Adding an SMA connector to the ISP-1507-AX Test Board
Looking at the schematic diagram of the ISP-1507-AX Test Board….
www.insightsip.com/.../ISP1507_AX_TB_Schematic.pdf
… I can see that there is the possibility to connect and SMA connector, which is great news, because this is what we want to do.
However, on the image of PCB itself in the Evaluation Board application note here….
www.insightsip.com/.../isp_ble_AN160601.pdf
…. I cannot see where the SMA connector should be connected.
Can you please explain where the SMA connector should be connected. Does it connect directly to the Board, or is it supposed to be connected via a coaxial cable?
