NRF52840 LATCH always set no matter which pin causes the wake up
Hi I'm using the PCA10056 DK and ran into an issue. I can configure the nrf52 to wake up using input pins(although some pins can't wake it up for some reason), however, when it wakes up, all the bits that correspond to pins that can wake up the MCU is set no matter which pin actually causes it. I have attached my source code below:
 * Copyright (c) 2016 - 2019, Nordic Semiconductor ASA
 * All rights reserved.
#include <stdint.h>
#include "app_error.h"
#include "ble.h"
#include "ble_hci.h"
#include "fds.h"
#include "nordic_common.h"
#include "nrf.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_soc.h"
#include "nrf_nvic.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_delay.h"
#include "ble_module.hpp"
#include "advertising_module.hpp"
#include "connection_module.hpp"
#include "gatt_module.hpp"
#include "gap_module.hpp"
#include "peer_manager_handler.h"
#include "pm_module.hpp"
#include "bms_module.hpp"
#include "qwr_module.hpp"
#include "bas_module.hpp"
#include "timetable_service_module.hpp"
#include "adc_module.hpp"
#include "power_module.hpp"
#include "computer_switch_module.hpp"
#include "rv3028.hpp"
#include "twi_module.hpp"
#include "state_machine.hpp"
#include "misc_module.hpp"
/**@brief Callback function for asserts in the SoftDevice.
 * @param[in]   line_num   Line number of the failing ASSERT call.
 * @param[in]   file_name  File name of the failing ASSERT call.
void assert_nrf_callback(uint16_t line_num, const uint8_t* p_file_name) {
  NRF_LOG_FINAL_FLUSH();
  //!< Value used as error code on stack dump, can be used to identify stack location on
  //!< stack unwind.
  app_error_handler(0xDEADBEEF, line_num, p_file_name);
// TODO(khoi): Remove this after development is done
#pragma GCC diagnostic ignored "-Wunused-function"
// void testFunc() { SEGGER_SYSVIEW_RecordU32(0 + testModule.EventOffset, 5); }
// NOTE: SOME PINS CAN'T WAKE UP THE CPU
constexpr nrfx_gpiote_pin_t COMPUTER_SWITCH_PIN     = NRF_GPIO_PIN_MAP(0, 9);
constexpr nrfx_gpiote_pin_t USER_INPUT_PIN          = NRF_GPIO_PIN_MAP(0, 3);
constexpr nrfx_gpiote_pin_t RTC_INTERRUPT_INPUT_PIN = NRF_GPIO_PIN_MAP(0, 2);
constexpr nrfx_gpiote_pin_t RTC_TIME_STAMP_PIN      = NRF_GPIO_PIN_MAP(0, 10);
constexpr nrfx_gpiote_pin_t RESET_PIN               = NRF_GPIO_PIN_MAP(0, 13);
void configure_reset_pin() {
  nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_HITOLO(false);
  in_config.pull                       = NRF_GPIO_PIN_PULLUP;
  const auto err_code = nrf_drv_gpiote_in_init(
      RESET_PIN, &in_config, [](nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action) {
        nrf_drv_gpiote_in_event_disable(RESET_PIN);
        ble::pm::delete_all_bonds_unsafe();
        sd_nvic_SystemReset();
  nrf_drv_gpiote_in_event_enable(RESET_PIN, true);
// APP_TIMER_DEF(m_timer_id);
int main(void) {
    const auto err_code = NRF_LOG_INIT(NULL);
  auto err_code = nrf_pwr_mgmt_init();
    const auto err_code = nrf_drv_gpiote_init();
  configure_reset_pin();
  // need to initialize but not call nrf_drv_gpiote_in_event_enable otherwise
  // latch clear doesn't seem to work
    const auto err_code = nrf_drv_gpiote_in_init(RTC_INTERRUPT_INPUT_PIN, &in_config, nullptr);
    nrf_drv_gpiote_in_event_disable(RTC_INTERRUPT_INPUT_PIN);
    const auto err_code = nrf_drv_gpiote_in_init(USER_INPUT_PIN, &in_config, nullptr);
    nrf_drv_gpiote_in_event_disable(USER_INPUT_PIN);
  if (nrf_gpio_pin_latch_get(USER_INPUT_PIN)) { NRF_LOG_INFO("user input latch set"); }
  if (nrf_gpio_pin_latch_get(RTC_INTERRUPT_INPUT_PIN)) { NRF_LOG_INFO("rtc interrupt latch set"); }
  if (nrf_gpio_pin_latch_get(RESET_PIN)) { NRF_LOG_INFO("reset latch set"); }
