Hi. I tried to add rel_humidity_measurement cluster to multisensor example. New cluster is visible , but i cant get humidity data report I used cli exemple, here are logs:
zigbee.report: Received value updates from the remote node 0x07EF
zigbee.report: Profile: 0x0104 Cluster: 0x0402 Attribute: 0x0000 Type: 41 Value: 4000
zcl subscribe on f4ce361cf4681e64 10 0405 0104 0 41
Error: Unable to configure attribute 0 reporting. Status: 141
Error: One or more attributes reporting were not configured successfully
Here is my code ZB_MULTI_SENSOR.H
#ifndef ZB_MULTI_SENSOR_H__
#define ZB_MULTI_SENSOR_H__
#include "zboss_api.h"
#include "zboss_api_addons.h"
#include "zb_zcl_pressure_measurement.h"
#include "zb_zcl_rel_humidity_measurement.h"
#ifdef __cplusplus
extern "C" {
/* Basic cluster attributes initial values. For more information, see section 3.2.2.2 of the ZCL specification. */
#define SENSOR_INIT_BASIC_APP_VERSION 01 /**< Version of the application software (1 byte). */
#define SENSOR_INIT_BASIC_STACK_VERSION 10 /**< Version of the implementation of the Zigbee stack (1 byte). */
#define SENSOR_INIT_BASIC_HW_VERSION 11 /**< Version of the hardware of the device (1 byte). */
#define SENSOR_INIT_BASIC_MANUF_NAME "Custom" /**< Manufacturer name (32 bytes). */
#define SENSOR_INIT_BASIC_MODEL_ID "Multisensor" /**< Model number assigned by the manufacturer (32-bytes long string). */
#define SENSOR_INIT_BASIC_DATE_CODE "20200603" /**< Date provided by the manufacturer of the device in ISO 8601 format (YYYYMMDD), for the first 8 bytes. The remaining 8 bytes are manufacturer-specific. */
#define SENSOR_INIT_BASIC_POWER_SOURCE ZB_ZCL_BASIC_POWER_SOURCE_DC_SOURCE /**< Type of power source or sources available for the device. For possible values, see section 3.2.2.2.8 of the ZCL specification. */
#define SENSOR_INIT_BASIC_LOCATION_DESC "House" /**< Description of the physical location of the device (16 bytes). You can modify it during the commisioning process. */
#define SENSOR_INIT_BASIC_PH_ENV ZB_ZCL_BASIC_ENV_UNSPECIFIED /**< Description of the type of physical environment. For possible values, see section 3.2.2.2.10 of the ZCL specification. */
#define MULTI_SENSOR_ENDPOINT 10 /**< Device endpoint. Used to receive light controlling commands. */
/* Main application customizable context. Stores all settings and static values. */
typedef struct
zb_zcl_basic_attrs_ext_t basic_attr;
zb_zcl_identify_attrs_t identify_attr;
zb_zcl_temp_measurement_attrs_t temp_attr;
zb_zcl_pressure_measurement_attrs_t pres_attr;
zb_zcl_rel_humidity_measurement_attrs_t rel_hum_attr;
} sensor_device_ctx_t;
#define ZB_MULTI_SENSOR_REPORT_ATTR_COUNT 3 /**< Number of attributes mandatory for reporting in the Temperature, humidity and Pressure Measurement cluster. */
#define ZB_DEVICE_VER_MULTI_SENSOR 0 /**< Multisensor device version. */
#define ZB_MULTI_SENSOR_IN_CLUSTER_NUM 1 /**< Number of the input (server) clusters in the multisensor device. */
#define ZB_MULTI_SENSOR_OUT_CLUSTER_NUM 5 /**< Number of the output (client) clusters in the multisensor device. */
/** @brief Declares cluster list for the multisensor device.
* @param cluster_list_name Cluster list variable name.
* @param basic_attr_list Attribute list for the Basic cluster.
* @param identify_attr_list Attribute list for the Identify cluster.
* @param temp_measure_attr_list Attribute list for the Temperature Measurement cluster.
* @param pressure_measure_attr_list Attribute list for the Pressure Measurement cluster.
* @param rel_humidity_measure_attr_list Attribute list for the Humidity Measurement cluster.
