc_pin(0);
        if (p_request->header.type == COAP_TYPE_NON)
            pir_response_config.type = COAP_TYPE_NON;
        else if (p_request->header.type == COAP_TYPE_CON)
            pir_response_config.type = COAP_TYPE_ACK;
        pir_response_config.id = p_request->header.id;
        pir_response_config.code = COAP_CODE_204_CHANGED;
        pir_response_config.port.port_number = COAP_PORT;
        pir_response_config.token_len = p_request->header.token_len;
        memcpy(&pir_response_config.token[0], &p_request->token[0], p_request->header.token_len);
        coap_pir_response_send(pir_response_config, p_request->remote);
    void coap_pir_response_send(coap_message_conf_t message_conf, coap_remote_t remote_address)
        coap_message_t * p_response;
        uint32_t msg_handle;
        uint32_t err_code = coap_message_new(&p_response, &message_conf);
        err_code = coap_message_remote_addr_set(p_response, &remote_address);
        err_code = coap_message_send(&msg_handle, p_response);
        NRF_LOG_INFO("sen pir resp %d", err_code);
        NRF_LOG_INFO("sended coap message pir response");
        err_code = coap_message_delete(p_response);
    //---------------------------- coap mod_mes messages ---------------------------
    void coap_mod_msg_request_callback(coap_resource_t * p_resource, coap_message_t * p_request)
    //TODO
        //save info about peer
        response_config.code = COAP_CODE_205_CONTENT;
        memcpy(&response_config.token[0], &p_request->token[0], p_request->header.token_len);
        remote = p_request->remote;
        if(memcmp(p_request->p_payload, modbus_cmd_hello_get_lcid, p_request->payload_len) == 0)
            address_state = ADDRESS_STATE_LCID_NOT_SEND;
            coap_mod_msg_response_send(NULL, 0);
            modbus_lc_request(p_request->p_payload, p_request->payload_len);
        NRF_LOG_INFO("received data, len: %d",p_request->payload_len);
    void coap_mod_msg_response_send(uint8_t* data, uint16_t size)
        uint32_t err_code = coap_message_new(&p_response, &response_config);
        err_code = coap_message_remote_addr_set(p_response, &remote);
    	if(size < 0 || data != NULL)
            err_code = coap_message_payload_set(p_response, data, size);
        NRF_LOG_INFO("response send, size of send %d", size);
        NRF_LOG_INFO("error %d: ", err_code);
        //APP_ERROR_CHECK(err_code);
        NRF_LOG_INFO("sended coap message mod_msg response");
    //---------------------------- coap address messages ---------------------------
    void coap_address_send_request(uint16_t lcid)
        uint32_t              err_code;
        message_conf.response_callback = coap_address_response_callback;
        err_code = coap_message_opt_str_add(p_request, COAP_OPT_URI_PATH, (uint8_t *)"adr", 3);
        err_code = coap_message_payload_set(p_request, &lcid, sizeof(uint16_t));
        uint32_t handle;
        NRF_LOG_INFO("send coap message lcid");
        //TODO led
    void coap_address_response_callback(uint32_t status, void * p_arg, coap_message_t * p_message)
            address_state = ADDRESS_STATE_UP_TO_DATE;
            addresses.ipv6 = get_my_actual_ip6_addr();
            NRF_LOG_INFO("addr response------PAUSE----");
    server code
  • Maybe you can share the sniffer log? Do the issue only occur with empty payload in the response, or does it also happen if you piggy back the response? Try to memset(&pir_response_config, 0x00, sizeof(coap_message_conf_t));
    Is the status code COAP_TRANSMISSION_RESET_BY_PEER or COAP_TRANSMISSION_TIMEOUT?
  • I try add payload and  memset(&pir_response_config, 0x00, sizeof(coap_message_conf_t));  but it not helped.
    status code: COAP_TRANSMISSION_TIMEOUT
    #define COAP_MAX_TRANSMISSION_SPAN 2
    #define COAP_MAX_RETRANSMIT_COUNT 0
    pir_communication.pcapng
    in this capture I send frist request and cca after 10 seconds second request.
  • Are you using the open thread border router? Can you try to do log the traffic using tcp dump, something like:
    tcpdump -i INTERFACE_NAME ip6
    The we can see if the packets have the correct destination address.
  • I dont use openthread border router. Is exist different way to capture this packets?
