nrf52840 usb_msc demo windos10 Home Edition USB disk will be lost in about 20 minutes
I used usb_msc with nRF5SDK160098a08e2 sdk to connect the usb of pca10056 development board to win10 home version and the disk could not be recognized after about 20 minutes;
1. Current test conclusion:
 1) Appears only in win10 home edition, not in win10 professional edition;
 2) Use the Debug mode, the optimization level is set to None, the disk is displayed for 20 minutes after mounting, and the disk is not lost. When entering the secondary folder to write the file, the file cannot be written, and finally the disk is lost;
2. Test procedures
nRF5SDK160098a08e2-new-2.rar
3. Problem phenomenon
1) When the USB is connected to the computer
2) The disk is lost in about 20 minutes
4. Test method
1) Burn the compiled program
2) USB connection to win10 home version computer
2) Create TEST1/TEST2/test.txt
3) Write the current time in the test.txt file every 10 minutes;
4) After a few times you will find that the file cannot be written;
5) The disk has been lost;
5. The compiled hex file is convenient for you to quickly reproduce the problem;
 2425.usbd_msc_pca10056.hex
  • Hi Edvin:
    1. Log log test conclusion:
        1) The log information of USB disk loss is not recorded in the simulation state;
    2. The original log information is as follows:
    [00:00:00.000,000] <info> app: app started ....
    [00:00:00.000,000] <info> app_timer: RTC: initialized.
    [00:00:00.000,000] <info> app: Initializing disk 0 (QSPI)...
    [00:00:00.000,000] <error> app: Disk initialization failed.... == 0
    [00:00:00.000,000] <info> app: Mounting volume...
    Listing directory: /
    <DIR> TEST1
    <DIR> System Volume Information
    Entries count: 3
    Creating random file: 000041c6.txt ...done
    [00:00:00.000,000] <info> app: USBD MSC example started.
    [00:00:00.000,000] <info> app: USB power detected
    [00:00:00.000,000] <info> app: Un-initializing disk 0 (QSPI)...
    [00:00:00.000,000] <info> app: USB ready
    3. Repeat the phenomenon of disk loss:
        1) After the program runs for 20 minutes, it is normal to refresh the disk and open the 4511.txt file in the disk;
        2) When writing data to the disk, the display cannot be saved, and finally it shows that it cannot respond;
       3) The disk is being refreshed at this moment, the disk has been lost;
    4. Personal advice:
        1) The efforts I can make on this side may not be able to advance anymore, I hope the original factory can actively cooperate and give help;
    I still haven't been able to reproduce the issue. I tried at home today, but my computer has Windows 10 Home Edition 1909, and as you claim, the issue is not present there. I have forwarded the question to our usb driver team. They also don't have a home edition license in the office, but they will look into it. I will let you know when I hear anything. Hopefully next week.
    Edvin
  • Hi Edvin,
      We have already started preparations for alternatives, I hope you can characterize the problem as soon as possible, thank you!
    This is the response I received from the USB driver team:
    Considering that this issue is only reproducible on two versions of Windows Home, it will not be trivial to set the environment up.
    But we could start from trying to debug it on clients’ setup – could you ask him to enable logging (specifically ones in USB MSC class), preferably using RTT as the amount could be overwhelming. It is possible that Windows sends an MSC command that is unsupported, which would result in this log:
    NRF_LOG_DEBUG("CMD: UNSUPPORTED");
    Even better if they could print the value of p_msc_ctx->cbw.cdb[0] in that log.
    If the client has a USB analyzer, bus activity logs would be greatly appreciated too.
    Can you please try to enable the logging on the USB MSC class?
    Do you have access to a USB analyzer? If so, can you please try to capture a USB trace?
    Edvin
  • Hi Edvin:
    1. First, we open the log of the USB part and continue the test;
    2. There is no USB logic analysis. How to use USB hound to monitor events;