#define ZB_DECLARE_MULTI_SENSOR_CLUSTER_LIST( \
cluster_list_name, \
basic_attr_list, \
identify_attr_list, \
temp_measure_attr_list, \
pres_measure_attr_list, \
rel_humidity_measure_attr_list) \
zb_zcl_cluster_desc_t cluster_list_name[] = \
ZB_ZCL_CLUSTER_DESC( \
ZB_ZCL_CLUSTER_ID_IDENTIFY, \
ZB_ZCL_ARRAY_SIZE(identify_attr_list, zb_zcl_attr_t), \
(identify_attr_list), \
ZB_ZCL_CLUSTER_SERVER_ROLE, \
ZB_ZCL_MANUF_CODE_INVALID \
ZB_ZCL_CLUSTER_ID_BASIC, \
ZB_ZCL_ARRAY_SIZE(basic_attr_list, zb_zcl_attr_t), \
(basic_attr_list), \
ZB_ZCL_CLUSTER_ID_TEMP_MEASUREMENT, \
ZB_ZCL_ARRAY_SIZE(temp_measure_attr_list, zb_zcl_attr_t), \
(temp_measure_attr_list), \
ZB_ZCL_CLUSTER_ID_PRESSURE_MEASUREMENT, \
ZB_ZCL_ARRAY_SIZE(pres_measure_attr_list, zb_zcl_attr_t), \
(pres_measure_attr_list), \
ZB_ZCL_CLUSTER_ID_REL_HUMIDITY_MEASUREMENT, \
ZB_ZCL_ARRAY_SIZE(rel_humidity_measure_attr_list, zb_zcl_attr_t), \
(rel_humidity_measure_attr_list), \
0, \
NULL, \
ZB_ZCL_CLUSTER_CLIENT_ROLE, \
/** @brief Declares simple descriptor for the "Device_name" device.
* @param ep_name Endpoint variable name.
* @param ep_id Endpoint ID.
* @param in_clust_num Number of the supported input clusters.
* @param out_clust_num Number of the supported output clusters.
#define ZB_ZCL_DECLARE_MULTI_SENSOR_DESC(ep_name, ep_id, in_clust_num, out_clust_num) \
ZB_DECLARE_SIMPLE_DESC(in_clust_num, out_clust_num); \
ZB_AF_SIMPLE_DESC_TYPE(in_clust_num, out_clust_num) simple_desc_##ep_name = \
ep_id, \
ZB_AF_HA_PROFILE_ID, \
ZB_HA_TEMPERATURE_SENSOR_DEVICE_ID, \
ZB_DEVICE_VER_MULTI_SENSOR, \
0, \
in_clust_num, \
out_clust_num, \
/** @brief Declares endpoint for the multisensor device.
* @param cluster_list Endpoint cluster list.
#define ZB_ZCL_DECLARE_MULTI_SENSOR_EP(ep_name, ep_id, cluster_list) \
ZB_ZCL_DECLARE_MULTI_SENSOR_DESC(ep_name, \
ep_id, \
ZB_MULTI_SENSOR_IN_CLUSTER_NUM, \
ZB_MULTI_SENSOR_OUT_CLUSTER_NUM); \
ZBOSS_DEVICE_DECLARE_REPORTING_CTX(reporting_info## device_ctx_name, \
ZB_MULTI_SENSOR_REPORT_ATTR_COUNT); \
ZB_AF_DECLARE_ENDPOINT_DESC(ep_name, ep_id, \
0, \
NULL, \
ZB_ZCL_ARRAY_SIZE(cluster_list, zb_zcl_cluster_desc_t), \
cluster_list, \
(zb_af_simple_desc_1_1_t*)&simple_desc_##ep_name, \
ZB_MULTI_SENSOR_REPORT_ATTR_COUNT, reporting_info## device_ctx_name, 0, NULL)
#ifdef __cplusplus
#endif // ZB_MULTI_SENSOR_H__
main.c
* Copyright (c) 2018 - 2020, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @file
* @defgroup zigbee_examples_multi_sensor main.c
* @ingroup zigbee_examples
* @brief Zigbee Pressure and Temperature sensor
#include "zb_mem_config_med.h"
#include "zb_error_handler.h"
#include "zigbee_helpers.h"
#include "app_timer.h"
#include "bsp.h"
#include "boards.h"
#include "sensorsim.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "zb_multi_sensor.h"
#define IEEE_CHANNEL_MASK (1l << ZIGBEE_CHANNEL) /**< Scan only one, predefined channel to find the coordinator. */
#define ERASE_PERSISTENT_CONFIG ZB_TRUE /**< Do not erase NVRAM to save the network parameters after device reboot or power-off. */
#define ZIGBEE_NETWORK_STATE_LED BSP_BOARD_LED_2 /**< LED indicating that light switch successfully joind Zigbee network. */
