Hey all,
I've been bringing up the nRF9160 Feather and noticed some curious issues with adding an external partition when MCUboot is enabled.
I first tested the external chip without MCUboot using the example provided at this path: ncs/zephyr/samples/subsys/fs/littlefs
The tests passed with an .overlay file like so:
/delete-node/ &storage_partition;
&w25q16jv {
partitions {
#address-cells = <1>;
#size-cells = <1>;
storage_partition: partition@0 {
label = "storage";
reg = <0x00000000 0x00010000>;
Now I'm trying to merge together the MCUboot + External LittleFS into one app.
My prj.conf looks like so:
# Note: fs_dirent structures are big. CONFIG_MAIN_STACK_SIZE=2048 # Print a banner on the UART on startup. CONFIG_BOOT_BANNER=y # Enable console and printk() CONFIG_PRINTK=y CONFIG_STDOUT_CONSOLE=y # Let __ASSERT do its job CONFIG_DEBUG=y CONFIG_LOG=y # Enable Zephyr application to be booted by MCUboot CONFIG_BOOTLOADER_MCUBOOT=y # Adding Peripherals CONFIG_GPIO=y # CONFIG_I2C=y # CONFIG_I2C_2=y # SPI Related CONFIG_SPI=y CONFIG_SPI_NOR=y CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096 # Enable flash operations. CONFIG_FLASH=y CONFIG_FLASH_MAP=y CONFIG_FLASH_PAGE_LAYOUT=y # CONFIG_MPU_ALLOW_FLASH_WRITE=y # Note: only necessary for internal flash # Nordic specific external flash stuff CONFIG_PM_EXTERNAL_FLASH=y CONFIG_PM_EXTERNAL_FLASH_DEV_NAME="w25q16jv" CONFIG_PM_EXTERNAL_FLASH_BASE=0x0 CONFIG_PM_EXTERNAL_FLASH_SIZE=0x1000000 # Enable the LittleFS file system. CONFIG_FILE_SYSTEM=y CONFIG_FILE_SYSTEM_LITTLEFS=y
After some serious searching, I found there was some documentation related to external flash plus Nordic's partition manager. I was able to get the external flash to show up in the devicetree_legacy_unfixed.h
It's not quite clear to me where the devicetree ends and the partition manager begins. Here's some output from my app versus the example code:
*** Booting Zephyr OS build v2.1.99-ncs1-2955-ge34f48a24ac4 ***
Hello World from Zephyr on circuitdojo_feather_nrf9160!
Area 6 at 0x10200 on NRF_FLASH_DRV_NAME for 478720 bytes
FAIL: mount id 6 at /lfs: -22
[00:00:00.017,028] .[0m<inf> littlefs: LittleFS version 2.2, disk version 2.0.[0m
[00:00:00.017,150] .[0m<inf> littlefs: FS at NRF_FLASH_DRV_NAME:0x10200 is 116 0x1000-byte blocks with 512 cycle.[0m
[00:00:00.017,150] .[0m<inf> littlefs: sizes: rd 16 ; pr 16 ; ca 64 ; la 32.[0m
[00:00:00.017,242] .[1;31m<err> littlefs: WEST_TOPDIR/modules/fs/littlefs/lfs.c:998: Corrupted dir pair at {0x0, 0x1}.[0m
[00:00:00.017,242] .[1;33m<wrn> littlefs: can't mount (LFS -84); formatting.[0m
[00:00:00.017,303] .[1;31m<err> littlefs: format failed (LFS -22).[0m
[00:00:00.017,303] .[1;31m<err> fs: fs mount error (-22).[0m
My code (which is some of the early bits of the LittleFS example)
*** Booting Zephyr OS build v2.1.99-ncs1-2955-ge34f48a24ac4 *** Area 6 at 0x0 on W25Q16JV for 65536 bytes /lfs mount: 0 /lfs: bsize = 16 ; frsize = 4096 ; blocks = 16 ; bfree = 14 /lfs/boot_count stat: 0 .fn 'boot_count' siz 4 /lfs/boot_count read count 10: 4 /lfs/boot_count seek start: 0 /lfs/boot_count write new boot count 11: 4 /lfs/boot_count close: 0 /lfs opendir: 0 F 4 boot_count End of files /lfs unmount: 0 [00:00:00.011,108] .[0m<inf> littlefs: LittleFS version 2.2, disk version 2.0.[0m [00:00:00.011,138] .[0m<inf> littlefs: FS at W25Q16JV:0x0 is 16 0x1000-byte blocks with 512 cycle.[0m [00:00:00.011,169] .[0m<inf> littlefs: sizes: rd 16 ; pr 16 ; ca 64 ; la 32.[0m [00:00:00.016,601] .[0m<inf> littlefs: /lfs mounted.[0m [00:00:00.057,830] .[0m<inf> littlefs: /lfs unmounted.[0m
You can see it's referencing the correct ID but not the rest of the correct info. (Like the mount point, name, size, etc)
Any help is appreciated!
