Hi all, I am combining MESH SDK 3.0.0 light switch example client and server with SDK 15.2. I have combined some server code to client and there are no error. And I can use nrfmesh to setup the network successfully. However, there are no respond on other boards when I press on one of the board. I have followed this thread to increase ACCESS_MODEL_COUNT and ACCESS_ELEMENT_COUNT by 1, but it doesn't work. Can anyone help me?
Following is the combined main.c code.
#include <stdint.h>
#include <string.h>
/* HAL */
#include "boards.h"
#include "simple_hal.h"
#include "app_timer.h"
/* Core */
#include "nrf_mesh_config_core.h"
#include "nrf_mesh_configure.h"
#include "nrf_mesh.h"
#include "mesh_stack.h"
#include "device_state_manager.h"
#include "access_config.h"
/* Provisioning and configuration */
#include "mesh_provisionee.h"
#include "mesh_app_utils.h"
/* Models */
#include "generic_onoff_client.h"
#include "generic_onoff_server.h"
/* Logging and RTT */
#include "log.h"
#include "rtt_input.h"
/* Example specific includes */
#include "app_config.h"
#include "nrf_mesh_config_examples.h"
#include "light_switch_example_common.h"
#include "app_onoff.h"
#include "example_common.h"
#include "ble_softdevice_support.h"
#define APP_STATE_OFF (0)
#define APP_STATE_ON (1)
#define APP_UNACK_MSG_REPEAT_COUNT (2)
static generic_onoff_client_t m_clients[CLIENT_MODEL_INSTANCE_COUNT];
static bool m_device_provisioned;
/* Forward declaration */
static void app_gen_onoff_client_publish_interval_cb(access_model_handle_t handle, void * p_self);
static void app_generic_onoff_client_status_cb(const generic_onoff_client_t * p_self,
const access_message_rx_meta_t * p_meta,
const generic_onoff_status_params_t * p_in);
static void app_gen_onoff_client_transaction_status_cb(access_model_handle_t model_handle,
void * p_args,
access_reliable_status_t status);
const generic_onoff_client_callbacks_t client_cbs =
.onoff_status_cb = app_generic_onoff_client_status_cb,
.ack_transaction_status_cb = app_gen_onoff_client_transaction_status_cb,
.periodic_publish_cb = app_gen_onoff_client_publish_interval_cb
static void device_identification_start_cb(uint8_t attention_duration_s)
hal_led_mask_set(LEDS_MASK, false);
hal_led_blink_ms(BSP_LED_2_MASK | BSP_LED_3_MASK,
LED_BLINK_ATTENTION_INTERVAL_MS,
LED_BLINK_ATTENTION_COUNT(attention_duration_s));
static void provisioning_aborted_cb(void)
hal_led_blink_stop();
static void provisioning_complete_cb(void)
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Successfully provisioned\n");
#if MESH_FEATURE_GATT_ENABLED
/* Restores the application parameters after switching from the Provisioning
* service to the Proxy */
gap_params_init();
conn_params_init();
dsm_local_unicast_address_t node_address;
dsm_local_unicast_addresses_get(&node_address);
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Node Address: 0x%04x \n", node_address.address_start);
hal_led_mask_set(LEDS_MASK, LED_MASK_STATE_OFF);
hal_led_blink_ms(LEDS_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_PROV);
static void app_onoff_server_set_cb(const app_onoff_server_t * p_server, bool onoff);
static void app_onoff_server_get_cb(const app_onoff_server_t * p_server, bool * p_present_onoff);
/* Generic OnOff server structure definition and initialization */
APP_ONOFF_SERVER_DEF(m_onoff_server_0,
APP_CONFIG_FORCE_SEGMENTATION,
APP_CONFIG_MIC_SIZE,
app_onoff_server_set_cb,
app_onoff_server_get_cb)
/* Callback for updating the hardware state */
/* Resolve the server instance here if required, this example uses only 1 instance. */
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Setting GPIO value: %d\n", onoff)
hal_led_pin_set(BSP_LED_0, onoff);
/* Callback for reading the hardware state */
*p_present_onoff = hal_led_pin_get(BSP_LED_0);
/* This callback is called periodically if model is configured for periodic publishing */
__LOG(LOG_SRC_APP, LOG_LEVEL_WARN, "Publish desired message here.\n");
/* Acknowledged transaction status callback, if acknowledged transfer fails, application can
* determine suitable course of action (e.g. re-initiate previous transaction) by using this
* callback.