#define MIN_TEMPERATURE_VALUE 0 /**< Minimum temperature value as returned by the simulated measurement function. */
#define MAX_TEMPERATURE_VALUE 4000 /**< Maximum temperature value as returned by the simulated measurement function. */
#define TEMPERATURE_VALUE_INCREMENT 50 /**< Value by which the temperature value is incremented/decremented for each call to the simulated measurement function. */
#define MIN_PRESSURE_VALUE 700 /**< Minimum pressure value as returned by the simulated measurement function. */
#define MAX_PRESSURE_VALUE 1100 /**< Maximum pressure value as returned by the simulated measurement function. */
#define PRESSURE_VALUE_INCREMENT 5 /**< Value by which the temperature value is incremented/decremented for each call to the simulated measurement function. */
/******************************************************* USER **********************************************************************/
#define MIN_HUMIDITY_VALUE 0
#define MAX_HUMIDITY_VALUE 10000
#define HUMIDITY_VALUE_INCREMENT 100
#if !defined ZB_ED_ROLE
#error Define ZB_ED_ROLE to compile End Device source code.
static sensor_device_ctx_t m_dev_ctx;
ZB_ZCL_DECLARE_IDENTIFY_ATTRIB_LIST(identify_attr_list, &m_dev_ctx.identify_attr.identify_time);
ZB_ZCL_DECLARE_BASIC_ATTRIB_LIST_EXT(basic_attr_list,
&m_dev_ctx.basic_attr.zcl_version,
&m_dev_ctx.basic_attr.app_version,
&m_dev_ctx.basic_attr.stack_version,
&m_dev_ctx.basic_attr.hw_version,
m_dev_ctx.basic_attr.mf_name,
m_dev_ctx.basic_attr.model_id,
m_dev_ctx.basic_attr.date_code,
&m_dev_ctx.basic_attr.power_source,
m_dev_ctx.basic_attr.location_id,
&m_dev_ctx.basic_attr.ph_env,
m_dev_ctx.basic_attr.sw_ver);
ZB_ZCL_DECLARE_TEMP_MEASUREMENT_ATTRIB_LIST(temperature_attr_list,
&m_dev_ctx.temp_attr.measure_value,
&m_dev_ctx.temp_attr.min_measure_value,
&m_dev_ctx.temp_attr.max_measure_value,
&m_dev_ctx.temp_attr.tolerance);
ZB_ZCL_DECLARE_PRES_MEASUREMENT_ATTRIB_LIST(pressure_attr_list,
&m_dev_ctx.pres_attr.measure_value,
&m_dev_ctx.pres_attr.min_measure_value,
&m_dev_ctx.pres_attr.max_measure_value,
&m_dev_ctx.pres_attr.tolerance);
ZB_ZCL_DECLARE_REL_HUMIDITY_MEASUREMENT_ATTRIB_LIST(rel_humidity_measure_attr_list,
&m_dev_ctx.rel_hum_attr.measure_value,
&m_dev_ctx.rel_hum_attr.min_measure_value,
&m_dev_ctx.rel_hum_attr.max_measure_value);
ZB_DECLARE_MULTI_SENSOR_CLUSTER_LIST(multi_sensor_clusters,
basic_attr_list,
identify_attr_list,
pressure_attr_list,
rel_humidity_measure_attr_list);
ZB_ZCL_DECLARE_MULTI_SENSOR_EP(multi_sensor_ep,
MULTI_SENSOR_ENDPOINT,
multi_sensor_clusters);
ZBOSS_DECLARE_DEVICE_CTX_1_EP(multi_sensor_ctx, multi_sensor_ep);
static sensorsim_cfg_t m_temperature_sim_cfg; /**< Temperature sensor simulator configuration. */
static sensorsim_state_t m_temperature_sim_state; /**< Temperature sensor simulator state. */
static sensorsim_cfg_t m_pressure_sim_cfg; /**< Pressure sensor simulator configuration. */
static sensorsim_state_t m_pressure_sim_state; /**< Pressure sensor simulator state. */
static sensorsim_cfg_t m_rel_humidity_sim_cfg; /**< Humidity sensor simulator configuration. */
static sensorsim_state_t m_rel_humidity_sim_state; /**< Humidity sensor simulator state. */
APP_TIMER_DEF(zb_app_timer);
/**@brief Function for the Timer initialization.
