I have just started with nRF51 DK using Keil uVision and encountered a strange problem. I compiled and loaded a ble_app_hrs example, I can see it working fine (the LED flashes every 2 seconds or so). I want to debug the example to see the flow of the program. And here I have a strange problem - after the program catches the breakpoint it's usually no longer running after I press Run. Sometimes after the breakpoint catches I am able to do 2 or 5 or even 20 steps, but then it does not respond again. I set the breakpoint in the periodic function heart_rate_meas_timeout_handler. It stops immediately after running the debug session, and when I click Run it never cacthes again. As I said, I am only able to do a couple of steps more after the breakpoint and at some point the program won't stop again. Any ideas what is causing the problem?
