IAR I-Jet Debugging Won't Run
I can't get a simple application, no soft device, to debug on the nRFDK 10028 board using the I-Jet. I am using the debug in and powering the device from an external power supply at 3.0V.
When I start the debug session I get the following in the debug console window.
Mon Mar 23, 2015 11:18:48: Loading the I-jet/JTAGjet driver
Mon Mar 23, 2015 11:18:48: Probe: Probe SW module ver 1.40
Mon Mar 23, 2015 11:18:48: Probe: Option: trace(Auto,size_limit=8M)
Mon Mar 23, 2015 11:18:48: Probe: I-jet-Trace SW module ver 1.31
Mon Mar 23, 2015 11:18:48: Probe: Found I-jet, SN=79707
Mon Mar 23, 2015 11:18:48: Probe: Opened connection to I-jet:79707
Mon Mar 23, 2015 11:18:48: Probe: USB connection verified (6581 packets/sec)
Mon Mar 23, 2015 11:18:48: Probe: I-jet, FW ver 4.2, HW Ver:A
Mon Mar 23, 2015 11:18:48: Probe: None or IJET-MIPI10 adapter detected
Mon Mar 23, 2015 11:18:48: Probe: Versions: JTAG=1.64 SWO=1.31 A2D=1.58 Stream=1.40
Mon Mar 23, 2015 11:18:48: EARM v.3.72
Mon Mar 23, 2015 11:18:48: Emulation layer version 3.72
Mon Mar 23, 2015 11:18:49: SWD clock detected: 12MHz
Mon Mar 23, 2015 11:18:49: Connected DAP on SWD. Detected IDCODE=0xbb11477.
Mon Mar 23, 2015 11:18:49: Connecting Cortex-M core ID = 0x4770021 on DAP port 0
Mon Mar 23, 2015 11:18:49: Recognized CPUID=0x410cc200 Cortex-M0 r0p0 arch ARMv6-M
Mon Mar 23, 2015 11:18:49: Debug resources: 4 instruction comparators, 2 data watchpoints.
Mon Mar 23, 2015 11:18:49: CPU status OK
Mon Mar 23, 2015 11:18:49: INFO: Configuring trace using 'Auto,size_limit=8M' setting ...
Mon Mar 23, 2015 11:18:49: CPU does not have TPIU - SWO cannot be enabled
Mon Mar 23, 2015 11:18:49: LowLevelReset(system, delay 200)
Mon Mar 23, 2015 11:18:49: CPU status - IN RESET
Mon Mar 23, 2015 11:18:50: Loaded debugee: C:\dbeckwith\Depot\650_NG\Debug\Exe\c.out
Mon Mar 23, 2015 11:18:50: The downloaded program doesn't seem to match the expected memory layout of the target system:
Mon Mar 23, 2015 11:18:50: Some SFRs are placed outside known memory areas, or in memory areas designated as read-only    or    as RAM:
Mon Mar 23, 2015 11:18:50:   POWER__TASKS_CONSTLAT @ 0x40000078, 32 bits
Mon Mar 23, 2015 11:18:50:   POWER__TASKS_LOWPWR @ 0x4000007C, 32 bits
Mon Mar 23, 2015 11:18:50:   POWER__EVENTS_POFWARN @ 0x40000108, 32 bits
Mon Mar 23, 2015 11:18:50:   POWER__INTENSET @ 0x40000304, 32 bits
Mon Mar 23, 2015 11:18:50:   POWER__INTENCLR @ 0x40000308, 32 bits
Mon Mar 23, 2015 11:18:50:   and more...
Mon Mar 23, 2015 11:18:50: Memory is specified as follows:
Mon Mar 23, 2015 11:18:50:   0x00000000 - 0x0003FFFF  ROM/Flash
Mon Mar 23, 2015 11:18:50:   0x10000000 - 0x100003FF  ROM/Flash
Mon Mar 23, 2015 11:18:50:   0x10001000 - 0x100013FF  ROM/Flash
Mon Mar 23, 2015 11:18:50:   0x20000000 - 0x20007FFF  RAM
Mon Mar 23, 2015 11:18:50:   0x40000000 - 0x4001FFFF  RAM
Mon Mar 23, 2015 11:18:50:   0x50000000 - 0x50000FFF  RAM
Mon Mar 23, 2015 11:18:50:   0xE0000000 - 0xE00FFFFF  Uncached/SFR
Mon Mar 23, 2015 11:18:50: SFRs range from 0x10000010 to 0xE00FFFFF
Mon Mar 23, 2015 11:18:50: Download error at 0x00000000: downloading into non-writable memory.
Mon Mar 23, 2015 11:18:50: 1192 bytes downloaded (116.41 Kbytes/sec)
Mon Mar 23, 2015 11:18:50: Warning: Cannot measure current when I-jet is not powering the target.
Mon Mar 23, 2015 11:18:50: Download completed.
Mon Mar 23, 2015 11:18:50: LowLevelReset(software, delay 200)
Mon Mar 23, 2015 11:18:50: Target reset
Mon Mar 23, 2015 11:18:50: There were 6 warnings during the initialization of the debugging session.
Mon Mar 23, 2015 11:18:50: CPU status - SLEEPING
Mon Mar 23, 2015 11:18:50: CPU status OK