* @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void)
ret_code_t err_code;
// Initialize timer module.
err_code = app_timer_init();
static void log_init(void)
/**@brief Function for initializing all clusters attributes.
static void multi_sensor_clusters_attr_init(void)
/* Basic cluster attributes data */
m_dev_ctx.basic_attr.zcl_version = ZB_ZCL_VERSION;
m_dev_ctx.basic_attr.app_version = SENSOR_INIT_BASIC_APP_VERSION;
m_dev_ctx.basic_attr.stack_version = SENSOR_INIT_BASIC_STACK_VERSION;
m_dev_ctx.basic_attr.hw_version = SENSOR_INIT_BASIC_HW_VERSION;
/* Use ZB_ZCL_SET_STRING_VAL to set strings, because the first byte should
* contain string length without trailing zero.
* For example "test" string wil be encoded as:
* [(0x4), 't', 'e', 's', 't']
ZB_ZCL_SET_STRING_VAL(m_dev_ctx.basic_attr.mf_name,
SENSOR_INIT_BASIC_MANUF_NAME,
ZB_ZCL_STRING_CONST_SIZE(SENSOR_INIT_BASIC_MANUF_NAME));
ZB_ZCL_SET_STRING_VAL(m_dev_ctx.basic_attr.model_id,
SENSOR_INIT_BASIC_MODEL_ID,
ZB_ZCL_STRING_CONST_SIZE(SENSOR_INIT_BASIC_MODEL_ID));
ZB_ZCL_SET_STRING_VAL(m_dev_ctx.basic_attr.date_code,
SENSOR_INIT_BASIC_DATE_CODE,
ZB_ZCL_STRING_CONST_SIZE(SENSOR_INIT_BASIC_DATE_CODE));
m_dev_ctx.basic_attr.power_source = SENSOR_INIT_BASIC_POWER_SOURCE;
ZB_ZCL_SET_STRING_VAL(m_dev_ctx.basic_attr.location_id,
SENSOR_INIT_BASIC_LOCATION_DESC,
ZB_ZCL_STRING_CONST_SIZE(SENSOR_INIT_BASIC_LOCATION_DESC));
m_dev_ctx.basic_attr.ph_env = SENSOR_INIT_BASIC_PH_ENV;
/* Identify cluster attributes data */
m_dev_ctx.identify_attr.identify_time = ZB_ZCL_IDENTIFY_IDENTIFY_TIME_DEFAULT_VALUE;
/* Temperature measurement cluster attributes data */
m_dev_ctx.temp_attr.measure_value = ZB_ZCL_ATTR_TEMP_MEASUREMENT_VALUE_UNKNOWN;
m_dev_ctx.temp_attr.min_measure_value = ZB_ZCL_ATTR_TEMP_MEASUREMENT_MIN_VALUE_MIN_VALUE;
m_dev_ctx.temp_attr.max_measure_value = ZB_ZCL_ATTR_TEMP_MEASUREMENT_MAX_VALUE_MAX_VALUE;
m_dev_ctx.temp_attr.tolerance = ZB_ZCL_ATTR_TEMP_MEASUREMENT_TOLERANCE_MAX_VALUE;
/* Pressure measurement cluster attributes data */
m_dev_ctx.pres_attr.measure_value = ZB_ZCL_ATTR_PRES_MEASUREMENT_VALUE_UNKNOWN;
m_dev_ctx.pres_attr.min_measure_value = ZB_ZCL_ATTR_PRES_MEASUREMENT_MIN_VALUE_MIN_VALUE;
m_dev_ctx.pres_attr.max_measure_value = ZB_ZCL_ATTR_PRES_MEASUREMENT_MAX_VALUE_MAX_VALUE;
m_dev_ctx.pres_attr.tolerance = ZB_ZCL_ATTR_PRES_MEASUREMENT_TOLERANCE_MAX_VALUE;
/******************************************************* USER *************************************************************/
/* Humidity measurement cluster attributes data */
m_dev_ctx.rel_hum_attr.measure_value = ZB_ZCL_ATTR_REL_HUMIDITY_MEASUREMENT_VALUE_UNKNOWN;
m_dev_ctx.rel_hum_attr.min_measure_value = ZB_ZCL_ATTR_REL_HUMIDITY_MEASUREMENT_MIN_VALUE_MIN_VALUE;
m_dev_ctx.rel_hum_attr.max_measure_value = ZB_ZCL_ATTR_REL_HUMIDITY_MEASUREMENT_MAX_VALUE_MAX_VALUE;
/**@brief Function for initializing LEDs.