void * p_args,
switch(status)
case ACCESS_RELIABLE_TRANSFER_SUCCESS:
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Acknowledged transfer success.\n");
case ACCESS_RELIABLE_TRANSFER_TIMEOUT:
hal_led_blink_ms(LEDS_MASK, LED_BLINK_SHORT_INTERVAL_MS, LED_BLINK_CNT_NO_REPLY);
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Acknowledged transfer timeout.\n");
case ACCESS_RELIABLE_TRANSFER_CANCELLED:
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Acknowledged transfer cancelled.\n");
ERROR_CHECK(NRF_ERROR_INTERNAL);
/* Generic OnOff client model interface: Process the received status message in this callback */
if (p_in->remaining_time_ms > 0)
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "OnOff server: 0x%04x, Present OnOff: %d, Target OnOff: %d, Remaining Time: %d ms\n",
p_meta->src.value, p_in->present_on_off, p_in->target_on_off, p_in->remaining_time_ms);
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "OnOff server: 0x%04x, Present OnOff: %d\n",
p_meta->src.value, p_in->present_on_off);
static void node_reset(void)
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- Node reset -----\n");
hal_led_blink_ms(LEDS_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_RESET);
/* This function may return if there are ongoing flash operations. */
mesh_stack_device_reset();
static void config_server_evt_cb(const config_server_evt_t * p_evt)
if (p_evt->type == CONFIG_SERVER_EVT_NODE_RESET)
node_reset();
static void button_event_handler(uint32_t button_number)
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Button %u pressed\n", button_number);
uint32_t status = NRF_SUCCESS;
generic_onoff_set_params_t set_params;
model_transition_t transition_params;
static uint8_t tid = 0;
/* Button 1: On, Button 2: Off, Client[0]
* Button 2: On, Button 3: Off, Client[1]
switch(button_number)
case 0:
case 2:
set_params.on_off = APP_STATE_ON;
case 1:
case 3:
set_params.on_off = APP_STATE_OFF;
set_params.tid = tid++;
transition_params.delay_ms = APP_CONFIG_ONOFF_DELAY_MS;
transition_params.transition_time_ms = APP_CONFIG_ONOFF_TRANSITION_TIME_MS;
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Sending msg: ONOFF SET %d\n", set_params.on_off);
switch (button_number)
case 0:
case 1:
/* Demonstrate acknowledged transaction, using 1st client model instance */
/* In this examples, users will not be blocked if the model is busy */
(void)access_model_reliable_cancel(m_clients[0].model_handle);
status = generic_onoff_client_set(&m_clients[0], &set_params, &transition_params);
hal_led_pin_set(BSP_LED_0, set_params.on_off);
case 2:
case 3:
/* Demonstrate un-acknowledged transaction, using 2nd client model instance */
status = generic_onoff_client_set_unack(&m_clients[1], &set_params,
&transition_params, APP_UNACK_MSG_REPEAT_COUNT);
hal_led_pin_set(BSP_LED_1, set_params.on_off);
switch (status)
case NRF_SUCCESS:
case NRF_ERROR_NO_MEM:
case NRF_ERROR_BUSY:
case NRF_ERROR_INVALID_STATE:
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Client %u cannot send\n", button_number);
case NRF_ERROR_INVALID_PARAM:
/* Publication not enabled for this client. One (or more) of the following is wrong:
* - An application key is missing, or there is no application key bound to the model
* - The client does not have its publication state set
* It is the provisioner that adds an application key, binds it to the model and sets
* the model's publication state.
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Publication not configured for client %u\n", button_number);
ERROR_CHECK(status);
static void rtt_input_handler(int key)
if (key >= '0' && key <= '3')
uint32_t button_number = key - '0';
button_event_handler(button_number);
static void models_init_cb(void)
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Initializing and adding models\n");
for (uint32_t i = 0; i < CLIENT_MODEL_INSTANCE_COUNT; ++i)
m_clients[i].settings.p_callbacks = &client_cbs;
m_clients[i].settings.timeout = 0;
m_clients[i].settings.force_segmented = APP_CONFIG_FORCE_SEGMENTATION;
m_clients[i].settings.transmic_size = APP_CONFIG_MIC_SIZE;
ERROR_CHECK(generic_onoff_client_init(&m_clients[i], i + 1));
static void mesh_init(void)
uint8_t dev_uuid[NRF_MESH_UUID_SIZE];
uint8_t node_uuid_prefix[NODE_UUID_PREFIX_LEN] = CLIENT_NODE_UUID_PREFIX;
ERROR_CHECK(mesh_app_uuid_gen(dev_uuid, node_uuid_prefix, NODE_UUID_PREFIX_LEN));
mesh_stack_init_params_t init_params =
.core.irq_priority = NRF_MESH_IRQ_PRIORITY_LOWEST,
.core.lfclksrc = DEV_BOARD_LF_CLK_CFG,
.core.p_uuid = dev_uuid,
.models.models_init_cb = models_init_cb,
.models.config_server_cb = config_server_evt_cb
ERROR_CHECK(mesh_stack_init(&init_params, &m_device_provisioned));
static void initialize(void)
__LOG_INIT(LOG_SRC_APP | LOG_SRC_ACCESS | LOG_SRC_BEARER, LOG_LEVEL_INFO, LOG_CALLBACK_DEFAULT);
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- BLE Mesh Light Switch Client Demo -----\n");
ERROR_CHECK(app_timer_init());
hal_leds_init();
#if BUTTON_BOARD
ERROR_CHECK(hal_buttons_init(button_event_handler));
ble_stack_init();
gap_params_init();
conn_params_init();
mesh_init();
static void start(void)
rtt_input_enable(rtt_input_handler, RTT_INPUT_POLL_PERIOD_MS);
if (!m_device_provisioned)
static const uint8_t static_auth_data[NRF_MESH_KEY_SIZE] = STATIC_AUTH_DATA;
mesh_provisionee_start_params_t prov_start_params =
.p_static_data = static_auth_data,
.prov_complete_cb = provisioning_complete_cb,
.prov_device_identification_start_cb = device_identification_start_cb,
.prov_device_identification_stop_cb = NULL,
.prov_abort_cb = provisioning_aborted_cb,
.p_device_uri = NULL
ERROR_CHECK(mesh_provisionee_prov_start(&prov_start_params));
const uint8_t *p_uuid = nrf_mesh_configure_device_uuid_get();
UNUSED_VARIABLE(p_uuid);
__LOG_XB(LOG_SRC_APP, LOG_LEVEL_INFO, "Device UUID ", p_uuid, NRF_MESH_UUID_SIZE);
ERROR_CHECK(mesh_stack_start());
hal_led_blink_ms(LEDS_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_START);
initialize();
start();
for (;;)
(void)sd_app_evt_wait();