  NRF_GPIO->LATCH = NRF_GPIO->LATCH;
  // give the latch some time to clear
  NRF_LOG_INFO("Yo");
  NRF_LOG_INFO("Yo");
  NRF_LOG_INFO("Yo");
  NRF_LOG_INFO("Yo");
  NRF_LOG_FLUSH();
  while (nrf_gpio_pin_latch_get(USER_INPUT_PIN) ||
    // make sure the latch is cleared
  NRF_LOG_INFO("Preparing to Sleep");
  NRF_LOG_FLUSH();
  nrf_drv_gpiote_in_event_enable(RTC_INTERRUPT_INPUT_PIN, true);
  nrf_drv_gpiote_in_event_enable(USER_INPUT_PIN, true);
    auto err_code = nrf_sdh_enable_request();
    uint32_t ram_start;
    err_code = nrf_sdh_ble_default_cfg_set(1, &ram_start);
    NRF_SDH_BLE_OBSERVER(m_ble_observer, 3, nullptr, NULL);
    ble_opt_t opt;
    memset(&opt, 0x00, sizeof(opt));
    opt.common_opt.conn_evt_ext.enable = 1;
    err_code = sd_ble_opt_set(BLE_COMMON_OPT_CONN_EVT_EXT, &opt);
  sd_power_system_off();
  while (1) {
    // in debug mode, sleep is emulated
    Did you confer with the Pin Assignment for the nRF52840 SoC before choosing which pins to use?
    For example, the pins 0.09 and 0.10 are connected to the NFC antenna by default. You may use these, but it would require some hardware changes.
    Which other pins did you attempt to use for the reset?
    Please elaborate on what bits you are referring to, and how this differs from your expectations.
    Karl
    Thank you for the fast response. I'm using pin 2, 3, 13 of port 0 to wake up the processor(I have attempted to use pin 20, 22 of port 0 to wake it up before but doesn't work). When the processor wakes up the value of the latch register is always 0x200C instead of just having one bit set for the pin that wakes it up(for example, 0x0004 for pin 2 causing the wake up).
    No problem at all, I am happy to help!
    Did you check the pins configuration on the DK? If you see the back of the DK, they are by default wired for the QSPI peripheral. You should see the Solder Bridge Configuration documentation for more information about the solder bridges on the nRF52840 DK.
    When you say wakes up, what sleepmode are you referring to? SYSTEM_OFF or a SYSTEM_ON_*?
    Have you seen this errata for the nRF52840? It might be what you are experiencing, in combination with the need to explicitly clear LATCH registers. An exempt from the documentation reads:
             The LATCH register will only be cleared if the CPU explicitly clears it by writing a '1' to the bit that shall be cleared, i.e. the LATCH register will not be affected by a PINx.DETECT signal being set low.
    Karl
    Thank you, I wasn't aware that those pins were used for the QSPI.
    This is for waking up from a SYSTEM_OFF. I don't do the register manipulation directly but used the nrf sdk functions for it, do you think that could cause it? I also clear the latch register as recommended before every sleep. This is how I initialize the GPIO and clear the latch register as well as sleep, the full code should be in the main post:
    sd_power_system_off(); // sleep
    No problem at all. They are quick to overlook!
    I do not think that the use of nrf sdk functions would cause this, but I am not personally familiar with using them as part of a cpp program - though I do not suppose that should matter.
    Could you verify that the DETECT signal is in fact low before the clearing of the latch register?
    What is the value of the LATCH register before and after the clearing operation?
            If the CPU performs a clear operation on a bit in the LATCH register when the associated PINx.DETECT signal is high, the bit in the LATCH register will not be cleared.
    By the way, have you seen the reply by my colleague to this ticket?
    Looking forward to solving this issue together,
    Karl