static zb_void_t leds_init(void)
ret_code_t error_code;
/* Initialize LEDs and buttons - use BSP to control them. */
error_code = bsp_init(BSP_INIT_LEDS, NULL);
APP_ERROR_CHECK(error_code);
bsp_board_leds_off();
/**@brief Function for handling nrf app timer.
* @param[IN] context Void pointer to context function is called with.
* @details Function is called with pointer to sensor_device_ep_ctx_t as argument.
static void zb_app_timer_handler(void * context)
zb_zcl_status_t zcl_status;
static zb_int16_t new_temp_value, new_pres_value, new_rel_hum_value;
/* Get new temperature measured value */
new_temp_value = (zb_int16_t)sensorsim_measure(&m_temperature_sim_state, &m_temperature_sim_cfg);
zcl_status = zb_zcl_set_attr_val(MULTI_SENSOR_ENDPOINT,
ZB_ZCL_ATTR_TEMP_MEASUREMENT_VALUE_ID,
(zb_uint8_t *)&new_temp_value,
ZB_FALSE);
if(zcl_status != ZB_ZCL_STATUS_SUCCESS)
NRF_LOG_INFO("Set temperature value fail. zcl_status: %d", zcl_status);
/* Get new pressure measured value */
new_pres_value = (zb_int16_t)sensorsim_measure(&m_pressure_sim_state, &m_pressure_sim_cfg);
ZB_ZCL_ATTR_PRES_MEASUREMENT_VALUE_ID,
(zb_uint8_t *)&new_pres_value,
ZB_FALSE);
NRF_LOG_INFO("Set pressure value fail. zcl_status: %d", zcl_status);
/******************************************************* USER ************************************************************/
new_rel_hum_value = (zb_int16_t)sensorsim_measure(&m_rel_humidity_sim_state, &m_rel_humidity_sim_cfg);
ZB_ZCL_ATTR_REL_HUMIDITY_MEASUREMENT_VALUE_ID,
(zb_uint8_t *)&new_rel_hum_value,
ZB_FALSE);
NRF_LOG_INFO("Set humidity value fail. zcl_status: %d", zcl_status);
/**@brief Function for initializing the sensor simulators.
static void sensor_simulator_init(void)
m_temperature_sim_cfg.min = MIN_TEMPERATURE_VALUE;
m_temperature_sim_cfg.max = MAX_TEMPERATURE_VALUE;
m_temperature_sim_cfg.incr = TEMPERATURE_VALUE_INCREMENT;
m_temperature_sim_cfg.start_at_max = false;
sensorsim_init(&m_temperature_sim_state, &m_temperature_sim_cfg);
m_pressure_sim_cfg.min = MIN_PRESSURE_VALUE;
m_pressure_sim_cfg.max = MAX_PRESSURE_VALUE;
m_pressure_sim_cfg.incr = PRESSURE_VALUE_INCREMENT;
m_pressure_sim_cfg.start_at_max = false;
sensorsim_init(&m_pressure_sim_state, &m_pressure_sim_cfg);
m_rel_humidity_sim_cfg.min = MIN_HUMIDITY_VALUE;
m_rel_humidity_sim_cfg.max = MAX_HUMIDITY_VALUE;
m_rel_humidity_sim_cfg.incr = HUMIDITY_VALUE_INCREMENT;
m_rel_humidity_sim_cfg.start_at_max = false;
sensorsim_init(&m_rel_humidity_sim_state, &m_rel_humidity_sim_cfg);
/**@brief Zigbee stack event handler.
* @param[in] bufid Reference to the Zigbee stack buffer used to pass signal.
void zboss_signal_handler(zb_bufid_t bufid)
zb_zdo_app_signal_hdr_t * p_sg_p = NULL;
zb_zdo_app_signal_type_t sig = zb_get_app_signal(bufid, &p_sg_p);
zb_ret_t status = ZB_GET_APP_SIGNAL_STATUS(bufid);
/* Update network status LED */
zigbee_led_status_update(bufid, ZIGBEE_NETWORK_STATE_LED);
switch (sig)
case ZB_BDB_SIGNAL_DEVICE_REBOOT:
/* fall-through */
case ZB_BDB_SIGNAL_STEERING:
/* Call default signal handler. */
ZB_ERROR_CHECK(zigbee_default_signal_handler(bufid));
if (status == RET_OK)
ret_code_t err_code = app_timer_start(zb_app_timer, APP_TIMER_TICKS(2000), NULL);
if (bufid)
zb_buf_free(bufid);
/**@brief Function for application main entry.
zb_ret_t zb_err_code;
zb_ieee_addr_t ieee_addr;
/* Initialize loging system and GPIOs. */
timers_init();
log_init();
sensor_simulator_init();
leds_init();
/* Create Timer for reporting attribute */
err_code = app_timer_create(&zb_app_timer, APP_TIMER_MODE_REPEATED, zb_app_timer_handler);
/* Set Zigbee stack logging level and traffic dump subsystem. */
ZB_SET_TRACE_LEVEL(ZIGBEE_TRACE_LEVEL);
ZB_SET_TRACE_MASK(ZIGBEE_TRACE_MASK);
ZB_SET_TRAF_DUMP_OFF();
/* Initialize Zigbee stack. */
ZB_INIT("multi_sensor");
/* Set device address to the value read from FICR registers. */
zb_osif_get_ieee_eui64(ieee_addr);
zb_set_long_address(ieee_addr);
/* Set static long IEEE address. */
zb_set_network_ed_role(IEEE_CHANNEL_MASK);
zigbee_erase_persistent_storage(ERASE_PERSISTENT_CONFIG);
zb_set_ed_timeout(ED_AGING_TIMEOUT_64MIN);
zb_set_keepalive_timeout(ZB_MILLISECONDS_TO_BEACON_INTERVAL(3000));
zb_set_rx_on_when_idle(ZB_FALSE);
/* Initialize application context structure. */
UNUSED_RETURN_VALUE(ZB_MEMSET(&m_dev_ctx, 0, sizeof(m_dev_ctx)));
/* Register temperature sensor device context (endpoints). */
ZB_AF_REGISTER_DEVICE_CTX(&multi_sensor_ctx);
/* Initialize sensor device attibutes */
multi_sensor_clusters_attr_init();
/** Start Zigbee Stack. */
zb_err_code = zboss_start_no_autostart();
ZB_ERROR_CHECK(zb_err_code);
while(1)
zboss_main_loop_iteration();
UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
zb_zcl_rel_humidity_measurement.c
#include "app_error.h"
static zb_ret_t check_value_rel_humidity_measurement(zb_uint16_t attr_id, zb_uint8_t endpoint, zb_uint8_t * p_value)
zb_ret_t ret = ZB_FALSE;
zb_int16_t val = ZB_ZCL_ATTR_GETS16(p_value);
NRF_LOG_DEBUG("Pre-validating value %hi of Humidity attribute %d", val, attr_id);
switch(attr_id)
case ZB_ZCL_ATTR_REL_HUMIDITY_MEASUREMENT_VALUE_ID:
/* Check if the value is unknown. */
if (val != ZB_ZCL_ATTR_REL_HUMIDITY_MEASUREMENT_VALUE_UNKNOWN)
/* Check if the value is higher than the minimal allowed. */
zb_zcl_attr_t * p_attr_min_desc = zb_zcl_get_attr_desc_a(endpoint,
ZB_ZCL_ATTR_REL_HUMIDITY_MEASUREMENT_MIN_VALUE_ID);
ASSERT(p_attr_min_desc);
zb_int16_t minimal_value = ZB_ZCL_GET_ATTRIBUTE_VAL_S16(p_attr_min_desc);
if ((minimal_value != ZB_ZCL_ATTR_REL_HUMIDITY_MEASUREMENT_MIN_VALUE_UNDEFINED) &&
(minimal_value > val))
/* Check if the value is lower than the maximal allowed. */
zb_zcl_attr_t * p_attr_max_desc = zb_zcl_get_attr_desc_a(endpoint,
ZB_ZCL_ATTR_REL_HUMIDITY_MEASUREMENT_MAX_VALUE_ID);
ASSERT(p_attr_max_desc);
zb_int16_t maximal_value = ZB_ZCL_GET_ATTRIBUTE_VAL_S16(p_attr_max_desc);
if ((maximal_value != ZB_ZCL_ATTR_REL_HUMIDITY_MEASUREMENT_MAX_VALUE_UNDEFINED) &&
(val > maximal_value))
ret = ZB_TRUE;
case ZB_ZCL_ATTR_REL_HUMIDITY_MEASUREMENT_MIN_VALUE_ID:
/* Check the invalid value */
if (val != ZB_ZCL_ATTR_REL_HUMIDITY_MEASUREMENT_MIN_VALUE_UNDEFINED)
/* Check the value is in bounds */
if ((val < ZB_ZCL_ATTR_REL_HUMIDITY_MEASUREMENT_MIN_VALUE_MIN_VALUE) ||
(val > ZB_ZCL_ATTR_REL_HUMIDITY_MEASUREMENT_MIN_VALUE_MAX_VALUE))
ret = ZB_TRUE;
case ZB_ZCL_ATTR_REL_HUMIDITY_MEASUREMENT_MAX_VALUE_ID:
if (val != ZB_ZCL_ATTR_REL_HUMIDITY_MEASUREMENT_MAX_VALUE_UNDEFINED)
if ((val < ZB_ZCL_ATTR_REL_HUMIDITY_MEASUREMENT_MAX_VALUE_MIN_VALUE) ||
#if ZB_ZCL_ATTR_REL_HUMIDITY_MEASUREMENT_MAX_VALUE_MAX_VALUE != 0x7FFF
/* Avoid compiler warning about always false condition */
(val > ZB_ZCL_ATTR_REL_HUMIDITY_MEASUREMENT_MAX_VALUE_MAX_VALUE))
#else
(0))
ret = ZB_TRUE;
return ret;
static zb_void_t zb_zcl_rel_humidity_measurement_write_attr_hook(zb_uint8_t endpoint, zb_uint16_t attr_id, zb_uint8_t * new_value)
UNUSED_PARAMETER(new_value);
NRF_LOG_DEBUG("Writing attribute %d of Humidity Measurement Cluster on endpoint %d", attr_id, endpoint);
if (attr_id == ZB_ZCL_ATTR_REL_HUMIDITY_MEASUREMENT_VALUE_ID)
/* Implement your own write attributes hook if needed. */
/**@brief Function which initialises the server side of Pressure Measurement Cluster. */
zb_void_t zb_zcl_rel_humidity_init_server()
zb_ret_t ret = zb_zcl_add_cluster_handlers(ZB_ZCL_CLUSTER_ID_REL_HUMIDITY_MEASUREMENT,
check_value_rel_humidity_measurement,
zb_zcl_rel_humidity_measurement_write_attr_hook,
(zb_zcl_cluster_handler_t)NULL);
ASSERT(ret == RET_OK);
/**@brief Function which initialises the client side of Pressure Measurement Cluster. */
zb_void_t zb_zcl_rel_humidity_init_client()
What i am doing wrong?
